[General] Pass Guaranteed Fantastic Salesforce - Valid CRT-450 Test Answers
94
General Pass Guaranteed Fantastic Salesforce - Valid CRT-450 Test Answers
Posted at 2/3/2026 15:07:00      View129 | Replies0        Print      Only Author   [Copy Link] 1#
2026 Latest Pass4sures CRT-450 PDF Dumps and CRT-450 Exam Engine Free Share: https://drive.google.com/open?id=1YlPwrx61I_4YdS_RHHWs2JuVipaMPoEG
We check the updating of Salesforce exam dumps everyday to make sure customer to pass the exam with latest vce dumps. Once the latest version of CRT-450 exam pdf released, our system will send it to your mail immediately. You will be allowed to free update your CRT-450 Top Questions one-year after purchased. Please feel free to contact us if you have any questions about our dumps.
Salesforce CRT-450 Certification Exam is an essential credential for developers who want to pursue a career in Salesforce development. Salesforce Certified Platform Developer I certification demonstrates that the candidate has the skills and knowledge necessary to design and develop custom applications on the Salesforce platform. It also provides a competitive edge in the job market and opens up new career opportunities. Furthermore, becoming a certified Salesforce developer is a great way to showcase your expertise and commitment to your profession.
CRT-450 actual test & CRT-450 pass for sure & CRT-450 test guideIn order to cater to different kinds of needs of candidates, we offer three versions for CRT-450 training materials for you to select. Each version has its own advantage, and you can choose the most suitable one in accordance with your own needs. CRT-450 PDF version is printable, and you can print it into paper if you like. CRT-450 Soft test engine can stimulate the real exam environment, so that you can build up your confidence for the exam. CRT-450 Online test engine is convenient and easy to learn, and it supports offline proactive. You can also have a review of what you have learned through CRT-450 Online test engine.
Salesforce CRT-450 is a certification exam that evaluates an individual's knowledge and skills in developing and customizing applications on the Salesforce platform. Salesforce Certified Platform Developer I certification is suitable for individuals who are interested in pursuing a career as a Salesforce platform developer. The Salesforce Certified Platform Developer I certification is the foundation-level certification for developers that assesses the essential knowledge and skills required to develop custom applications on the Salesforce platform.
Salesforce Certified Platform Developer I Sample Questions (Q61-Q66):NEW QUESTION # 61
Which scenario is invalid for execution by unit tests?
  • A. Executing methods as different users.
  • B. Executing methods for negative test scenarios
  • C. Loading test data in place of user input for Flows.
  • D. Loading the standard Pricebook ID using a system method
NEW QUESTION # 62
Universal Containers has developed custom Apex code and Lightning Components in a Sandbox environment.
They need to deploy the code and associated configurations to the Production environment.
What is the recommended process for deploying the code and configurations to Production?
  • A. Use a change set to deploy the Apex code and Lightning Components.
  • B. Use the Ant Migration Tool to deploy the Apex code and Lightning Components.
  • C. Use the Force.com IDE to deploy the Apex code and Lightning Components.
  • D. Use Salesforce CLI to deploy the Apex code and Lightning Components.
Salesforce CLI is a command-line interface that allows developers to create, test, and deploy code and configurations to any Salesforce environment1. Salesforce CLI is the recommended tool for deploying custom Apex code and Lightning Components, as it provides more flexibility, control, and automation than other deployment methods2. Salesforce CLI can also integrate with source control systems, such as Git, to enable version control and collaboration among developers3. Using a change set is another option to deploy code and configurations from one Salesforce org to another, but it has some limitations, such as requiring a deployment connection, not supporting all metadata types, and not allowing selective deployment of components4. Using the Force.com IDE or the Ant Migration Tool are also possible ways to deploy code and configurations, but they are less user-friendly and require more manual steps than Salesforce CLI5 . References:
* Salesforce CLI | Salesforce Developer Tools
* Deploy Your Code with Salesforce CLI | Salesforce Trailhead
* Manage Projects with Salesforce DX | Salesforce Trailhead
* Change Sets | Salesforce Trailhead
* Force.com IDE | Salesforce Developer Tools
* [Ant Migration Tool | Salesforce Developer Tools]
NEW QUESTION # 63
On a Visualforce page with a custom controller, how should a developer retrieve a record by using an ID that is passed on the URL?
  • A. Use the $Action.View method in the Visualforce page.
  • B. Use the tag in the Visualforce page.
  • C. Use the constructor method for the controller.
  • D. Create a new PageReference object with the Id.
NEW QUESTION # 64
What is a valid Apex statement?
  • A. Integer w, x, y = 123, z = 'abc',
  • B. Private static constant Double rate = 775;
  • C. Map conMap = (SELECT Name FROM Contact);
  • D. Account[] acctList = new List{new Account()}
NEW QUESTION # 65
Universal Containers (UC) wants to lower its shipping cost while making the shipping process more efficient. The Distribution Officer advises UC to implement global addresses to allow multiple Accounts to share a default pickup address. The developer is tasked to create the supporting object and relationship for this business requirement and uses the Setup Menu to create a custom object called "Global Address".
Which field should the developer add to create the most efficient model that supports the business need?
  • A. Add a master-detail field on the Global Address object to the Account object.
  • B. Add a lookup field on the Account object to the Global Address object.
  • C. Add 2 master-detail field on the Account object to the Global Address object.
  • D. Add a lookup field on the Global Address object to the Account object.
Scenario:
Universal Containers (UC) wants to allow multiple Accounts to share a default pickup address.
They have created a custom object called Global Address.
Requirement:
Create an efficient model to link multiple Accounts to a single Global Address.
Solution:
To associate multiple Accounts with a single Global Address, we need to create a lookup relationship from Account to Global Address.
Option D: Add a lookup field on the Account object to the Global Address object.
Correct Approach.
Adding a Lookup Field on the Account object that references the Global Address object allows multiple Accounts to reference the same Global Address.
This setup models a many-to-one relationship:
Many Accounts can have the same Global Address as their pickup address.
Benefits:
Data Normalization: Reduces data redundancy by storing the address once.
Ease of Maintenance: Updating the Global Address updates it for all associated Accounts.
An object cannot have two master-detail relationships to the same object.
Master-detail relationships imply ownership and cascade deletion, which may not be appropriate.
Does not address the requirement efficiently.
Option B: Add a master-detail field on the Global Address object to the Account object.
Incorrect Relationship Direction.
This would imply that each Global Address is owned by a single Account.
Does not allow multiple Accounts to share the same Global Address.
The master-detail relationship would be from Global Address to Account, which is opposite of what's needed.
Option C: Add a lookup field on the Global Address object to the Account object.
This creates a relationship where each Global Address references a single Account.
Does not support multiple Accounts sharing the same Global Address.
Would create a one-to-one relationship.
Conclusion:
Adding a Lookup Field on the Account object pointing to the Global Address object (Option D) creates a many-to-one relationship.
This efficiently models the business need where multiple Accounts can share a default pickup address.
Lookup Relationships
Creating Relationships Among Objects
Why Other Options are Not Suitable:
Option A: Add 2 master-detail fields on the Account object to the Global Address object.
Incorrect.
NEW QUESTION # 66
CRT-450 Test Prep: https://www.pass4sures.top/Salesforce-Developers/CRT-450-testking-braindumps.html
