Testking Analytics-Con-201 Learning Materials - Testking Analytics-Con-201 Exam
101
Posted at 3/6/2026 01:54:08      View95 | Replies0        Print      Only Author   [Copy Link] 1#
We are not exaggerating that if you study with our Analytics-Con-201 exam questions, then you will pass the exam for sure because this conclusion comes from previous statistics. The pass rate of our customers is high as 98% to 100% with our Analytics-Con-201 Practice Engine. We believe you are also very willing to become one of them, then why still hesitate? Just come in and try our Analytics-Con-201 study materials, and we can assure you that you will not regret your choice.
PremiumVCEDump is continuing to provide the candidates with Salesforce certification exam-related reference materials for years. PremiumVCEDump is the website that is validated by all the Analytics-Con-201 test-takers, which can provide all candidates with the best questions and answers. PremiumVCEDump comprehensively ensures the interests of all candidates, which enjoys immense praise of the candidates. Moreover PremiumVCEDump is the most trusted website on the current market.
Free PDF Quiz Analytics-Con-201 - The Best Testking Salesforce Certified CRM Analytics and Einstein Discovery Consultant Learning MaterialsOur Analytics-Con-201 test question with other product of different thing is we have the most core expert team to update our Analytics-Con-201 study materials, learning platform to changes with the change of the exam outline. If not timely updating Analytics-Con-201 training materials will let users reduce the learning efficiency of even lags behind that of other competitors, the consequence is that users and we don't want to see the phenomenon of the worst, so in order to prevent the occurrence of this kind of risk, the Analytics-Con-201 Practice Test materials give supervision and update the progress every day, it emphasized the key selling point of the product.
Salesforce Certified CRM Analytics and Einstein Discovery Consultant Sample Questions (Q15-Q20):NEW QUESTION # 15
Universal Containers asks a CRM Analytics consultant to review the performance of its local data sync.
After removing unused objects and fields from connected data, what else should the consultant do to improve performance of the data sync?
  • A. Evaluate connection mode for each connected object.
  • B. Enable fast sync in analytics settings.
  • C. Contact Salesforce Support to increase sync speed.
To improve the performance of local data sync in Universal Containers, evaluating the connection mode for each connected object is a practical approach. Here's the rationale:
* Optimization of Resources: Different connection modes (e.g., Full Sync, Incremental Sync) use different amounts of resources. Choosing the right mode for each object based on how frequently its data changes can optimize the sync process and reduce load times.
* Efficient Data Handling: By tailoring the connection mode to the needs of specific data objects, the overall efficiency of the data sync process is improved, leading to faster refresh rates and more timely data availability.
* Cost and Performance Balance: Evaluating and selecting the appropriate connection mode can also help balance performance needs with cost constraints, as some modes may consume more compute resources than others.
NEW QUESTION # 16
Which timeseries statement will fix the query?
  • A. q = timeseries q generate 'sum_Sales' as 'Forecasted_Sales' with (dateCols=('Date_Quarter',
    'Date_Month', "Q-M"), partition='Region', ignoreLast=true);
  • B. q = timeserles q generate 'sum_Sales' as 'Forecasted_Sales' with (length=12,dateCols=("Date_Year',
    'Date_Month', "Y-M"), partition='Region');
  • C. q= timeseries q generate 'sum_Sales' as 'Forecasted_Sales' with (dateCols=('Date_Year', 'Date Quarter', "Y-Q"), partition='Region', seasonality=4);
NEW QUESTION # 17
A client has two datasets that are used across seven different dashboards. Three of these dashboards are used by marketing and four are used by sales. The client requires that only marketing can access the marketing dashboards and only sales can access the sales dashboards.
Which solution should a consultant recommend?
  • A. Create three custom apps: one for marketing dashboards with marketing as "viewer", one for sales dashboards with sales as "viewer", and one for datasets where marketing and sales are "viewer".
  • B. Use two custom apps: one for marketing dashboards with marketing as "viewer" and one for sales dashboards with sales as "viewer". Add the datasets as references to both custom apps.
  • C. Duplicate the datasets and create two custom apps: one for marketing dashboards and datasets with marketing as "editor" and one for sales dashboards and datasets with sales as "editor".
NEW QUESTION # 18
Cloud Kicks (CK) has a dashboard in CRM Analytics with forecasting data. One widget is a compare table using the timeseries function showing the quarterly forecast. However, CK is interested in enhancing the dashboard with a weekly forecast per customer.
How should CK achieve this?
  • A. An SAQL query with a timeseries statement specifying Opportunity Name as the partition and Y-M-W as the Date Cols
  • B. An SAQL query with @ timeseries statement specifying Account Name as the partition and Y-M-D as the Date Cols
  • C. An SAQL query with a timeseries statement specifying Account Name as the partition and Y-M-W as the Date Cols
To create a weekly forecast per customer, anSAQL (Salesforce Analytics Query Language)query can be used.
The timeseries function generates forecast data based on a specified date range. In this case, the forecast is customer-specific, meaning the partition should be based onAccount Nameto ensure that the forecast is generated for each customer. The date column (Date Cols) should be set to Y-M-W to aggregate the forecast data on a weekly basis.
NEW QUESTION # 19
Universal Containers has a well-defined role hierarchy in Salesforce where everyone is assigned to an appropriate node. The accounts within their instance are categorized by their demography.
An individual sales rep should be able to view all accounts that they own. In addition, sales reps should be able to see any accounts where the value of the account demography matches the demography defined on their user record. A user could have more than one demography defined on their user record.
To meet this requirement, the CRM Analytics consultant has set up a security predicate of the existing
'Account' dataset as follows:
This, however, does not seem to be working as expected.
What is causing the issue?
  • A. The Sales Rep is not provided access permission on custom field Demographic__c on the User object.
  • B. The Analytics Security User is not provided access permission on custom field Demographic_c on the User object.
  • C. The security predicate needs to be updated as 'Ownerld' == "sUser.id" || 'Demography' = "$User.
    Demographic__c'.
The issue with the security predicate not functioning as expected likely stems from a permissions issue related to the custom field Demographic__c on the User object. Here's a detailed explanation:
* Field-Level Security: If the sales reps do not have access to the Demographic__c field, the security predicate which references this field cannot execute properly as the system cannot evaluate the predicate without accessing the field.
* Permission Settings: Ensuring that the sales reps have the necessary permissions to view and use the Demographic__c field is crucial for the security predicate to function correctly.
* Data Visibility: The security model in CRM Analytics relies heavily on the underlying data permissions in Salesforce. If these permissions are not correctly configured, the expected data visibility through CRM Analytics will not be achieved.
NEW QUESTION # 20
The last format is desktop Analytics-Con-201 practice test software that can be accessed easily just by installing the software on the Windows Pc or Laptop. The desktop software format can be accessed offline without any internet so the students who don't have internet won't struggle in the preparation for Analytics-Con-201 Exam. These three forms are specially made for the students to access them according to their comfort zone and Analytics-Con-201 exam prepare for the best.
Testking Analytics-Con-201 Exam Questions: https://www.premiumvcedump.com/Salesforce/valid-Analytics-Con-201-premium-vce-exam-dumps.html
Salesforce Testking Analytics-Con-201 Learning Materials So you need a right training material to help you, Our good quality of Analytics-Con-201 exam questions and after-sales service, the vast number of users has been very well received, Our Analytics-Con-201 study materials can help you get your certification in the least time with the least efforts, You can download the full features of Analytics-Con-201 PDF Questions and practice test software right after the payment.
Introducing the View Types on Mac OS X, Setting up an address Analytics-Con-201 from a C string with varying addresses requires more programming effort, So you need a right training material to help you.
Our good quality of Analytics-Con-201 Exam Questions and after-sales service, the vast number of users has been very well received, Our Analytics-Con-201 study materials can help you get your certification in the least time with the least efforts.
Analytics-Con-201 Prep Training - Analytics-Con-201 Study Guide & Analytics-Con-201 Test PdfYou can download the full features of Analytics-Con-201 PDF Questions and practice test software right after the payment, With a Analytics-Con-201 certification, you can not only get New Analytics-Con-201 Exam Sample a good position in many companies, but also make your financial free come true.
