[General] NCA-GENL学習教材、NCA-GENL関連資料
100
【General】 NCA-GENL学習教材、NCA-GENL関連資料
Posted at 1/31/2026 20:45:20      View:111 | Replies:0        Print      Only Author   [Copy Link] 1#
ちなみに、Xhs1991 NCA-GENLの一部をクラウドストレージからダウンロードできます:https://drive.google.com/open?id=1h6CoO4_112SgPnwNiRh83-S0BBWFfmS0
より多くの時間を節約できるように、お支払い後10分以内にNCA-GENLテストガイドをオンラインでお送りします。時間の無駄を避けるため、できるだけ早くこれらのNCA-GENLトレーニング資料を学習できることを保証いたします。私たちNVIDIAは、時間は世界で最も貴重なものだと信じています。これが、NVIDIA Generative AI LLMs学習効率と生産性の向上に専念する理由です。 NCA-GENL調査の質問の利点をいくつかご紹介します。NCA-GENLの質問をご覧ください。
NVIDIA NCA-GENL 認定試験の出題範囲:
トピック出題範囲
トピック 1
  • Experimentation: This section of the exam measures the skills of ML Engineers and covers how to conduct structured experiments with LLMs. It involves setting up test cases, tracking performance metrics, and making informed decisions based on experimental outcomes.:
トピック 2
  • Alignment: This section of the exam measures the skills of AI Policy Engineers and covers techniques to align LLM outputs with human intentions and values. It includes safety mechanisms, ethical safeguards, and tuning strategies to reduce harmful, biased, or inaccurate results from models.
トピック 3
  • Python Libraries for LLMs: This section of the exam measures skills of LLM Developers and covers using Python tools and frameworks like Hugging Face Transformers, LangChain, and PyTorch to build, fine-tune, and deploy large language models. It focuses on practical implementation and ecosystem familiarity.
トピック 4
  • LLM Integration and Deployment: This section of the exam measures skills of AI Platform Engineers and covers connecting LLMs with applications or services through APIs, and deploying them securely and efficiently at scale. It also includes considerations for latency, cost, monitoring, and updates in production environments.
トピック 5
  • Experiment Design
トピック 6
  • This section of the exam measures skills of AI Product Developers and covers how to strategically plan experiments that validate hypotheses, compare model variations, or test model responses. It focuses on structure, controls, and variables in experimentation.
トピック 7
  • Fundamentals of Machine Learning and Neural Networks: This section of the exam measures the skills of AI Researchers and covers the foundational principles behind machine learning and neural networks, focusing on how these concepts underpin the development of large language models (LLMs). It ensures the learner understands the basic structure and learning mechanisms involved in training generative AI systems.
トピック 8
  • Data Preprocessing and Feature Engineering: This section of the exam measures the skills of Data Engineers and covers preparing raw data into usable formats for model training or fine-tuning. It includes cleaning, normalizing, tokenizing, and feature extraction methods essential to building robust LLM pipelines.
トピック 9
  • Data Analysis and Visualization: This section of the exam measures the skills of Data Scientists and covers interpreting, cleaning, and presenting data through visual storytelling. It emphasizes how to use visualization to extract insights and evaluate model behavior, performance, or training data patterns.
NCA-GENL関連資料、NCA-GENL問題例NCA-GENL資格は重要な認証科目です。人数は少なくて需要は大きいため、この認証を持っている人は給料が一番高い人になっています。NCA-GENL試験に合格したら、あなたの知識と能力を証明することができます。あなたはそれらの専門家の一員になれたら、あなたはいい仕事を探せます。我々のNCA-GENL問題集を利用して、試験に参加しましょう。
NVIDIA Generative AI LLMs 認定 NCA-GENL 試験問題 (Q50-Q55):質問 # 50
When designing an experiment to compare the performance of two LLMs on a question-answering task, which statistical test is most appropriate to determine if the difference in their accuracy is significant, assuming the data follows a normal distribution?
  • A. Chi-squared test
  • B. Mann-Whitney U test
  • C. Paired t-test
  • D. ANOVA test
The paired t-test is the most appropriate statistical test to compare the performance (e.g., accuracy) of two large language models (LLMs) on the same question-answering dataset, assuming the data follows a normal distribution. This test evaluates whether the mean difference in paired observations (e.g., accuracy on each question) is statistically significant. NVIDIA's documentation on model evaluation in NeMo suggests using paired statistical tests for comparing model performance on identical datasets to account for correlated errors.
Option A (Chi-squared test) is for categorical data, not continuous metrics like accuracy. Option C (Mann- Whitney U test) is non-parametric and used for non-normal data. Option D (ANOVA) is for comparing more than two groups, not two models.
NVIDIA NeMo Documentation: https://docs.nvidia.com/deeplear ... /docs/en/stable/nlp
/model_finetuning.html
質問 # 51
What is 'chunking' in Retrieval-Augmented Generation (RAG)?
  • A. A concept in RAG that refers to the training of large language models.
  • B. A method used in RAG to generate random text.
  • C. Rewrite blocks of text to fill a context window.
  • D. A technique used in RAG to split text into meaningful segments.
Chunking in Retrieval-Augmented Generation (RAG) refers to the process of splitting large text documents into smaller, meaningful segments (or chunks) to facilitate efficient retrieval and processing by the LLM.
According to NVIDIA's documentation on RAG workflows (e.g., in NeMo and Triton), chunking ensures that retrieved text fits within the model's context window and is relevant to the query, improving the quality of generated responses. For example, a long document might be divided into paragraphs or sentences to allow the retrieval component to select only the most pertinent chunks. Option A is incorrect because chunking does not involve rewriting text. Option B is wrong, as chunking is not about generating random text. Option C is unrelated, as chunking is not a training process.
/intro.html
Lewis, P., et al. (2020). "Retrieval-Augmented Generation for Knowledge-Intensive NLP Tasks."
質問 # 52
What is the main difference between forward diffusion and reverse diffusion in diffusion models of Generative AI?
  • A. Forward diffusion uses feed-forward networks, while reverse diffusion uses recurrent networks.
  • B. Forward diffusion focuses on generating a sample from a given noise vector, while reverse diffusion reverses the process by estimating the latent space representation of a given sample.
  • C. Forward diffusion uses bottom-up processing, while reverse diffusion uses top-down processing to generate samples from noise vectors.
  • D. Forward diffusion focuses on progressively injecting noise into data, while reverse diffusion focuses on generating new samples from the given noise vectors.
Diffusion models, a class of generative AI models, operate in two phases: forward diffusion and reverse diffusion. According to NVIDIA's documentation on generative AI (e.g., in the context of NVIDIA's work on generative models), forward diffusion progressively injects noise into a data sample (e.g., an image or text embedding) over multiple steps, transforming it into a noise distribution. Reverse diffusion, conversely, starts with a noise vector and iteratively denoises it to generate a new sample that resembles the training data distribution. This process is central tomodels like DDPM (Denoising Diffusion Probabilistic Models). Option A is incorrect, as forward diffusion adds noise, not generates samples. Option B is false, as diffusion models typically use convolutional or transformer-based architectures, not recurrent networks. Option C is misleading, as diffusion does not align with bottom-up/top-down processing paradigms.
NVIDIA Generative AI Documentation: https://www.nvidia.com/en-us/ai-data-science/generative-ai/ Ho, J., et al. (2020). "Denoising Diffusion Probabilistic Models."
質問 # 53
In the context of developing an AI application using NVIDIA's NGC containers, how does the use of containerized environments enhance the reproducibility of LLM training and deployment workflows?
  • A. Containers automatically optimize the model's hyperparameters for better performance.
  • B. Containers encapsulate dependencies and configurations, ensuring consistent execution across systems.
  • C. Containers reduce the model's memory footprint by compressing the neural network.
  • D. Containers enable direct access to GPU hardware without driver installation.
NVIDIA's NGC (NVIDIA GPU Cloud) containers provide pre-configured environments for AI workloads, enhancing reproducibility by encapsulating dependencies, libraries, and configurations. According to NVIDIA's NGC documentation, containers ensure that LLM training and deployment workflows run consistently across different systems (e.g., local workstations, cloud, or clusters) by isolating the environment from host system variations. This is critical for maintaining consistent results in research and production.
Option A is incorrect, as containers do not optimize hyperparameters. Option C is false, as containers do not compress models. Option D is misleading, as GPU drivers are still required on the host system.
NVIDIA NGC Documentation: https://docs.nvidia.com/ngc/ngc-overview/index.html
質問 # 54
What is the Open Neural Network Exchange (ONNX) format used for?
  • A. Sharing neural network literature
  • B. Compressing deep learning models
  • C. Representing deep learning models
  • D. Reducing training time of neural networks
The Open Neural Network Exchange (ONNX) format is an open-standard representation for deep learning models, enabling interoperability across different frameworks, as highlighted in NVIDIA's Generative AI and LLMs course. ONNX allows models trained in frameworks like PyTorch or TensorFlow to be exported and used in other compatible tools for inference or further development, ensuring portability and flexibility.
Option B is incorrect, as ONNX is not designed to reduce training time but to standardize model representation. Option C is wrong, as model compression is handled by techniques like quantization, not ONNX. Option D is inaccurate, as ONNX is unrelated to sharing literature. The course states: "ONNX is an open format for representing deep learning models, enabling seamless model exchange and deployment across various frameworks and platforms." References: NVIDIA Building Transformer-Based Natural Language Processing Applications course; NVIDIA Introduction to Transformer-Based Natural Language Processing.
質問 # 55
NCA-GENL試験のダンプでは、鮮明な例と正確なチャートを追加して、直面する可能性のある例外的なケースを刺激します。 NCA-GENLガイドTorrentは、試験資料の世界有数のプロバイダーの1つとして知られています。 NCA-GENLテストの質問は、さらなるパートナーシップのために1年半の価格で無料で更新されます。
NCA-GENL関連資料: https://www.xhs1991.com/NCA-GENL.html
さらに、Xhs1991 NCA-GENLダンプの一部が現在無料で提供されています:https://drive.google.com/open?id=1h6CoO4_112SgPnwNiRh83-S0BBWFfmS0
