[Hardware] AWS-Certified-Developer-Associate New Learning Materials - Test AWS-Certified-De
81
Hardware AWS-Certified-Developer-Associate New Learning Materials - Test AWS-Certified-De
Posted at 2/1/2026 23:21:15      View137 | Replies0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest TestSimulate AWS-Certified-Developer-Associate PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1_JDXj8cnQEEh-yx65D0LWw_DGEPIglH-
Maybe you have desired the AWS-Certified-Developer-Associate certification for a long time but don't have time or good methods to study. Maybe you always thought study was too boring for you. Our AWS-Certified-Developer-Associate study materials will change your mind. With our AWS-Certified-Developer-Associate exam questions, you will soon feel the happiness of study. Just look at the three different versions of our AWS-Certified-Developer-Associate learning quiz: the PDF, Software and APP online which can apply to study not only on the paper, but also can apply to study on IPAD, phone or laptop.
To be eligible for the AWS Certified Developer - Associate exam, candidates must have at least one year of experience in developing and maintaining applications on the AWS platform. They should also have a strong understanding of AWS services such as EC2, S3, DynamoDB, and Lambda. AWS-Certified-Developer-Associate Exam consists of multiple-choice questions and is delivered in a proctored setting.
Test AWS-Certified-Developer-Associate Testking, AWS-Certified-Developer-Associate Exam Topics PdfThe AWS Certified Developer Associate Exam (DVA-C02) AWS-Certified-Developer-Associate certification is a valuable credential earned by individuals to validate their skills and competence to perform certain job tasks. Your AWS Certified Developer Associate Exam (DVA-C02) AWS-Certified-Developer-Associate certification is usually displayed as proof that youve been trained, educated, and prepared to meet the specific requirement for your professional role. The AWS Certified Developer Associate Exam (DVA-C02) AWS-Certified-Developer-Associate Certification enables you to move ahead in your career later.
Amazon AWS Certified Developer Associate Exam (DVA-C02) Sample Questions (Q119-Q124):NEW QUESTION # 119
When developing an AWS Lambda function that processes Amazon Kinesis Data Streams, Administrators within the company must receive a notice that includes the processed data.
How should the Developer write the function to send processed data to the Administrators?
  • A. Publish the processed data to an Amazon SNS topic
  • B. Push the processed data to Amazon SQS
  • C. Use Amazon CloudWatch Events to send the processed data
  • D. Separate the Lambda handler from the core logic
https://stackoverflow.com/questi ... -sns-and-amazon-sqs
https://stackoverflow.com/questi ... using-an-aws-lambda
NEW QUESTION # 120
A company runs an e-commerce website that uses Amazon DynamoDB where pricing for items is dynamically updated in real time. At any given time, multiple updates may occur simultaneously for pricing information on a particular product. This is causing the original editor's changes to be overwritten without a proper review process.
Which DynamoDB write option should be selected to prevent this overwriting?
  • A. Batch writes
  • B. Concurrent writes
  • C. Atomic writes
  • D. Conditional writes
https://docs.aws.amazon.com/amaz ... s.ConditionalUpdate
NEW QUESTION # 121
A user is trying to create a policy for an IAM user from the AWS console. Which of the below mentioned options is not available to the user while configuring policy?
  • A. Assign No permission
  • B. Use policy simulator to create policy
  • C. Use custom policy to create policy
  • D. Use policy generator to create policy
When a user is trying to create a policy from the AWS console, it will have options such as create policy from templates or use a policy generator. The user can also define a custom policy or chose the option to have no permission. The policy simulator is not available in the console.
http://docs.aws.amazon.com/IAM/l ... MBestPractices.html
NEW QUESTION # 122
A developer is writing a serverless application that requires an AWS Lambda function to be invoked every 10 minutes.
What is an automated and serverless way to invoke the function?
  • A. Create an Amazon Simple Notification Service (Amazon SNS) topic that has a subscription to the Lambda function with a 600-second timer.
  • B. Create an Amazon EventBridge rule that runs on a regular schedule to invoke the Lambda function.
  • C. Deploy an Amazon EC2 instance based on Linux, and edit its /etc/confab file by adding a command to periodically invoke the lambda function
  • D. Configure an environment variable named PERIOD for the Lambda function. Set the value to 600.
The solution that will meet the requirements is to create an Amazon EventBridge rule that runs on a regular schedule to invoke the Lambda function. This way, the developer can use an automated and serverless way to invoke the function every 10 minutes. The developer can also use a cron expression or a rate expression to specify the schedule for the rule. The other options either involve using an Amazon EC2 instance, which is not serverless, or using environment variables or query parameters, which do not trigger the function.
Reference: Schedule AWS Lambda functions using EventBridge
NEW QUESTION # 123
In DynamoDB, if you create a table and request 10 units of write capacity and 200 units of read capacity of provisioned throughput, how much would you be charged in US East (Northern Virginia) Region?
  • A. $0.03 per hour
  • B. $0.15 per hour
  • C. $0.10 per hour
  • D. $0.05 per hour
To understand pricing in DynamoDB, consider the following example. If you create a table and request 10 units of write capacity and 200 units of read capacity of provisioned throughput, you would be charged:
$0.01 + (4 x $0.01) = $0.05 per hour
http://aws.amazon.com/dynamodb/pricing/
NEW QUESTION # 124
If you are occupied with your study or work and have little time to prepare for your exam, then you can choose us. AWS-Certified-Developer-Associate training materials are edited by skilled professional experts, and therefore they are high-quality. You just need to spend about 48 to 72 hours on study, you can pass the exam. We are pass guarantee and money back guarantee for AWS-Certified-Developer-Associate Exam Materials, if you fail to pass the exam, you just need to send us your failure scanned to us, we will give you full refund, and no other questions will be asked. Online and offline service is available, if you have any questions for AWS-Certified-Developer-Associate exam materials, dont hesitate to consult us.
Test AWS-Certified-Developer-Associate Testking: https://www.testsimulate.com/AWS-Certified-Developer-Associate-study-materials.html
P.S. Free 2026 Amazon AWS-Certified-Developer-Associate dumps are available on Google Drive shared by TestSimulate: https://drive.google.com/open?id=1_JDXj8cnQEEh-yx65D0LWw_DGEPIglH-
