[General] Best Accurate Salesforce-Certified-Administrator Review Guide by PremiumVCEDump
112
【General】 Best Accurate Salesforce-Certified-Administrator Review Guide by PremiumVCEDump
Posted at 2/12/2026 07:16:07      View:129 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Salesforce Salesforce-Certified-Administrator dumps are available on Google Drive shared by PremiumVCEDump: https://drive.google.com/open?id=1CuKcbdQZiSVGhr7PjeZsnFnjyVsj2LTv
For candidates who are going to buy the Salesforce-Certified-Administrator training materials online, they have the concern of the safety of the website. Our Salesforce-Certified-Administrator training materials will offer you a clean and safe online shopping environment, since we have professional technicians to examine the website and products at times. In addition, Salesforce-Certified-Administrator Training Materials have 98.75% pass rate, and you can pass the exam. We also pass guarantee and money back guarantee if you fail to pass the exam.
Earning a Salesforce Certified Administrator certification can provide individuals with a competitive edge in the job market and demonstrate their expertise in Salesforce Administration. Successful completion of Salesforce-Certified-Administrator Exam can also lead to new career opportunities, higher salaries, and the ability to take on more complex Salesforce projects.
Holding a Salesforce Certified Administrator certification can open up a wide range of career opportunities in the Salesforce ecosystem. It is recognized globally as a symbol of excellence and expertise in Salesforce administration. Certified administrators are highly sought after by organizations that use Salesforce, and the certification can lead to higher salaries, better job prospects, and more fulfilling careers.
Salesforce is a cloud-based software company that provides customer relationship management (CRM) solutions to businesses across industries. As a Salesforce Administrator, you are responsible for ensuring the successful implementation and maintenance of the Salesforce platform in your organization. The Salesforce Certified Administrator certification is designed to test your knowledge and skills in administering and configuring Salesforce.
Salesforce-Certified-Administrator Certification Training & Salesforce-Certified-Administrator Exam Dumps & Salesforce-Certified-Administrator Study GuideSalesforce Salesforce-Certified-Administrator practice test PremiumVCEDump is another great way to reduce your stress level when preparing for the Salesforce Exam Questions. With our PremiumVCEDump, you can practice your excellence and improve your competence on the Salesforce-Certified-Administrator exam dumps. Each Salesforce-Certified-Administrator practice exam, composed of numerous skills, can be measured by the same model used by real examiners. Salesforce Salesforce-Certified-Administrator has real Salesforce-Certified-Administrator exam questions. You can change the difficulty of these questions, which will help you determine what areas appertain to more study before taking your Salesforce-Certified-Administrator exam dumps.
Salesforce Certified Administrator Sample Questions (Q129-Q134):NEW QUESTION # 129
The sales team at Ursa Major Solar has asked the administrator to automate an outbound message.
What should the administrator utilize to satisfy the request?
  • A. Workflow rule
  • B. Process builder
  • C. Flow builder
  • D. Task assignment
NEW QUESTION # 130
Universal Containers wants to provide reseller partners with discounted prices on the products they purchase.
How should an administrator configure this requirement?
  • A. Create a separate PriceBook for reseller partners.
  • B. Add a Partner_Discount_c field to the Opportunity
  • C. Build separate reseller partner products.
  • D. Use a different Opportunity record type.
A PriceBook is a feature that allows administrators to define different prices for the same products based on different criteria such as customer segment, region, channel, etc. For example, a PriceBook can provide reseller partners with discounted prices on the products they purchase compared to regular customers. A PriceBook consists of one or more PriceBook entries that specify the product ID, pricebook ID, list price, currency, and active status for each product-pricebook combination.
References:https://help.salesforce.com/s/ar ... view.htm&type=5
NEW QUESTION # 131
The administrator at Cloud kicks deleted a custom field but realized there is a business unit that still uses the field.
What should an administrator take into consideration when undeleting the field?
  • A. The field needs to be re-added to reports.
  • B. The field needs to be restored from the recycle bin.
  • C. The field needs to be re-added to page Layouts.
  • D. The field history will remain deleted.
NEW QUESTION # 132
Universal Containers requires that when an Opportunity is closed won, all other open opportunities on the same account must be marked as closed lost.
Which automation solution should an administrator use to implement this request?
  • A. Outbound Message
  • B. Workflow Rule
  • C. Quick Action
  • D. Flow Builder
Flow Builder allows you to create an automated business process that can update records based on certain criteria. You can use a scheduled flow to run once a week and count the number of open cases related to an account.
References: https://help.salesforce.com/s/ar ... view.htm&type=5
https://help.salesforce.com/s/ar ... tart.htm&type=5
NEW QUESTION # 133
The administrator at Cloud Kicks has a Custom picklist field on Lead, Which is missing on the Contact when leads are converted.
Which two items should the administrator do to make sure these values are populated?
Choose 2 answers
  • A. Update the picklist value with a validation rule.
  • B. Create a custom picklist field on Contact.
  • C. Set the picklist field to be required on the Lead Object.
  • D. Map the picklist field on the Lead to the Contact.
NEW QUESTION # 134
Our customer service is available all day, and your problems can be solved efficiently at any time. Last but not least, we can guarantee the security of the purchase process of Salesforce-Certified-Administrator Test Questions and the absolute confidentiality of customer information. You do not have to worry about these issues, because we know that this is a basic condition for us to establish a good business model. If you have any questions, you can always contact us online or email us. We will reply as soon as possible.
Braindumps Salesforce-Certified-Administrator Downloads: https://www.premiumvcedump.com/Salesforce/valid-Salesforce-Certified-Administrator-premium-vce-exam-dumps.html
BTW, DOWNLOAD part of PremiumVCEDump Salesforce-Certified-Administrator dumps from Cloud Storage: https://drive.google.com/open?id=1CuKcbdQZiSVGhr7PjeZsnFnjyVsj2LTv
