[Linux] How to setting mipi pll setting on RK3399
49
【Linux】 How to setting mipi pll setting on RK3399
Posted at 6/15/2018 08:24:14      View:8841 | Replies:9        Print      Only Author   [Copy Link] 1#
The current situation works normally under 800Mbps.
I want to know PLL Programming
REFCLK = 27 MHz case (Over 800Mbps Under 1Gbps)
I found 419 page in Rockchip RK3399TRM V1.3 Part2.pdf file
But Cases are under 800 Mbps
And I changed mipi_dphy_cfg() in cif_isp10_rk3399.c
If set to over 800Mbps , an interrupt error occurs.
Under 800Mbps not generated.
[   12.884399] cif_isp10_mipi_isr(6550) ERR: mipi_mis icr err: 0x300000
[   12.884985] cif_isp10_mipi_isr(6550) ERR: mipi_mis icr err: 0x3
[   12.885532] cif_isp10_mipi_isr(6550) ERR: mipi_mis icr err: 0x300000
[   12.886120] cif_isp10_mipi_isr(6550) ERR: mipi_mis icr err: 0x500003
[   12.886703] cif_isp10_mipi_isr(6550) ERR: mipi_mis icr err: 0x3
[   12.887254] cif_isp10_mipi_isr(6550) ERR: mipi_mis icr err: 0x300003
[   12.887835] cif_isp10_mipi_isr(6550) ERR: mipi_mis icr err: 0x3
[   12.888387] cif_isp10_mipi_isr(6550) ERR: mipi_mis icr err: 0x500003
[   12.888968] cif_isp10_mipi_isr(6550) ERR: mipi_mis icr err: 0x300000
Thanks & regard
Posted at 6/25/2018 16:41:01        Only Author  2#
I waiting your response
Is it possible to set 800Mbps per mipi line?
Posted at 7/1/2018 21:51:26        Only Author  3#
if you want to do PLL Programming @REFCLK=27HMZ(Over 800Mbps Under 1Gbps),please to do the sequence as belowed:
1、hsfreqrange[5:0] = desired value, the value you can find in  Frequency Ranges table in RK3399TRM V1.3;
2、Make N and M factors configuration effective:test code 0x19 = 0x30;
3、PLL Input Divider Ratio (N) programmed: test code 0x17 = desired value,
     the value range is :800-899(Mbps)= 2;900-999(Mbps)= 1;
4、PLL Loop Divider Ratio (M) programmed:test code 0x18 = desired value,lsb first,the msb,
     the value range is(dec) :800-849 Mbps = 93,850-899 Mbps = 99; 900 -949 Mbps = 69; 950-999 Mbps = 73;
5、VCO Control (vcorange and vcocap) programmed: test code 0x10 = desired value;
      VCO range is :
      vcorange[2:0]   800-899Mbps =100, 900-999Mbps = 101
      vcocap[1:0] always be set as 0x0;
6、PLL Control (icpctrl) programmed: test code 0x11= desired value
      icpctrl[3:0] : 800-899 Mbps = 0110 , 900-999 Mbps = 1011
7、PLL Control (lpfctrl) programmed and allow 0x11 to be effective:test code  0x12 = 0xc | desired value,
       value =lpfctrl[5:0] :800-899 Mbps = 000100,900-999 Mbps = 010000
      best of luck !
Posted at 7/2/2018 13:31:02        Only Author  4#
Dear tannyhjl
I have tried the above settings but I still get an interrupt error
Please confirm that the modified code is correct.
My target setting is 891Mhz
I modified file and function
                /* set clock lane */
                mipi_dphy1_wr_reg(isp_cfg, 0x34, 0x00);
                mipi_dphy1_wr_reg(isp_cfg, 0x44, hsfreqrange);//0x39<<1
/////////////////////This is your setting. I modified /////////////////////////////////////////
               mipi_dphy1_wr_reg(isp_cfg, 0x19, 0x30);
               mipi_dphy1_wr_reg(isp_cfg, 0x17, 0x01);
               mipi_dphy1_wr_reg(isp_cfg, 0x18, 0x02);
               mipi_dphy1_wr_reg(isp_cfg, 0x18, 0x83);
               mipi_dphy1_wr_reg(isp_cfg, 0x10, 0x80 | 0x01 | (0x4 << 3));
               mipi_dphy1_wr_reg(isp_cfg, 0x11, 0x06);
               mipi_dphy1_wr_reg(isp_cfg, 0x12, (0xC0|0x4));
                mipi_dphy1_wr_reg(isp_cfg, 0x54, 0);
                mipi_dphy1_wr_reg(isp_cfg, 0x84, 0);
                mipi_dphy1_wr_reg(isp_cfg, 0x94, 0);
                mipi_dphy1_wr_reg(isp_cfg, 0x75, 0x04);
                mipi_dphy1_rd_reg(isp_cfg, 0x0);
Thanks & regard !
Posted at 7/6/2018 09:57:26        Only Author  5#
Hello elect123, you can have a  try as belowed:
                /* HS hsfreqrange & lane 0  settle bypass */
                mipi_dphy0_wr_reg(isp_cfg, 0x44, hsfreqrange);
                mipi_dphy0_wr_reg(isp_cfg, 0x54, 0);
                mipi_dphy0_wr_reg(isp_cfg, 0x84, 0);
                mipi_dphy0_wr_reg(isp_cfg, 0x94, 0);
                mipi_dphy0_wr_reg(isp_cfg, 0x75, 0x04);
                mipi_dphy0_rd_reg(isp_cfg, 0x75);
                /* Make N and M factors configuration effective */
                /* PLL Input Divider Ratio (N) programmed */
                mipi_dphy1_wr_reg(isp_cfg, 0x17, 0x02);
                /* PLL Loop Divider Ratio (M) programmed */
                mipi_dphy1_wr_reg(isp_cfg, 0x18, 0x03); //lsb
        mipi_dphy1_wr_reg(isp_cfg, 0x18, 0x83); //msb
                 * VCO Control (vcorange and vcocap) programmed
                 * VCO range= 3'b100
                 * Vcocap = 2'b00
                mipi_dphy1_wr_reg(isp_cfg, 0x10, 0xA1);
                /* PLL Control (icpctrl) programmed */
                /* PLL Control (lpfctrl) programmed and allow 0x11 to be effective */
       good luck for you!
Posted at 7/9/2018 09:11:59        Only Author  6#
Dear tannyhjl
Do you have any other check points?
Thanks & regard !
Posted at 1/11/2026 17:46:31        Only Author  7#
Um keine Reue und Bedauern in Ihrem Leben zu hinterlassen, sollen Sie jede Gelegenheit ergreifen, um das Leben zu vebessern. Haben Sie das gemacht? Die Fragenkataloge zur VMware 3V0-32.23 Zertifizierungsprüfung von Fast2test helfen den IT-Fachleuten, die Erfolg erzielen wollen, die VMware 3V0-32.23 Zertifizierungsprüfung zu bestehen. Um den Erfolg nicht zu verpassen, machen Sie doch schnell.
Posted at 1/11/2026 20:26:41        Only Author  8#
This article is a true inspiration, thank you for sharing it! Almost time to face the Valid C_CPE_2409 cram materials exam. Wish me good luck!
Posted at 2/7/2026 18:45:47        Only Author  9#
Thank you for sharing this thought-provoking article! Improve your IT expertise with free CFE-Financial-Transactions-and-Fraud-Schemes test tutorial. Best of luck in your exam journey!
Posted at 3/7/2026 03:16:58        Only Author  10#
The article is truly moving, thank you for sharing! Please wish me luck as I face the ITIL reliable exam cram exam!
