[General] New EDGE-Expert Dumps & EDGE-Expert Actual Test Pdf
86
【General】 New EDGE-Expert Dumps & EDGE-Expert Actual Test Pdf
Posted at 1/29/2026 19:15:03      View:161 | Replies:1        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest Itcertmaster EDGE-Expert PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1SVio9Zl6tJJkqh-AFcHgB476GdBpg37s
In order to meet the different need from our customers, the experts and professors from our company designed three different versions of our EDGE-Expert exam questions for our customers to choose, including the PDF version, the online version and the software version. Though the content of the EDGE-Expert Study Materials is the same, but the displays are totally different to make sure that our customers can study our EDGE-Expert learning guide at any time and condition.
Dear every IT candidate, please pay attention to EDGE EDGE-Expert exam training torrent which can guarantee you 100% pass. We know that time and energy is very precious. So the high efficiency of the EDGE-Expert preparation is very important for the IT candidates. If you choose EDGE-Expert Online Test, you just need to take 20-30 hours to review the questions and answers, then you can attend your EDGE-Expert actual test with confidence.
EDGE-Expert Actual Test Pdf - Reliable EDGE-Expert Test DumpsThe product Itcertmaster provide with you is compiled by professionals elaborately and boosts varied versions which aimed to help you pass the EDGE-Expert exam by the method which is convenient for you. It is not only cheaper than other dumps but also more effective. The high pass rate of our EDGE-Expert Study Materials has been approved by thousands of candidates, they recognized our website as only study tool to pass EDGE-Expert exam.
EDGE Excellence in Design for Greater Efficiencies (EDGE Expert) Exam Sample Questions (Q23-Q28):NEW QUESTION # 23
For a project in a hot and dry climate with no air-conditioning system, which of the following will NOT have an impact on the occupants' thermal comfort?
  • A. Wall and roof insulation
  • B. Solar shading
  • C. Ceiling fans
  • D. Solar photovoltaics
In a hot and dry climate without air-conditioning, thermal comfort relies on passive design strategies that reduce heat gain or improve air movement. The EDGE User Guide discusses passive measures for thermal comfort: "In hot climates without air-conditioning, thermal comfort can be improved through ceiling fans, which enhance air movement, solar shading, which reduces solar heat gain, and wall and roof insulation, which minimizes heat transfer into the building" (EDGE User Guide, Section 3.5: Passive Design Strategies).
Option A (ceiling fans) improves air movement, directly impacting thermal comfort: "Ceiling fans increase air speed, enhancing evaporative cooling on occupants' skin" (EDGE Methodology Report Version 2.0, Section
5.5: Thermal Comfort Measures). Option B (solar shading) reduces heat gain, improving comfort: "External shading reduces solar radiation entering the building, lowering indoor temperatures" (EDGE User Guide, Section 3.5: Passive Design Strategies). Option C (wall and roof insulation) also enhances comfort by reducing heat transfer: "Insulation lowers the U-value of the building envelope, maintaining cooler indoor temperatures" (EDGE User Guide, Section 4.1: Insulation Measures). Option D (solar photovoltaics) generates electricity but does not directly affect thermal comfort in a building without air-conditioning: "Solar photovoltaics contribute to energy supply but do not directly influence indoor thermal comfort unless used to power cooling systems, which are absent in this scenario" (EDGE Methodology Report Version 2.0, Section
5.3: Energy Measures). Thus, solar photovoltaics (Option D) will not impact thermal comfort in this context.
Reference:EDGE User Guide Version 2.1, Section 3.5: Passive Design Strategies, Section 4.1: Insulation Measures; EDGE Methodology Report Version 2.0, Section 5.5: Thermal Comfort Measures, Section 5.3:
Energy Measures.
NEW QUESTION # 24
Which of the following wall solar reflectivity indexes would be the most energy efficient in a hot climate?
  • A. 0.4
  • B. 0.2
  • C. 0.3
  • D. 0.7
In hot climates, reducing heat gain through building envelopes is a key strategy for energy efficiency, as emphasized in EDGE's green building design principles. The EDGE User Guide discusses solar reflectivity (measured by the Solar Reflectance Index, SRI) for walls and roofs, stating: "Higher SRI values indicate greater reflectivity, which reduces heat absorption and lowers cooling energy demand in hot climates. For walls in hot climates, an SRI of 0.7 or higher is recommended to maximize energy savings" (EDGE User Guide, Section 3.5: Passive Design Strategies). The options provided are 0.2, 0.3, 0.4, and 0.7. Since 0.7 is the highest SRI value among the choices, it reflects the most solar radiation, thereby reducing the cooling load andimproving energy efficiency in a hot climate, as per EDGE's guidance. Options A, B, and C have lower SRI values and would result in greater heat absorption, increasing energy use for cooling.
Reference:EDGE User Guide Version 2.1, Section 3.5: Passive Design Strategies.
NEW QUESTION # 25
What is the minimum percentage of efficient lightbulbs that must be installed to claim the measure EEM22 - Efficient Lighting for Internal Areas?
  • A. 100%
  • B. 90%
  • C. 70%
  • D. 80%
The EDGE measure EEM22 - Efficient Lighting for Internal Areas focuses on reducing energy consumption through the use of efficient lighting. The EDGE User Guide specifies the requirements for this measure: "To claim EEM22 - Efficient Lighting for Internal Areas, at least 90% of the lamps in internal areas must be energy-efficient, such as LED or CFL, with a luminous efficacy of at least 80 lumens per watt. This threshold ensures significant energy savings while allowing for minimal exceptions in specific areas" (EDGE User Guide, Section 4.4: Lighting Efficiency Measures). Option C, 90%, directly matches this requirement. Option A (70%) and Option B (80%) are below the threshold, thus not qualifying for the measure. Option D (100%) exceeds the minimum requirement, but EDGE allows for flexibility with a 90% threshold to accommodate practical constraints: "A 90% requirement balances practicality with energy savings, recognizing that some areas may require specialized lighting" (EDGE Methodology Report Version 2.0, Section 5.4: Lighting Calculations). Therefore, the minimum percentage to claim EEM22 is 90% (Option C).
Reference:EDGE User Guide Version 2.1, Section 4.4: Lighting Efficiency Measures; EDGE Methodology Report Version 2.0, Section 5.4: Lighting Calculations.
NEW QUESTION # 26
Which of the following is NOT an option for insulation in materials efficiency measures?
  • A. Polypropylene
  • B. Polyurethane
  • C. Mineral wool
  • D. Polystyrene
Insulation materials in EDGE are evaluated for their thermal performance and embodied energy as part of materials efficiency measures. The EDGE User Guide lists common insulation options: "In EDGE, insulation materials for walls, roofs, and floors include mineral wool, polyurethane,polystyrene, and fiberglass, which are selected for their low thermal conductivity and availability in most markets" (EDGE User Guide, Section
7.2: Materials Efficiency Measures). Options A (mineral wool), B (polyurethane), and D (polystyrene) are explicitly mentioned as insulation materials in EDGE. Option C, polypropylene, is not listed as an insulation material, as confirmed by the EDGE Methodology Report: "Polypropylene is a plastic material often used in packaging or pipes, but it is not recognized in EDGE as an insulation material due to its poor thermal resistance compared to standard insulation options like polystyrene or polyurethane" (EDGE Methodology Report Version 2.0, Section 6.1: Embodied Energy in Materials). The EDGE software's material database further excludes polypropylene from insulation options, focusing instead on materials with established thermal properties for building envelopes. Thus, polypropylene (Option C) is not an insulation option in EDGE.
Reference:EDGE User Guide Version 2.1, Section 7.2: Materials Efficiency Measures; EDGE Methodology Report Version 2.0, Section 6.1: Embodied Energy in Materials.
NEW QUESTION # 27
In the EDGE software, what is the unit of the embodied carbon of the material?
  • A. kWh
  • B. kgCO2
  • C. BTU
  • D. MJ
Embodied carbon in EDGE refers to the carbon emissions associated with the production, transportation, and installation of building materials, a key metric for materials efficiency. The EDGE User Guide specifies how this is measured: "In the EDGE software, the embodied carbon of materials is quantified in kilograms of carbon dioxide equivalent (kgCO2), reflecting the total greenhouse gas emissions associated with the material' s lifecycle, from extraction to installation"(EDGE User Guide, Section 7.2: Materials Efficiency Measures).
Option A, kgCO2, directly matches this unit, as EDGE uses kgCO2 to standardize carbon emissions across materials, allowing for comparison and aggregation in the software's results. Option B (MJ) is incorrect, as MJ (megajoules) measures embodied energy, not carbon: "Embodied energy in EDGE is measured in MJ, representing the energy consumed in material production, while embodied carbon is separately calculated in kgCO2 to assess environmental impact" (EDGE Methodology Report Version 2.0, Section 6.1: Embodied Energy in Materials). Option C (BTU) is also incorrect, as BTU (British Thermal Units) is an energy unit not used in EDGE for carbon calculations: "EDGE uses metric units like MJ for energy and kgCO2 for carbon; BTU is not a standard unit in the software" (EDGE User Guide, Section 2.3: Using the EDGE App). Option D (kWh) is another energy unit, typically used for operational energy, not embodied carbon: "kWh is used in EDGE to measure operational energy consumption, such as electricity use, but not for embodied carbon, which is always in kgCO2" (EDGE Methodology Report Version 2.0, Section 5.2: Energy Calculation Methods). The EDGE User Guide further clarifies: "The software displays embodied carbon in kgCO2 to align with global carbon accounting standards, enabling users to understand the environmental footprint of their material choices" (EDGE User Guide, Section 7.2: Materials Efficiency Measures). The EDGE Methodology Report adds: "For example, concrete might have an embodied carbon of 0.15 kgCO2 per kg, allowing users to compare materials like fly ash concrete versus standard concrete in terms of carbon impact" (EDGE Methodology Report Version 2.0, Section 6.1: Embodied Energy in Materials). Thus, the unit of embodied carbon in EDGE is kgCO2 (Option A).
Reference:EDGE User Guide Version 2.1, Section 7.2: Materials Efficiency Measures, Section 2.3: Using the EDGE App; EDGE Methodology Report Version 2.0, Section 6.1: Embodied Energy in Materials, Section
5.2: Energy Calculation Methods.
NEW QUESTION # 28
The name of these formats are Excellence in Design for Greater Efficiencies (EDGE Expert) Exam (EDGE-Expert) PDF dumps file, desktop practice test software, and web-based practice test software. All these three Excellence in Design for Greater Efficiencies (EDGE Expert) Exam (EDGE-Expert) practice test formats are easy to use and perfectly work with all devices, operating systems, and web browsers. The EDGE-Expert PDF dumps file is a simple collection of Real and Updated EDGE-Expert Exam Questions in PDF format and it is easy to install and use. Just install the Excellence in Design for Greater Efficiencies (EDGE Expert) Exam (EDGE-Expert) PDF dumps file on your desktop computer, laptop, tab, or even on your smartphone and start Excellence in Design for Greater Efficiencies (EDGE Expert) Exam (EDGE-Expert) exam preparation anytime and anywhere.
EDGE-Expert Actual Test Pdf: https://www.itcertmaster.com/EDGE-Expert.html
This is the most important aspect of our EDGE-Expert valid questions test, If you want to pass EDGE-Expert exam, here come our EDGE-Expert exam prep giving you a helping hand, We provide excellent technical tracking customer service for every buyer purchasing EDGE EDGE-Expert actual test dumps, EDGE New EDGE-Expert Dumps So how can you obtain a smoothly and quickly, Our high-quality EDGE-Expert practice test & exam preparation materials guarantee you pass exam 100% for sure if you pay close attention to our EDGE-Expert study materials.
So, what's the big change, This is the greatest website that can give smart and reliable help for the exam, This is the most important aspect of our EDGE-Expert valid questions test.
If you want to pass EDGE-Expert exam, here come our EDGE-Expert exam prep giving you a helping hand, We provide excellent technical tracking customer service for every buyer purchasing EDGE EDGE-Expert actual test dumps.
EDGE EDGE-Expert Exam dumps [2026]So how can you obtain a smoothly and quickly, Our high-quality EDGE-Expert practice test & exam preparation materials guarantee you pass exam 100% for sure if you pay close attention to our EDGE-Expert study materials.
2026 Latest Itcertmaster EDGE-Expert PDF Dumps and EDGE-Expert Exam Engine Free Share: https://drive.google.com/open?id=1SVio9Zl6tJJkqh-AFcHgB476GdBpg37s
Posted at 2/21/2026 15:05:44        Only Author  2#
Thank you for your brilliant article, it truly left me in awe! I’m about to take the SC-400 valid test topics exam. Wishing for a great result!
