[General] Latest XSOAR-Engineer Exam Bootcamp, Valid Exam XSOAR-Engineer Practice
98
【General】 Latest XSOAR-Engineer Exam Bootcamp, Valid Exam XSOAR-Engineer Practice
Posted at 2/16/2026 23:32:28      View:123 | Replies:0        Print      Only Author   [Copy Link] 1#
TorrentExam have the obligation to ensure your comfortable learning if you have spent money on our XSOAR-Engineer study materials. We do not have hot lines. So you are advised to send your emails to our email address. In case you send it to others’ email inbox, please check the address carefully before. The after-sales service of website can stand the test of practice. You needn’t spend too much time to learn it. Our XSOAR-Engineer Exam Guide is of high quality and if you use our product the possibility for you to pass the exam is very high.
Our users are all over the world, and users in many countries all value privacy. Our XSOAR-Engineer simulating exam ' global system of privacy protection standards has reached the world's leading position. No matter where you are, you don't have to worry about your privacy being leaked if you ask questions about our XSOAR-Engineer Exam Braindumps or you pay for our XSOAR-Engineer practice guide by your credit card. It is safe for our customers to buy our XSOAR-Engineer learning materials!
The best way to Prepare Exam With Palo Alto Networks XSOAR-Engineer Exam DumpsDon't miss practicing the XSOAR-Engineer mock exams and score yourself honestly. You have all the time to try Palo Alto Networks XSOAR-Engineer practice exams and then be confident while appearing for the final turn. The desktop software works on Windows and the web-based format works on all operating systems. With PDF questions, you can prepare for the XSOAR-Engineer Certification Exam while sitting back at our place.
Palo Alto Networks XSOAR-Engineer Exam Syllabus Topics:
  • Playbook Development: This domain addresses automation through playbook creation including task configuration, context data manipulation, various task types, sub-playbooks with looping, filters and transformers, debugger usage, built-ins and scripts, automation script creation, and job management.
  • Use Case Planning and Development: This domain focuses on designing security use cases through incident and indicator lifecycle management, field and layout customization, classifier and mapper configuration, incident creation methods, pre
  • post-processing, and incident type configuration with playbooks, layouts, SLAs, and lists.
  • Incident Interactions and Reporting: This domain covers incident operations including states and actions, War Room activities, incident relationships, and dashboard and report configuration for metrics and visualization.
  • Threat Intelligence Management: This domain focuses on threat intelligence operations including indicator creation and configuration, indicator relationships, enrichment with source reliability, external intelligence sharing, and exclusion list management.
Topic 5
  • Planning, Installation, and Maintenance: This domain covers system setup and administration including authentication configuration, engine deployment, dev
  • prod environment planning, Marketplace pack management, integration instance configuration, and system maintenance.
Palo Alto Networks XSOAR Engineer Sample Questions (Q26-Q31):NEW QUESTION # 26
Which command adds or updates a description to an incident that can be used within widgets?
Which command adds or updates a description to an incident that can be used within widgets?.
  • A. !setIncident description=This is an updated description.
  • B. !Set key="description" value="This is an updated description.".
  • C. !Set key-"description" value-This is an updated description.
  • D. !setIncident description="This is an updated description.".
The !setIncident command is the documented method for updating incident fields programmatically in Cortex XSOAR. The Admin Guide states that the syntax requires proper quoting for parameters, especially when assigning descriptive text that may include spaces. The correct syntax is:
!setIncident description="some text"
This updates the built-in description field at the incident level and allows widgets, dashboards, and reports to use the updated description because XSOAR widgets can read incident fields directly. OptionAuses correct syntax with quotes included.
Option B incorrectly uses !Set, which modifiescontext keys, not incident fields. Option C is invalid due to incorrect parameter formatting (hyphens instead of equals signs). Option D omits quotation marks, causing parsing errors in cases where the value includes spaces, verbs, or punctuation.
Thus, the only correct and fully documented method to update an incident's description so that it is available to widgets isA: !setIncident description="...".
NEW QUESTION # 27
Based on the image below, which key from the context points to the string GOGL?.
  • A. Whois.IP.asn_registry.entities.
  • B. Whois.IP.network.name.
  • C. Whois.IP.[0].network.name.
  • D. Whois.IP.entities.
NEW QUESTION # 28
What is the primary effect on a new file hash when it is added to the indicator exclusion list?.
  • A. It is excluded from intelligence feeds that have a reliability score lower than "B - Usually reliable.".
  • B. It is not extracted, enriched, or given a new verdict.
  • C. It is processed normally by enrichment automations, but the verdict is set to "benign.".
  • D. It is extracted and stored, but an "exclusion" tag is added, requiring manual review before it can affect any incidents.
The Indicator Exclusion List feature in XSOAR is designed to prevent certain IOCs (file hashes, IPs, domains, etc.) from being processed by the platform. The Admin Guide explains that once an indicator is added to the exclusion list, XSOARdoes not extract, enrich, score, or apply verdictsto that indicator during ingestion or field-change extraction. This ensures that benign internal hashes, test indicators, or noisy artifacts do not trigger incidents, enrichments, or correlation rules.
Option B does not reflect platform behavior-XSOAR does not create exclusion tags requiring manual review; instead, itcompletely bypasses extraction and enrichment. Option C is incorrect because excluded indicators do not undergo enrichment or verdict assignment at all. Option D incorrectly suggests that exclusion depends on feed reliability; the exclusion list applies globally and unconditionally.
Therefore, the correct interpretation per the documentation is thatexcluded indicators are never extracted or processed, aligning precisely with optionA.
NEW QUESTION # 29
What is an example of a generic reputation command?
  • A. !reputation
  • B. !getReputation
  • C. !ip
  • D. !enrichIndicator
NEW QUESTION # 30
To avoid exceeding API quotas for third-party services, indicators are only updated after the indicator cache expiration period. What is the default cache expiration period for indicators in XSOAR (minutes/days)?
  • A. 21,600 minutes (15 days)
  • B. 4,320 minutes (3 days)
  • C. 10,080 minutes (7 days)
  • D. 20,160 minutes (14 days)
Reference: https://docs-cortex.paloaltonetw ... SOAR-Administrator- Guide/Indicator-Type-Profile
NEW QUESTION # 31
What is the measure of competence? Of course, most companies will judge your level according to the number of qualifications you have obtained. It may not be comprehensive, but passing the qualifying exam is a pretty straightforward way to hire an employer. Our XSOAR-Engineer exam practice questions on the market this recruitment phenomenon, tailored for the user the fast pass the examination method of study, make the need to get a good job have enough leverage to compete with other candidates. The quality of our XSOAR-Engineer learning guide is absolutely superior, which can be reflected from the annual high pass rate.
Valid Exam XSOAR-Engineer Practice: https://www.torrentexam.com/XSOAR-Engineer-exam-latest-torrent.html
