New Topic
[Linux] how to make minimal Linux build for rk3568
154
Linux how to make minimal Linux build for rk3568
Posted at 4/13/2023 18:51:54      View7678 | Replies12        Print      Only Author   [Copy Link] 1#
  • SDK Package Name: rk356x_linux_release_v1.3.0b_20221213
  • Modification Content: LVDS configuration
  • Log: no log (2).zip
I have a custom board based on RK3568jq.I have downloded pre-made Linux minimal image AIO-3568J_Ubuntu20.04-Minimal-r240_v1.3.2b_230331.img
from this link:
https://drive.google.com/drive/folders/10PdMdmHaRxDPeEWIRqHLou4zUxcXRCQi
Then i wrote this firmware to RK3568jq SOM and everything works fine, Linux is loaded successfully.
I have only official document for Linux Desktop build:
https://wiki.t-firefly.com/en/iCore-3568JQ/linux_compile.html
But there is no steps described for minimal Linux OS build. And desktop Linux does not load on my custom board.
I have a question:
How can i make minimal Linux OS build for rk3568jq from the source code (SDK)  (not downloaded pre-made Linux minimal image)?
Thank you.
no log (2).zip
22 Bytes, Down times: 1
Posted at 4/14/2023 10:38:46        Only Author  2#
You can download minimal rootfs and pack firmware by yourself.
https://en.t-firefly.com/doc/download/150.html#other_379
Posted at 4/18/2023 14:17:59        Only Author  3#
fixed
i used Yocto build from this link and everything is ok:
https://wiki.t-firefly.com/en/Fi ... e/manual_yocto.html
Posted at 10/30/2024 19:08:34        Only Author  4#
It sounds like you've made some solid progress with the pre-built image, but I totally get why you'd want a minimal Linux build directly from the source for your RK3568JQ-based board. The official desktop Linux build guide is a good starting point, and you can adapt parts of that for the minimal setup. Heres how to go about it:
1. Set Up the Build Environment: Youll need to set up your host environment if you havent already (install dependencies like gcc, g++, make, etc.). Then, download the Firefly SDK source code for RK3568JQ.
2. Configure for Minimal Image: Start by using a minimal root filesystem, which is lighter on unnecessary services. You might look into busybox as it provides a stripped-down set of common commands for small footprint systems.
3. Modify the Build Script: If the SDK offers configuration files, search for a minimal configuration option (like core-image-minimal if youre using Yocto, or equivalent). Set that configuration in the .config or in the build script to avoid including the GUI or desktop elements.
4. Compile the Kernel and Root Filesystem: From the SDK, you should be able to compile the kernel and filesystem for your minimal setup. This usually involves commands like:
  1. make ARCH=arm CROSS_COMPILE=<your-cross-compiler> <defconfig>
  2. make ARCH=arm CROSS_COMPILE=<your-cross-compiler> -j4
Copy the code
5. Transfer and Test: Once the image is built, flash it to your board as you did with the pre-made image and test boot. If you encounter boot issues, try monitoring the serial console for debugging infoit often points out if a certain module or driver is causing issues.
It might take a few iterations, but this should get you started on a minimal build thats more tailored to your setup. Let us know how it goes, or if you need help with specific build errors.
Good luck!
Posted at 10/31/2024 21:35:27        Only Author  5#
There are some fascinating deadlines in this article but I don?t know if I see all of them center to heart. There may be some validity but I will take maintain opinion till I look into it further. Good article , thanks and we want extra! Added to FeedBurner as nicely Instagream [[url]https://www.instagram.com/]
Posted at 11/13/2024 19:26:38        Only Author  6#
With our selection of casual shoes for women, you may find the ideal balance between comfort and style. Choose from a variety of stylish loafers or hip sneakers to enhance your regular outfit. Get the newest styles now and spend all day in unparalleled comfort!
Posted at 11/13/2024 20:14:21        Only Author  7#
Gulaal presents the latest Pakistani dress designs, combining traditional beauty with contemporary flair. Discover our newest collections that celebrate cultural heritage with modern style.
Posted at 4/10/2025 14:48:06        Only Author  8#
The core philosophy behind SaveOurSavings is simple: your money should work for you, saveoursaving  not against you. In an age where instant gratification often takes precedence over long-term planning, many people find themselves struggling to set aside even a small portion of their income. Whether its due to student loans, unexpected medical expenses, or the rising cost of everyday living, saving money can feel like an impossible task. But the truth is, taking small, consistent steps can make a big difference.
Posted at 1/10/2026 01:53:25        Only Author  9#
Your article is breathtakingly good, thank you for sharing it! Preparing myself for the ACD201 latest study questions pdf exam. Wish me good luck!
Posted at 1/13/2026 11:04:41        Only Author  10#
This article is refreshing, and its really worth reading. The Reliable exam C-BCBAI-2509 questions fee exam was crucial for my career advancement, and now Im sharing it for free!
Return to List
12
