[General] Valid Salesforce Exam Integration-Architect Torrent & Professional TestValid
32
General Valid Salesforce Exam Integration-Architect Torrent & Professional TestValid
Posted at 4/20/2026 13:20:15      View151 | Replies0        Print      Only Author   [Copy Link] 1#
What's more, part of that TestValid Integration-Architect dumps now are free: https://drive.google.com/open?id=1w6ITVKj2_2FEjKdjFXgSsMMIsbAz7NLU
We have always taken care to provide our customers with the very best. So we provide numerous benefits along with our Salesforce Certified Integration Architect exam study material. We provide our customers with the demo version of the Salesforce Integration-Architect Exam Questions to eradicate any doubts that may be in your mind regarding the validity and accuracy. You can test the product before you buy it.
Salesforce Integration-Architect is a certification exam that assesses the candidate's expertise in integrating Salesforce with other systems. Integration-Architect exam is designed to test the knowledge of the candidate in various areas like data integration, security, and system architecture. The Salesforce Integration-Architect certification is a must-have for professionals working in the field of Salesforce integration. Salesforce Certified Integration Architect certification is also beneficial for those who are looking to improve their skills in Salesforce integration as it helps them to gain recognition as an expert in the field.
Integration-Architect Valid Real Test - Integration-Architect VCE DumpsIntegration-Architect is an Salesforce certification exam, so Integration-Architect is the first step to set foot on the road of Salesforce certification. Integration-Architect certification exam become more and more fiery and more and more people participate in Integration-Architect Exam, but passing rate of Integration-Architect certification exam is not very high.When you select Integration-Architect exam, do you want to choose an exam training courses?
Salesforce is a leading CRM platform that is widely used by businesses of all sizes to manage their customer relationships. As companies increasingly rely on Salesforce to manage their sales, marketing, and customer service operations, the need for skilled professionals who can integrate Salesforce with other systems has grown significantly. The Salesforce Integration-Architect (Salesforce Certified Integration Architect) Certification Exam is designed to validate the skills and knowledge of professionals who specialize in integrating Salesforce with other systems.
Salesforce Certified Integration Architect Sample Questions (Q85-Q90):NEW QUESTION # 85
Northern Trail Outfitters needs to use Shield Platform Encryption to encrypt social security numbers in order to meet a business requirement. Which action should an integration architect take prior to the implementation of Shield Platform Encryption?
  • A. Encrypt all the data so that it is secure.
  • B. Review Shield Platform Encryption configurations and functional limitations.
  • C. Encrypt the data using the most current key.
Prior to implementing Shield Platform Encryption, the most critical step for an Integration Architect is to perform a comprehensive Review of Shield Platform Encryption configurations and their impact on existing platform functionality. Encryption at rest is not a "set-and-forget" feature; it changes how the Salesforce database interacts with various features, and failing to review these limitations beforehand can lead to significant business disruption.
Salesforce documentation emphasizes that encryption affects several core areas:
* SOQL/SOSL Limitations: Encrypted fields have restricted capabilities in WHERE, GROUP BY, and ORDER BY clauses.1 For example, if Social Security Numbers (SSNs) are encrypted using Probabilistic Encryption, they cannot be filtered or sorted in a query.2 This could break existing integrations or reports that rely on finding specific records by SSN.
* Search Functionality: While Salesforce supports searching for encrypted data, there are specific behaviors to consider regarding how search indexes are built and updated.
* AppExchange and Managed Packages: If the SSN field is used by a third-party app or a managed package, encrypting it might cause those external tools to fail if they are not designed to handle encrypted data types.
* Field Attributes: Encrypted fields cannot be used as Unique or External IDs if using the probabilistic scheme, which is a vital consideration for data synchronization architectures.3 Therefore, the architect must first conduct a Business Impact Analysis. This includes identifying where the sensitive data (SSNs) is used in Apex code, Flows, validation rules, and reports. By reviewing the configurations and functional limitations first, the architect can decide between Probabilistic (higher security) and Deterministic (allows filtering) encryption strategies.4 Option A is a step taken during or after implementation (Background Encryption), and Option C is an anti-pattern, as encrypting " everything" leads to unnecessary performance overhead and massive functional loss. Only after a thorough review can the architect safely proceed with the technical implementation of Shield.
NEW QUESTION # 86
Acustomer imports data from an external system into Salesforce using Bulk API. These jobs have batch sizes of 2000 and are run in parallel mode. The batch fails frequently with the error "Max CPU time exceeded". A smaller batch size will fix this error.
Which two options should be considered when using a smaller batch size?
Choose 2 answers
  • A. Smaller batch size may cause record-locking errors.
  • B. Smaller batch size may exceed theconcurrent API request limits.
  • C. Smaller batch size can trigger "Too many concurrent batches" error.
  • D. Smaller batch size may increase time required to execute bulk jobs.
Answer: A,D
The error "Max CPU time exceeded" occurs when a batch of records takes more than 10 minutes to process in the Bulk API. Using a smaller batch size can reduce the processing time and avoid this error. However, there are some trade-offs to consider when using a smaller batch size, such as:
Answer A is valid because a smaller batch size may cause record-locking errors if multiple batches try toupdate the same records or records that are related by a lookup or master-detail relationship. This can result in concurrency issues and data inconsistency1 Answer B is valid because a smaller batch size may increase the time required to executebulk jobs, as more batches need to be created and processed sequentially. This can affect the performance and efficiency of the integration1 Answer C is not valid because a smaller batch size may not exceed the concurrent API request limits, as the Bulk API does not count against the concurrent request limit. TheBulk API has its own limit on the number ofbatches that can be queued or in progress, which is 5,000 per rolling 24-hour period2 Answer D is not valid because a smaller batch size can trigger "Too many concurrent batches" error only if the number of batches exceeds the limit of 5,000 per rolling 24-hour period. Thiserror is not related to the parallel mode of the Bulk API, which allows up to 10 batches to be processed simultaneously
NEW QUESTION # 87
Northern Trail Outfitters needs a synchronous callout from Salesforce to an Order Management System (OMS) when an opportunity is "Closed/Won" with products attached. What should an integration architect do to satisfy these requirements?
  • A. Write a trigger that invokes an Apex proxy class to make a REST callout to the OMS.
  • B. Develop a batch Apex job that aggregates closed opportunities and makes a REST callout to the OMS hourly.
  • C. Build a Lightning component that makes a synchronous Apex REST callout to the OMS when a button is clicked.
To satisfy a requirement for a synchronous callout triggered by a user action, the architect should use a UI- driven approach, such as a Lightning component and a button.
In Salesforce, triggers (Option B) are primarily used for asynchronous logic in integration contexts. Because a trigger executes as part of the database save operation, making a synchronous callout directly from a trigger is prohibited as it would block the database transaction until the external system responds, leading to performance degradation and "uncommitted work pending" errors. If a trigger must initiate an integration, it must do so asynchronously (using @future or Queueable Apex), which violates the requirement for a synchronous call.
By using a Lightning component, the architect can initiate a synchronous Request-and-Reply pattern. When the sales rep clicks the "7Submit to OMS" button, the componen8t invokes an Apex method that makes the REST callout to the OMS in real-time. The user remains on the page while the system waits for the OMS to respond, allowing for immediate feedback-such as an order confirmation number or an error message-to be displayed in the UI. A Batch Apex job (Option C) is inherently asynchronous and delayed, making it unsuitable for a synchronous, real-time fulfillment requirement.
NEW QUESTION # 88
Northern Trail Outfitters (NTO) has recently changed its Corporate Security Guidelines requiring all cloud applications to pass through a secure firewall before accessing on-premise resources. NTO is evaluating middleware solutions. Which consideration should an integration architect evaluate before choosing a middleware solution?
  • A. The middleware solution is capable of establishing a secure API Gateway between cloud applications and on-premise resources.
  • B. The middleware solution is able to interface directly with databases via an Open Database Connectivity (ODBC) connection string.
  • C. The middleware solution enforces the OAuth security protocol.
When corporate guidelines mandate a firewall-protected entry point for cloud traffic, the middleware architecture must include a component capable of residing in a Demilitarized Zone (DMZ) or perimeter network. The architect must evaluate the solution's API Gateway capabilities.
A secure API Gateway acts as the intermediary that terminates external (cloud) TLS connections and inspects incoming traffic before proxying it to internal systems. It allows the security team to implement:
* IP Whitelisting: Ensuring only Salesforce's IP ranges can access the gateway.
* Mutual Authentication: Using certificates to verify that the request is genuinely coming from the Salesforce org.
* Rate Limiting: Protecting on-premise resources from being overwhelmed by cloud requests.
Option A (OAuth) is an authorization framework and does not satisfy the network-level firewall requirement on its own. Option B (ODBC) is an internal database protocol that should generally never be exposed to a cloud-facing firewall due to security risks. By prioritizing a solution with a hardened API Gateway, the architect ensures that NTO meets its new security mandates while providing a scalable and secure bridge for Salesforce to access back-office services.
NEW QUESTION # 89
A new Salesforce program has the following high-level abstract requirement: Business processes executed on Salesforce require data updates between their Internal systems and Salesforce.
Which relevant detail should an integration architect seek to specifically solve for integration architecture needs of the program?
  • A. Integration skills, SME availability, and Program Governance details
  • B. Core functional and non-functionalrequirements for User Experience design, Encryption needs, Community and license choices
  • C. Timing aspects, real-time/near real-time (synchronous or asynchronous), batch and update frequency
Timing aspects, real-time/near real-time (synchronous or asynchronous), batch and update frequency are relevant details that an integration architect should seek to specifically solve for integration architecture needs of the program. These details help to determine the appropriate integration pattern, technology, and solution for the business requirements. Core functional and non-functional requirements for User Experience design, Encryption needs, Community and license choices are important for the overall program design, but not specific to the integration architecture needs. Integration skills, SME availability, and Program Governance details are also important for the program execution, but not specific to the integration architectureneeds.
NEW QUESTION # 90
Integration-Architect Valid Real Test: https://www.testvalid.com/Integration-Architect-exam-collection.html
2026 Latest TestValid Integration-Architect PDF Dumps and Integration-Architect Exam Engine Free Share: https://drive.google.com/open?id=1w6ITVKj2_2FEjKdjFXgSsMMIsbAz7NLU
