[General] Exam CT-AI Pass Guide & Reliable CT-AI Test Syllabus
99
【General】 Exam CT-AI Pass Guide & Reliable CT-AI Test Syllabus
Posted at 2/12/2026 10:35:21      View:100 | Replies:0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest Real4dumps CT-AI PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1jdQ4YvE4EUlhzf_iNJ1BRTsAnePtqkPs
The industry experts hired by CT-AI study materials explain all the difficult-to-understand professional vocabularies easily. All the languages used in CT-AI real exam were very simple and easy to understand. With our CT-AI study guide, you don't have to worry about that you don't understand the content of professional books. You also don't need to spend expensive tuition to go to tutoring class. CT-AI Practice Engine can help you solve all the problems in your study.
ISTQB CT-AI Exam Syllabus Topics:
  • ML Functional Performance Metrics: In this section, the topics covered include how to calculate the ML functional performance metrics from a given set of confusion matrices.
  • Testing AI-Based Systems Overview: In this section, focus is given to how system specifications for AI-based systems can create challenges in testing and explain automation bias and how this affects testing.
  • Testing AI-Specific Quality Characteristics: In this section, the topics covered are about the challenges in testing created by the self-learning of AI-based systems.
  • Neural Networks and Testing: This section of the exam covers defining the structure and function of a neural network including a DNN and the different coverage measures for neural networks.
Topic 5
  • ML: Data: This section of the exam covers explaining the activities and challenges related to data preparation. It also covers how to test datasets create an ML model and recognize how poor data quality can cause problems with the resultant ML model.
Topic 6
  • Methods and Techniques for the Testing of AI-Based Systems: In this section, the focus is on explaining how the testing of ML systems can help prevent adversarial attacks and data poisoning.
Free PDF Quiz ISTQB - Efficient Exam CT-AI Pass GuideAre you tired of feeling overwhelmed and unsure about how to prepare for the CT-AI exam? Are you ready to take control of your future and get the Certified Tester AI Testing Exam (CT-AI) certification you need to accelerate your career? If so, it's time to visit Real4dumps and download real ISTQB CT-AI Exam Dumps. Our team of experts has designed a CT-AI Exam study material that has already helped thousands of students just like you achieve their goals. We offer a comprehensive Certified Tester AI Testing Exam (CT-AI) practice exam material that is according to the content of the CT-AI test.
ISTQB Certified Tester AI Testing Exam Sample Questions (Q119-Q124):NEW QUESTION # 119
Which of the following characteristics of AI-based systems make it more difficult to ensure they are safe?
  • A. Sustainability
  • B. Non-determinism
  • C. Robustness
  • D. Simplicity
AI-based systems oftenexhibit non-deterministic behavior, meaning theydo not always produce the same output for the same input. This makesensuring safety more difficult, as the system's behavior can change based on new data, environmental factors, or updates.
* Why Non-determinism Affects Safety:
* In traditional software, the same input always produces the same output.
* In AI systems, outputsvary probabilisticallydepending on learned patterns and weights.
* This unpredictability makes itharder to verify correctness, reliability, and safety, especially in critical domains likeautonomous vehicles, medical AI, and industrial automation.
* A (Simplicity):AI-based systems are typicallycomplex, not simple, which contributes to safety challenges.
* B (Sustainability):While sustainability is an important AI consideration, it doesnot directly affect safety.
* D (Robustness)ack of robustnesscan make AI systems unsafe, butnon-determinism is the primary issuethat complicates safety verification.
* ISTQB CT-AI Syllabus (Section 2.8: Safety and AI)
* "The characteristics of AI-based systems that make it more difficult to ensure they are safe include: complexity, non-determinism, probabilistic nature, self-learning, lack of transparency, interpretability and explainability, lack of robustness".
Why Other Options Are Incorrect:Supporting References from ISTQB Certified Tester AI Testing Study Guide:Conclusion:Sincenon-determinism makes AI behavior unpredictable, complicating safety assurance, thecorrect answer is C.
NEW QUESTION # 120
Which of the following is a problem with AI-generated test cases that are generated from the requirements?
  • A. They are usually missing the expected results, so verification is difficult or must resort to only detecting significant failures
  • B. They are defect-prone because they are unable to detect nuances in the requirements
  • C. They make debugging more complicated because the number of steps is usually high in order to induce the target failure
  • D. They are slow and will usually not be able to execute in the time allowed
The syllabus mentions a drawback of AI-generated test cases:
"AI-based test generation tools can generate test cases... However, unless a test model that defines required behaviors is used as the basis of the tests, this form of test generation generally suffers from a test oracle problem because the AI-based tool does not know what the expected results should be." (Reference: ISTQB CT-AI Syllabus v1.0, Section 11.3, page 78 of 99)
NEW QUESTION # 121
Which of the following aspects is a challenge when handling test data for an AI-based system?
  • A. Data frameworks or machine learning frameworks
  • B. Output data or intermediate data
  • C. Personal data or confidential data
  • D. Video frame speed or aspect ratio
The syllabus explicitly mentions challenges of handling personal data and ensuring privacy when testing AI- based systems:
"The management of personal data and sensitive data is often a concern during testing, as testing typically requires realistic data and it is difficult to fully anonymize data." (Reference: ISTQB CT-AI Syllabus v1.0, Section 7.3, page 52 of 99)
NEW QUESTION # 122
Which of the following neural network coverage criteria can be adapted for its application?
Choose ONE option (1 out of 4)
  • A. Threshold coverage
  • B. Neuron coverage
  • C. Sign-Change coverage
  • D. Sign-Sign coverage
Section4.2 - Test Coverage Criteria for AI Modelsof the ISTQB CT-AI syllabus describes neural network- specific coverage methods. Among the techniques,threshold coverageis explicitly noted asadaptable, meaning testers may choose different thresholds to determine whether neuron activation is considered
"covered." This flexibility makes threshold coverage adjustable to the model architecture, problem domain, and required test thoroughness.
Options A and B (Sign-Sign and Sign-Change coverage) are more rigid structural criteria and are not described as adaptable within the syllabus. They focus on sign patterns of neuron activations and do not allow altering thresholds. Option D, neuron coverage, measures the proportion of neurons activated at least once.
Although simple, it is not defined as an adaptable criterion. Its limitations are documented: it provides shallow insight and too easily achieves high coverage.
Onlythreshold coverageallows testers to adjust activation thresholds for more refined coverage measurement, makingOption Cthe correct choice.
NEW QUESTION # 123
"BioSearch" is creating an Al model used for predicting cancer occurrence via examining X-Ray images. The accuracy of the model in isolation has been found to be good. However, the users of the model started complaining of the poor quality of results, especially inability to detect real cancer cases, when put to practice in the diagnosis lab, leading to stopping of the usage of the model.
A testing expert was called in to find the deficiencies in the test planning which led to the above scenario.
Which ONE of the following options would you expect to MOST likely be the reason to be discovered by the test expert?
SELECT ONE OPTION
  • A. A lack of similarity between the training and testing data.
  • B. A lack of focus on choosing the right functional-performance metrics.
  • C. The input data has not been tested for quality prior to use for testing.
  • D. A lack of focus on non-functional requirements testing.
The question asks which deficiency is most likely to be discovered by the test expert given the scenario of poor real-world performance despite good isolated accuracy.
* A lack of similarity between the training and testing data (A): This is a common issue in ML where the model performs well on training data but poorly on real-world data due to a lack of representativeness in the training data. This leads to poor generalization to new, unseen data.
* The input data has not been tested for quality prior to use for testing (B): While data quality is important, this option is less likely to be the primary reason for the described issue compared to the representativeness of training data.
* A lack of focus on choosing the right functional-performance metrics (C): Proper metrics are crucial, but the issue described seems more related to the data mismatch rather than metric selection.
* A lack of focus on non-functional requirements testing (D): Non-functional requirements are important, but the scenario specifically mentions issues with detecting real cancer cases, pointing more towards data issues.
ISTQB CT-AI Syllabus Section 4.2 on Training, Validation, and Test Datasets emphasizes the importance of using representative datasets to ensure the model generalizes well to real-world data.
Sample Exam Questions document, Question #40 addresses issues related to data representativeness and model generalization.
NEW QUESTION # 124
ISTQB CT-AI certification exam is a very difficult test. Even if the exam is very hard, many people still choose to sign up for the exam. As to the cause, CT-AI exam is a very important test. For IT staff, not having got the certificate has a bad effect on their job. ISTQB CT-AI certificate will bring you many good helps and also help you get promoted. In a word, this is a test that will bring great influence on your career. Such important exam, you also want to attend the exam.
Reliable CT-AI Test Syllabus: https://www.real4dumps.com/CT-AI_examcollection.html
P.S. Free 2026 ISTQB CT-AI dumps are available on Google Drive shared by Real4dumps: https://drive.google.com/open?id=1jdQ4YvE4EUlhzf_iNJ1BRTsAnePtqkPs
