[General] GitHub GitHub-Advanced-Security Exam Reference, GitHub-Advanced-Security Certifi
97
【General】 GitHub GitHub-Advanced-Security Exam Reference, GitHub-Advanced-Security Certifi
Posted at 1/12/2026 02:28:33      View:246 | Replies:4        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of Getcertkey GitHub-Advanced-Security dumps from Cloud Storage: https://drive.google.com/open?id=17ZcGVmqYqjBkCCCXERZG87Ci1d8CggIl
With infallible content for your reference, our GitHub-Advanced-Security study guide contains the newest and the most important exam questions to practice. And our technicals are always trying to update our GitHub-Advanced-Security learning quiz to the latest. Only by regular practice can you ingest more useful information than others. And our GitHub-Advanced-Security Exam Questions can help you change your fate and choosing our GitHub-Advanced-Security preparation materials is foreshadow of your success.
Once you purchase the GitHub-Advanced-Security exam dumps from Getcertkey you can use it in three forms GitHub PDF Questions format, web-based software, and desktop GitHub GitHub-Advanced-Security practice test. Candidates can use GitHub Advanced Security GHAS Exam pdf questions file on their mobiles, laptop tablets, or any other device. Candidates can install the GitHub-Advanced-Security Practice Exam software on their desktops to attempt the GitHub GitHub-Advanced-Security practice test even when they are offline.
GitHub-Advanced-Security Certification Test Answers - Dumps GitHub-Advanced-Security CostOur company employs experts in many fields to write GitHub-Advanced-Security study guide, so you can rest assured of the quality of our learning materials. What's more, preparing for the exam under the guidance of our GitHub-Advanced-Security exam questions, you will give you more opportunities to be promoted and raise your salary in the near future. So when you are ready to take the exam, you can rely on our GitHub-Advanced-Security Learning Materials. If you want to be the next beneficiary, what are you waiting for? Come and buy our GitHub-Advanced-Security learning materials.
GitHub Advanced Security GHAS Exam Sample Questions (Q59-Q64):NEW QUESTION # 59
Which Dependabot configuration fields are required? (Each answer presents part of the solution. Choose three.)
  • A. milestone
  • B. package-ecosystem
  • C. schedule.interval
  • D. directory
  • E. allow
Answer: B,C,D
When configuring Dependabot via the dependabot.yml file, the following fields are mandatory for each update configuration:
directory: Specifies the location of the package manifest within the repository. This tellsDependabot where to look for dependency files.
package-ecosystem: Indicates the type of package manager (e.g., npm, pip, maven) used in the specified directory.
schedule.interval: Defines how frequently Dependabot checks for updates (e.g., daily, weekly). This ensures regular scanning for outdated or vulnerable dependencies.
The milestone field is optional and used for associating pull requests with milestones. The allow field is also optional and used to specify which dependencies to update.
GitLab
NEW QUESTION # 60
As a developer, you need to configure a code scanning workflow for a repository where GitHub Advanced Security is enabled. What minimum repository permission do you need?
  • A. Read
  • B. Write
  • C. None
  • D. Admin
To create or modify acode scanning workflow file(typically under .github/workflows/codeql-analysis.yml), you must haveWriteaccess to the repository.
Write permission allows you to commit the workflow file, which is required to run or configure code scanning using GitHub Actions.
NEW QUESTION # 61
A repository's dependency graph includes:
  • A. Annotated code scanning alerts from your repository's dependencies.
  • B. A summary of the dependencies used in your organization's repositories.
  • C. Dependencies parsed from a repository's manifest and lock files.
  • D. Dependencies from all your repositories.
Thedependency graphin a repository is built byparsing manifest and lock files(like package.json, pom.xml, requirements.txt). It helps GitHub detect dependencies and cross-reference them with known vulnerability databases for alerting.
It is specific to each repository and does not show org-wide or cross-repo summaries.
NEW QUESTION # 62
What filter or sort settings can be used to prioritize the secret scanning alerts that present the most risk?
  • A. Sort to display the oldest first
  • B. Select only the custom patterns
  • C. Filter to display active secrets
  • D. Sort to display the newest first
The best way toprioritizesecret scanning alerts is tofilter by active secrets- these are secrets GitHub has confirmed are still valid and could be exploited. This allows security teams to focus on high-risk exposures that require immediate attention.
Sorting by time or filtering by custom patterns won't help with risk prioritization directly.
NEW QUESTION # 63
Assuming that notification settings and Dependabot alert recipients have not been customized, which user account setting should you use to get an alert when a vulnerability is detected in one of your repositories?
  • A. Enable by default for new public repositories
  • B. Enable all in existing repositories
  • C. Enable all for Dependabot alerts
  • D. Enable all for Dependency graph
To ensure you're notified whenever a vulnerability is detected via Dependabot, you mustenablealerts for Dependabotin your personal notification settings. This applies to both new and existing repositories. It ensures you get timely alerts about security vulnerabilities.
The dependency graph must be enabled for scanning, but does not send alerts itself.
NEW QUESTION # 64
One of the main unique qualities of Getcertkey GitHub Advanced Security GHAS Exam Exam Questions is its ease of use. Our practice exam simulators are user and beginner friendly. You can use GitHub Advanced Security GHAS Exam (GitHub-Advanced-Security) PDF dumps and Web-based software without installation. GitHub GitHub-Advanced-Security PDF Questions work on all the devices like smartphones, Macs, tablets, Windows, etc. We know that it is hard to stay and study for the GitHub Advanced Security GHAS Exam (GitHub-Advanced-Security) exam dumps in one place for a long time.
GitHub-Advanced-Security Certification Test Answers: https://www.getcertkey.com/GitHub-Advanced-Security_braindumps.html
Now, here comes a piece of good news, our GitHub Certification GitHub-Advanced-Security pdf vce collection will be of great importance for you in the process of preparing for the actual exam, GitHub GitHub-Advanced-Security Exam Reference Don't hesitate, choose me, Our supporter of GitHub-Advanced-Security study guide has exceeded tens of thousands around the world, which directly reflects the quality of them, You can also download and install the offline version of GitHub Advanced Security GHAS Exam GitHub-Advanced-Security practice exam software on Windows-based PCs only.
This is just too confusing, so in this book Dumps GitHub-Advanced-Security Cost I'll always refer to it as the Active Stroke Style panel, no matter what toolis being used, This gives you several key GitHub-Advanced-Security benefits: First, you will have truly compiled code instead of interpreted script.
Download Updated GitHub GitHub-Advanced-Security Dumps at Discount and Start Preparation TodayNow, here comes a piece of good news, our GitHub Certification GitHub-Advanced-Security PDF VCE collection will be of great importance for you in the process of preparing for the actual exam.
Involving all types of questions in accordance with the real exam content, our GitHub-Advanced-Security exam questions are compiled to meet all of your requirements.
P.S. Free & New GitHub-Advanced-Security dumps are available on Google Drive shared by Getcertkey: https://drive.google.com/open?id=17ZcGVmqYqjBkCCCXERZG87Ci1d8CggIl
Posted at 1/15/2026 07:54:54        Only Author  2#
H12-821_V1.0인증시험은 IT업계에 종사하고 계신 분이시라면 최근 많은 인기를 누리고 있다는 것을 알고 계실것입니다. H12-821_V1.0인증시험을 패스하여 자격증을 취득하는데 가장 쉬운 방법은 KoreaDumps에서 제공해드리는 H12-821_V1.0덤프를 공부하는 것입니다. Huawei H12-821_V1.0덤프에 있는 문제와 답만 기억하시면 H12-821_V1.0시험을 패스하는데 많은 도움이 됩니다.덤프구매후 최신버전으로 업데이트되면 업데이트버전을 시스템 자동으로 구매시 사용한 메일주소로 발송해드려 덤프유효기간을 최대한 길게 연장해드립니다.
Posted at 1/26/2026 16:17:30        Only Author  3#
I found the article to be incredibly beneficial to my understanding. The content in 300-835 exam dumps demo is detailed and free, designed to aid in your studies.
Posted at 2/11/2026 05:04:23        Only Author  4#
This article is truly magnificent, thank you so much for sharing. With the help of the Downloadable AWS-Developer PDF, I achieved a promotion and pay raise. Now it’s free for everyone. Wishing you all success!
Posted at 3/5/2026 20:31:46        Only Author  5#
Your article was so impressive, I’m deeply thankful. This is the ISO-9001-Lead-Auditor exam sample exam that helped me get promoted and earn a pay raise. It’s available for free today—good luck with your career goals!
