Updated Cisco 300-610 Exam Questions in PDF Format for Quick Preparation
78
Posted at 1/10/2026 17:39:36      View141 | Replies1        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of PrepAwayPDF 300-610 dumps for free: https://drive.google.com/open?id=1zEeubJUv2KD5w3mTZjPylYXizHuI847Z
Practice tests (desktop and web-based) are simulations of actual Cisco 300-610 PDF Questions designed to help individuals prepare and improve their performance for the Cisco 300-610 certification test. PrepAwayPDF facilitates the customers with customizable practice tests which means they can adjust the number of questions and set the time of the test according to themselves which will help them in order to feel the real-based exam pressure and control it.
300-610 exam practice is well known for its quality service! Our users are all over the world, and we use uniform service standards everywhere. Our after-sales service staff will be on-line service 24 hours a day, 7 days a week. So, whether you are purchasing 300-610 Training Materials, or during the study period, no matter what kind of problems you encounter on the 300-610 study guide, you can always contact online customer service to get the timely help.
300-610 Test Questions Pdf | 300-610 Dumps FreePeople who get 300-610 certification show dedication and willingness to work hard, also can get more opportunities in job hunting. It seems that 300-610 certification becomes one important certification for many IT candidates. While a good study material will do great help in 300-610 Exam Preparation. PrepAwayPDF 300-610 will solve your problem and bring light for you. 300-610 exam questions and answers are the best valid with high hit rate, which is the best learning guide for your Cisco 300-610 preparation.
Cisco Designing Cisco Data Center Infrastructure Sample Questions (Q45-Q50):NEW QUESTION # 45
A midsize corporation with significant data-storage requirements is planning to deploy RFC 3720- based technology in its data center to provide efficient and reliable block-level storage access to servers. The corporation requires a robust solution with optimal performance, load-balancing, and fault tolerance. The solution must use multiple network paths to optimize bandwidth usage and provide redundancy. LACP has already been enabled on the data-center switches. Which two actions must be taken to accomplish the goal? (Choose two.)
  • A. Implement MPIO with redundant network paths.
  • B. Implement VLAN tagging in accordance with the IEEE 802.1Q standard to segregate iSCSI traffic from other data-center traffic.
  • C. Disable jumbo frames on the data center switches.
  • D. Configure the iSCSI initiators and targets to use a single network path.
  • E. Configure iSCSI MPIO software on the hosts.
Answer: B,E
Enabling MPIO on each server ensures that the host OS can use multiple active iSCSI sessions in parallel, aggregating bandwidth across NICs and automatically failing over if one path drops.
Isolating iSCSI frames on their own VLAN prevents congestion from other workloads, improves security, and simplifies QoS policies - without this, even multi-path links can suffer from "noisy neighbor" issues.
NEW QUESTION # 46
After experiencing traffic disruptions from the failure of a single router, a customer asks an engineer to design a solution that will prevent this from occurring in the future. While examining the customer's environment, the engineer discovers that the routers are manufactured by a variety of different vendors, and they have varying amounts of CPU and memory resources. Additionally, several of the customer's applications require the ability to fine-tune the load-balancing parameters between multiple gateway routers.
Which solution should be used to meet these requirements?
  • A. VRRP
  • B. GLBP
  • C. FHRP
  • D. HSRP
NEW QUESTION # 47
An engineer must design a Cisco HyperFlex solution to support a virtualized environment in a single data center location. The design must consider these customer requirements:
- a large-scale cluster with eight or more nodes
- distributed high-performance file system for virtualized servers
- high fault tolerance to multiple node failures
Which action meets these objectives?
  • A. Configure data destaging and deduplication.
  • B. Enable logical availability zones.
  • C. Create multiple datastores for storage of VM.
  • D. Implement a replication factor of four.
Logical Availability Zones are created to avoid multiple node and component failures on large clusters, and to increase cluster resiliency. Logical Availability Zones can only be enabled with clusters that are 8 converged nodes or larger.
NEW QUESTION # 48
Which two naming formats identify target or initiator iSCSI nodes? (Choose two.)
  • A. WWN
  • B. WWPN
  • C. OUI
  • D. EUI
  • E. IQN
Answer: A,E
Section: Storage Network Design
Explanation/Reference: https://www.cisco.com/en/US/docs ... _3_x/configuration/ guides/cli_3_3_1/ciscsi.html
NEW QUESTION # 49
A customer must install a new Hyperflex Stretched cluster in two sites. Low latency and predictable high performance are the top priorities for this setup due to the extensive usage of data-intensive applications across the cluster.
Which HyperFlex storage solution is recommended to meet these requirements?
  • A. All-SAN
  • B. All-Flash
  • C. All-HDD
  • D. Hybrid
NEW QUESTION # 50
PrepAwayPDF offers web-based 300-610 practice exams and desktop Designing Cisco Data Center Infrastructure (300-610) practice test software so that our customers can give unlimited Cisco 300-610 practice tests and make themselves perfect by tracking their mistakes. The progress of previously given Designing Cisco Data Center Infrastructure (300-610) practice tests are saved in the history so that the customers can assess it and avoid mistakes in future exams and pass Designing Cisco Data Center Infrastructure (300-610) certification exam easily.
300-610 Test Questions Pdf: https://www.prepawaypdf.com/Cisco/300-610-practice-exam-dumps.html
Cisco 300-610 Exam Sims We will give the refund to your payment account, Cisco 300-610 Exam Sims And the newest practice material is free for you within one year from the date of your order on, You will be full of fighting will after you begin to practice on our 300-610 Test Questions Pdf - Designing Cisco Data Center Infrastructure training pdf, Cisco 300-610 Exam Sims The pdf version is convenient for you to make notes.
Although Apple's feedback service reports failed deliveries i.e, 300-610 In this lesson, you learn how to use the Node Editor for compositing, We will give the refund to your payment account.
And the newest practice material is free for you within one year New 300-610 Braindumps Questions from the date of your order on, You will be full of fighting will after you begin to practice on our Designing Cisco Data Center Infrastructure training pdf.
Pass Guaranteed Cisco - High Hit-Rate 300-610 - Designing Cisco Data Center Infrastructure Exam SimsThe pdf version is convenient for you to make notes, You only need to practice on our 300-610 Exam Torrent for no more than thirty hours.
P.S. Free & New 300-610 dumps are available on Google Drive shared by PrepAwayPDF: https://drive.google.com/open?id=1zEeubJUv2KD5w3mTZjPylYXizHuI847Z
Posted at 1/22/2026 20:44:06        Only Author  2#
Clicking like on this amazing content! Free Valid examcollection NCP-CN to help you level up your IT skills. Best of luck!
