[General] Prominent Features of CompTIA CAS-005 Practice Test Questions
58
General Prominent Features of CompTIA CAS-005 Practice Test Questions
Posted at 1/10/2026 08:39:02      View198 | Replies3        Print      Only Author   [Copy Link] 1#
2026 Latest PracticeDump CAS-005 PDF Dumps and CAS-005 Exam Engine Free Share: https://drive.google.com/open?id=12ts5JUxR844ubNVCMeKxNJ4sc3xeyb63
If you cannot complete the task efficiently, we really recommend using CAS-005 learning materials. Through the assessment of your specific situation, we will provide you with a reasonable schedule, and provide the extensible version of CAS-005 exam training guide you can quickly grasp more knowledge in a shorter time. In the same time, you will do more than the people around you. This is what you can do with CAS-005 Test Guide. Our CAS-005 learning guide is for you to improve your efficiency and complete the tasks with a higher quality.
Our Desktop version is an application software that runs without an internet connection. It helps you to test yourself by giving the CompTIA SecurityX Certification Exam (CAS-005) practice test. Our desktop version also keeps a record of your previous performance and it shows the improvement in your next CAS-005 Practice Exam. With the help of PracticeDump CompTIA SecurityX Certification Exam (CAS-005) exam questions, you will be able to pass the CompTIA CAS-005 certification exam with ease. When you invest in our product it will surely benefit your CompTIA SecurityX Certification Exam (CAS-005) exam dumps.
New CompTIA CAS-005 Test Preparation | CAS-005 Latest Dumps BookPracticeDump is a learning website which provides CAS-005 latest dumps and answers, and almost covers every knowledge of CAS-005 exam questions. Using our learning textbooks to prepare CAS-005 test is your best choice. PracticeDump with latest CAS-005 exam simulations will help you Pass CAS-005 Exam in a short time in a fast way. We promise that we will refund fully if the CAS-005 vce dumps and training materials have any problems or you fail the CAS-005 exam with our CAS-005 braindumps.
CompTIA CAS-005 Exam Syllabus Topics:
  • Governance, Risk, and Compliance: This section of the exam measures the skills of CompTIA security architects that cover the implementation of governance components based on organizational security requirements, including developing policies, procedures, and standards. Candidates will learn about managing security programs, including awareness training on phishing and social engineering.
  • Security Architecture: This domain focuses on analyzing requirements to design resilient systems, including the configuration of firewalls and intrusion detection systems.
  • Security Operations: This domain is designed for CompTIA security architects and covers analyzing data to support monitoring and response activities, as well as assessing vulnerabilities and recommending solutions to reduce attack surfaces. Candidates will apply threat-hunting techniques and utilize threat intelligence concepts to enhance operational security.
  • Security Engineering: This section measures the skills of CompTIA security architects that involve troubleshooting common issues related to identity and access management (IAM) components within an enterprise environment. Candidates will analyze requirements to enhance endpoint and server security while implementing hardware security technologies. This domain also emphasizes the importance of advanced cryptographic concepts in securing systems.
CompTIA SecurityX Certification Exam Sample Questions (Q37-Q42):NEW QUESTION # 37
A security administrator is reviewing the following code snippet from a website component:
A review of the inc.tmp file shows the following:
Which of the following is most likely the reason for inaccuracies?
  • A. The WAF is configured to be in transparent mode.
  • B. The relevant stylesheet has become corrupted.
  • C. A search engine's bots are being blocked at the firewall.
  • D. A content management solution plug-in has been exploited.
The code indicates that a WordPress (CMS) plug-in has likely been exploited. The function get_hex_cache() combines obfuscated PHP code (hex2bin) with external file retrieval (inc.tmp). This is characteristic of malicious plug-in injections in content management systems such as WordPress, where attackers inject backdoors or malicious scripts through vulnerable plug-ins.
Option B (search engine bots blocked) and C (corrupted stylesheet) would not explain injected PHP logic. Option D (WAF in transparent mode) reduces security controls but does not create malicious functions inside the CMS code.
The presence of obfuscated data in inc.tmp strongly suggests tampering. Exploited CMS plug-ins are a common initial access vector, often used to hide persistent malware or web shells.
This aligns with CAS-005 objectives on secure coding, monitoring for tampering, and conducting regular code reviews of third-party dependencies.
NEW QUESTION # 38
A security engineer must resolve a vulnerability in a deprecated version of Python for a custom-developed flight simulation application that is monitored and controlled remotely. The source code is proprietary and built with Python functions running on the Ubuntu operating system. Version control is not enabled for the application in development or production. However, the application must remain online in the production environment using built-in features. Which of the following solutions best reduces the attack surface of these issues and meets the outlined requirements?
  • A. Configure code-signing within the CI/CD pipeline, update Python with aptitude, and update modules with pip in a test environment. Deploy the solution to production.
  • B. Enable branch protection in the GitHub repository. Update Python with aptitude, and update modules with pip in a test environment. Deploy the solution to production.
  • C. Use an NFS network share. Update Python with aptitude, and update modules with pip in a test environment. Deploy the solution to production.
  • D. Configure version designation within the Python interpreter. Update Python with aptitude, and update modules with pip in a test environment. Deploy the solution to production.
Code-signing within the CI/CD pipeline ensures that only verified and signed code is deployed, mitigating the risk of supply chain attacks. Updating Python with aptitude and updating modules with pip ensures vulnerabilities are patched. Deploying the solution to production after testing maintains application availability while securing the development lifecycle.
Branch protection (B) applies only to version-controlled environments, which is not the case here.
NFS network share (C) does not address the deprecated Python vulnerability.
Version designation (D) does not eliminate security risks from outdated dependencies.
NEW QUESTION # 39
An analyst reviews a SIEM and generates the following report:
Only HOST002 is authorized for internet traffic. Which of the following statements is accurate?
  • A. The VM002 host is misconfigured and needs to be revised by the network team.
  • B. The network connection activity is unusual, and a network infection is highly possible.
  • C. The SIEM platform is reporting multiple false positives on the alerts.
  • D. The HOST002 host is under attack, and a security incident should be declared.
Comprehensive and Detailed
Understanding the Security Event:
HOST002 is the only device authorized for internet traffic. However, the SIEM logs show that VM002 is making network connections to web.corp.local.
This indicates unauthorized access, which could be a sign of lateral movement or network infection.
This is a red flag for potential malware, unauthorized software, or a compromised host.
Why Option D is Correct:
Unusual network traffic patterns are often an indicator of a compromised system.
VM002 should not be communicating externally, but it is.
This suggests a possible breach or malware infection attempting to communicate with a command-and-control (C2) server.
A (Misconfiguration): While a misconfiguration could explain the unauthorized connections, the pattern of activity suggests something more malicious.
B (Security incident on HOST002): The issue is not with HOST002. The suspicious activity is from VM002.
C (False positives): The repeated pattern of unauthorized connections makes false positives unlikely.
CompTIA SecurityX CAS-005 Official Study Guide: Chapter on SIEM & Incident Analysis MITRE ATT&CK Tactics: Lateral Movement & Network-based Attacks
NEW QUESTION # 40
A security analyst wants to use lessons learned from a poor incident response to reduce dwell lime in the future The analyst is using the following data points
Which of the following would the analyst most likely recommend?
  • A. utilizing allow lists on the WAF for all users using GFT methods
  • B. Allowing TRACE method traffic to enable better log correlation
  • C. Enabling alerting on all suspicious administrator behavior
  • D. Adjusting the SIEM to alert on attempts to visit phishing sites
In the context of improving incident response and reducing dwell time, the security analyst needs to focus on proactive measures that can quickly detect and alert on potential security breaches. Here's a detailed analysis of the options provided:
A: Adjusting the SIEM to alert on attempts to visit phishing sites: While this is a useful measure to prevent phishing attacks, it primarily addresses external threats and doesn't directly impact dwell time reduction, which focuses on the time a threat remains undetected within a network.
B: Allowing TRACE method traffic to enable better log correlation: The TRACE method in HTTP is used for debugging purposes, but enabling it can introduce security vulnerabilities. It's not typically recommended for enhancing security monitoring or incident response.
C: Enabling alerting on all suspicious administrator behavior: This option directly targets the potential misuse of administrator accounts, which are often high-value targets for attackers. By monitoring and alerting on suspicious activities from admin accounts, the organization can quickly identify and respond to potential breaches, thereby reducing dwell time significantly. Suspicious behavior could include unusual login times, access to sensitive data not usually accessed by the admin, or any deviation from normal behavior patterns.
This proactive monitoring is crucial for quick detection and response, aligning well with best practices in incident response.
D: Utilizing allow lists on the WAF for all users using GET methods: This measure is aimed at restricting access based on allowed lists, which can be effective in preventing unauthorized access but doesn't specifically address the need for quick detection and response to internal threats.
NEW QUESTION # 41
A security architect is implementing more restrictive policies to improve secure coding practices.
Which of the following solutions are the best ways to improve the security coding practices?
(Choose two.)
  • A. Define security gates and tests along the CI/CD flow with strict exception rules.
  • B. Deliver regular training for the software developers based on best practices.
  • C. Perform regular code reviews and implement pair programming methodology.
  • D. Perform regular vulnerability assessments on production software, defining tight SLAs for treatment.
  • E. Implement a SAST tool along the pipeline for every new commit.
  • F. Hire a third-party company to perform regular software tests, including quality and unity tests.
Answer: B,E
NEW QUESTION # 42
PracticeDump's CompTIA CAS-005 exam training materials are the necessities of each of candidates who participating in the IT certification. With this training material, you can do a full exam preparation. So that you will have the confidence to win the exam. PracticeDump's CompTIA CAS-005 Exam Training materials are highly targeted. Not every training materials on the Internet have such high quality. Only PracticeDump could be so perfect.
New CAS-005 Test Preparation: https://www.practicedump.com/CAS-005_actualtests.html
P.S. Free 2026 CompTIA CAS-005 dumps are available on Google Drive shared by PracticeDump: https://drive.google.com/open?id=12ts5JUxR844ubNVCMeKxNJ4sc3xeyb63
Posted at 1/11/2026 14:34:55        Only Author  2#
The article is absolutely magnificent, thank you for sharing it with us. Hope I perform well in the Exam dumps C_S4CCO_2506 provider exam C wish me luck!
Posted at 1/12/2026 12:57:53        Only Author  3#
That article made a lasting impact on me. Latest CITM learning material offers outstanding content, all for free.
Posted at 1/24/2026 17:11:02        Only Author  4#
I deeply appreciate your article, it was truly memorable. You can enjoy the Latest test AD0-E136 simulations content for free, and its of high quality.
