[General] New Mule-Dev-301 Exam Test - Test Mule-Dev-301 Valid
33
General New Mule-Dev-301 Exam Test - Test Mule-Dev-301 Valid
Posted at 3/11/2026 09:27:20      View197 | Replies0        Print      Only Author   [Copy Link] 1#
Therefore, make the most of this opportunity of getting these superb exam questions for the Salesforce Certified MuleSoft Developer II certification exam. We guarantee you that our top-rated Salesforce Mule-Dev-301 Practice Exam (PDF, desktop practice test software, and web-based practice exam) will enable you to pass the Mule-Dev-301 certification exam on the very first go.
It is known to us that the 21st century is an information era of rapid development. Now the people who have the opportunity to gain the newest information, who can top win profit maximization. In a similar way, people who want to pass Mule-Dev-301 exam also need to have a good command of the newest information about the coming exam. However, it is not easy for a lot of people to learn more about the information about the study materials. Luckily, the Mule-Dev-301 Study Materials from our company will help all people to have a good command of the newest information.
Test Salesforce Mule-Dev-301 Valid, Mule-Dev-301 Exam PrepThe Mule-Dev-301 vce braindumps of our TestkingPass contain questions and correct answers and detailed answer explanations and analysis, which apply to any level of candidates. Our IT experts has studied Salesforce real exam for long time and created professional study guide. So you will pass the test with high rate If you practice the Mule-Dev-301 Dumps latest seriously and skillfully.
Salesforce Certified MuleSoft Developer II Sample Questions (Q53-Q58):NEW QUESTION # 53
A Mule application pom.xml configures the Maven Resources plugin to exclude parsing binary files in the project's src/main/resources/certs directory.
Which configuration of this plugin achieves a successful build?
  • A.
  • B.
  • C.
  • D.
To configure the Maven Resources plugin to exclude parsing binary files in the project's src/main/resources/certs directory, option C should be used. This option specifies that any files with .cer or .jks extensions under the certs directory should be excluded from filtering. Filtering is a process of replacing placeholders with actual values in resource files during the build process. Binary files should not be filtered because they may become corrupted or unusable. Reference: https://maven.apache.org/plugins ... xamples/filter.html https://maven.apache.org/plugins ... nclude-exclude.html
NEW QUESTION # 54
When implementing a synchronous API where the event source is an HTTP Listener, a developer needs to return the same correlation ID back to the caller in the HTTP response header.
How can this be achieved?
  • A. NO action is needed as the correlation ID is returned to the caller in the response header by default
  • B. Enable the auto-generate CorrelationID option when scaffolding the flow
  • C. Configure a custom correlation policy
  • D. Enable the CorrelationID checkbox in the HTTP Listener configuration
When implementing a synchronous API where the event source is an HTTP Listener, Mule automatically propagates some message attributes between flows via outbound and inbound properties. One of these attributes is correlation ID, which is returned to the caller in the response header by default as MULE_CORRELATION_ID. Reference: https://docs.mulesoft.com/mule-r ... #message-attributes
NEW QUESTION # 55
A developer is working on a project that requires encrypting all data before sending it to a backend application. To accomplish this, the developer will use PGP encryption in the Mule 4 Cryptography module.
What is required to encrypt the data before sending it to the backend application?
  • A. The application needs to both the private and public keys to encrypt the data
  • B. The application needs the public key from the backend service to encrypt the data
  • C. The application needs the private key from the backend service to encrypt the data
  • D. The application needs to configure HTTPS TLS context information to encrypt the data
To encrypt the data before sending it to the backend application using PGP encryption, the application needs the public key from the backend service. PGP encryption uses a public-key cryptography system, which means that each party has a pair of keys: a public key and a private key. The public key is used to encrypt data, and the private key is used to decrypt data. Therefore, to encrypt data for a specific recipient (the backend service), the application needs to use the recipient's public key. The recipient can then use its own private key to decrypt the data. Reference: https://docs.mulesoft.com/mule-runtime/4.3/cryptography-pgp
NEW QUESTION # 56
Multiple individual Mute application need to use the Mule Maven plugin to deploy to CloudHub.
The plugin configuration should .. reused where necessary and anything project, specific should be property-based.
Where should the Mule Maven details be configured?
  • A. A Bill of Materials (BOM) parent pm
  • B. A parent pom.xml
  • C. Settings, xml
  • D. Pom, xml
To reuse Mule Maven plugin configuration across multiple individual Mule applications, the developer should use a parent pom.xml file. A parent pom.xml file defines common configuration for one or more child projects that inherit from it. The developer can specify common properties and dependencies for all child projects in the parent pom.xml file, such as Mule Maven plugin configuration, and then reference them in each child project's pom.xml file using placeholders. Reference: https://docs.mulesoft.com/mule-runtime/4.3/mmp-concept#parent-pom https://maven.apache.org/guides/ ... Project_Inheritance
NEW QUESTION # 57
A healthcare portal needs to validate the token that it sends to a Mule API. The developer plans to implement a custom policy using the HTTP Policy Transform Extension to match the token received in the header from the heathcare portal.
Which files does the developer need to create in order to package the custom policy?
  • A. Deployable ZIP file, YAML configuration file
  • B. XML template file, YAML configuration file
  • C. JSON properties file, XML template file
  • D. JSON properties file, YAML configuration file
To package a custom policy using the HTTP Policy Transform Extension, the developer needs to create an XML template file and a YAML configuration file. The XML template file defines the policy logic using Mule components and placeholders for user-defined properties. The YAML configuration file defines the metadata of the policy, such as its name, description, category, parameters, and dependencies. Reference: https://docs.mulesoft.com/api-ma ... ackaging-the-policy
NEW QUESTION # 58
If you are the first time to take part in the exam. We strongly advise you to buy our Mule-Dev-301 training materials. One of the most advantages is that our Mule-Dev-301 study braindumps are simulating the real exam environment. Many candidates usually feel nervous in the real exam. If you purchase our Mule-Dev-301 Guide questions, you do not need to worry about making mistakes when you take the real exam. In addition, you have plenty of time to practice on our Mule-Dev-301 exam prep.
Test Mule-Dev-301 Valid: https://www.testkingpass.com/Mule-Dev-301-testking-dumps.html
You will enjoy some discounts to buy our Mule-Dev-301 real questions on large holidays, Salesforce Test Mule-Dev-301 Valid projects are everywhere in the world, and the business and software solutions they provide are accepted by almost all companies, TestkingPass Test Mule-Dev-301 Valid Salesforce Test Mule-Dev-301 Valid exam PDF is easy to be print out and very suitable for candidates who prefers study offline while exam VCE is better for online study, Our Mule-Dev-301 test questions and dumps can help you solve this problem.
By analyzing routing updates from all other routers, a Mule-Dev-301 router can build a detailed picture of network topology, A good developer today tests his or her own code.
You will enjoy some discounts to buy our Mule-Dev-301 Real Questions on large holidays, Salesforce projects are everywhere in the world, and the business and software solutions they provide are accepted by almost all companies.
New Mule-Dev-301 Exam Test 100% Pass | Latest Mule-Dev-301: Salesforce Certified MuleSoft Developer II 100% PassTestkingPass Salesforce exam PDF is easy to be print out and very suitable for candidates who prefers study offline while exam VCE is better for online study, Our Mule-Dev-301 test questions and dumps can help you solve this problem.
What the Mule-Dev-301 certification bring may be a highlighting in your resume, sometimes may be a higher position with considerable salary, in a word, extraordinary benefits for you and your family.
