Analytics-DA-201 Study Guide: Salesforce Certified Tableau Data Analyst & An
Posted at 2/22/2026 00:18:40
The client can try out and download our Salesforce Analytics-DA-201 Training Materials freely before their purchase so as to have an understanding of our product and then decide whether to buy them or not. The website pages of our product provide the details of our Salesforce Certified Tableau Data Analyst learning questions.
Salesforce Analytics-DA-201 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - SAP Clean Core Extensibility and ABAP Cloud: This part of the exam targets the SAP S
- 4HANA Technical Consultant and covers concepts of clean core extensibility using ABAP in the cloud. The focus is on in-app and side-by-side extensibility techniques, ensuring that custom code complies with cloud-readiness principles and does not compromise the upgrade stability of core systems.
| | Topic 2 | - Object-Oriented Design: This section of the exam evaluates the SAP ABAP Cloud Developer's understanding of object-oriented principles in the ABAP context. It focuses on class-based programming, inheritance, interfaces, and polymorphism, all crucial for building modular and maintainable ABAP cloud applications.
| | Topic 3 | - ABAP SQL and Code Pushdown: This section of the exam measures the competencies of the SAP ABAP Cloud Developer related to performance optimization through ABAP SQL and code pushdown techniques. It ensures that the developer understands how to shift logic to the database layer using efficient SQL scripting to enhance performance in data-intensive applications.
Latest Analytics-DA-201 Test Question & Reliable Analytics-DA-201 Dumps EbookOnly 20-30 hours on our Analytics-DA-201 learning guide are needed for the client to prepare for the test and it saves our client’s time and energy. Most people may wish to use the shortest time to prepare for the Analytics-DA-201 test and then pass the test with our Analytics-DA-201 Study Materials successfully because they have to spend their most time and energy on their jobs, learning, family lives and other important things. And our Analytics-DA-201 exam braindumps won't let you down!
Salesforce Certified Tableau Data Analyst Sample Questions (Q158-Q163):NEW QUESTION # 158
You have a data source that contains 20 tables.
You want the tables to be organized within the Data pane based on the type of data contained within the tables.
What should you use?
- A. Sets
- B. Groups
- C. Hierarchies
- D. Folders
To organize the tables in the Data pane based on the type of data contained within the tables, you should use folders. Folders are a way to manually group fields, parameters, sets, or tables in the Data pane according to your preference. You can create folders by right-clicking on the fields or tables you want to group and selecting Folders > Create Folder. You can also drag and drop fields or tables into existing folders. You can name the folders according to the type of data they contain, such as sales, customer, product, etc. Folders can help you find and access the fields or tables you need more easily and efficiently. References:
* Organize and Customize Fields in the Data Pane - Tableau
* Tableau Certified Data Analyst Study Guide
NEW QUESTION # 159
You are developing a data source in Tableau Prep.
You have two tables named Orders and Employees.
The Orders table was created in 2019 and contains the following columns.
The Employees table contains all the employee information for the various sales teams in the sales department and contains the following columns
You want to prepare the data so that you can analyze sales trends over time for every sales team.
Which three actions should you perform in order? (Place the three correct options in order. Use the arrows to move Options to Answer Area. Use Answer Area arrows to re-order the options.)
There are different ways to prepare the data in Tableau Prep, but one possible answer is:
Answer area:
* Join the tables.
* Aggregate the data by Sales Team.
* Add the following filter to the Employees table: Sale Team - Team Alpha.
To analyze sales trends over time for every sales team, you need to combine the data from the Orders and Employees tables. You can do this by joining the tables on the Rep ID column, which is a common identifier for both tables. This will create a single table with all the columns from both tables. Next, you need to aggregate the data by Sales Team, which is the level of analysis you want. You can do this by grouping the data by the Sales Team column and applying an aggregation function (such as sum, average, count, etc.) to the other columns that you want to measure (such as Total Amount, Rep Tenure, etc.). This will create a summary table with one row for each sales team and the aggregated values for the other columns. Finally, you need to filter the data to focus on a specific sales team, such as Team Alpha. You can do this by adding a filter to the Employees table and selecting only the rows where Sales Team equals Team Alpha. This will remove the rows for other sales teams and keep only the data for Team Alpha.
[Tableau Certified Data Analyst Exam Prep Guide], page 9, section "Preparing Data"
[Tableau Help: Join Your Data]
[Tableau Help: Aggregate Your Data]
[Tableau Help: Filter Your Data]
NEW QUESTION # 160
You have the following dashboard.
From the context menu of Sales over time, select Ignore Actions.
Several Lays later, you decide that you want to filter both Sales over time and Detail table by selecting a data point on the map.
What should you do?
- A. From the context menu of Detail table, select Ignore Actions.
- B. From the context menu of Sales over time, select Use as Filter and then deselect Use as Filter
- C. From the context menu of Profits by state, deselect Use as Filter and then select Use as Filter.
- D. From the context menu of Sales over lime, select Filters and then select Enable Auto Update.
NEW QUESTION # 161
You company has two divisions located in the United States and Germany Bach division has a separate database. The following is a sample of the sales data for the division in the United States.
The following is a sample of the sales data for me division in Germany.
You have population data in a file named Populatio.csv. the following is a sample of the data.
You plan to create a visualization that ml show tie sales per capita for each salesperson Each salesperson must be identified by identified by their full name.
You need to prepare the data to support the planned visualization. The data source must support being published .
Which four actions should you perform in order?
(Place the four correct options n order Use the arrows to move Options to Answer Area arrows to re-order the options.
Use Answer Area arrows to re-order the options)
1) Open Tableau prep
2) Create a new column ...
3) Union the sales ...
4) Join the sales ...
References: https://help.tableau.com/current/prep/en-us/prep_get_started.htm https://help.tableau.com/current
/prep/en-us/prep_union.htm https://help.tableau.com/current/prep/en-us/prep_clean.htm https://help.tableau.
com/current/prep/en-us/prep_join.htm
NEW QUESTION # 162
You have the Mowing dashboard.
Which two elements are floating? Choose two.
- A. The map
- B. The color legend
- C. The Rate of Obesity chart
- D. The state filter
- E. The little
In Tableau dashboards, floating elements are those that can be freely moved over the dashboard canvas without being snapped into the tiled layout. The floating elements are often indicated by their standalone frames and the ability to overlap with other dashboard items. From the provided image, the state filter and the Rate of Obesity chart can be identified as floating if they can be moved independently of the tiled grid layout that constrains other elements.
NEW QUESTION # 163
Perhaps now you are one of the candidates of the Salesforce Analytics-DA-201 exam, perhaps now you are worried about not passing the exam smoothly. Now we have good news for you: our Analytics-DA-201 study materials will solve all your worries and help you successfully pass it. With the high pass rate as 98% to 100%, you will find that we have the best Salesforce Certified Tableau Data Analyst Analytics-DA-201 learning braindumps which contain the most accurate real exam questions.
Latest Analytics-DA-201 Test Question: https://www.actualtestsit.com/Salesforce/Analytics-DA-201-exam-prep-dumps.html
- Free PDF 2026 Analytics-DA-201: Salesforce Certified Tableau Data Analyst High Hit-Rate Useful Dumps 🛴 Easily obtain { Analytics-DA-201 } for free download through ➠ [url]www.testkingpass.com 🠰 🌜Analytics-DA-201 Latest Exam Notes[/url]
- Free PDF 2026 Analytics-DA-201: Salesforce Certified Tableau Data Analyst High Hit-Rate Useful Dumps 🏍 Search for { Analytics-DA-201 } and easily obtain a free download on ➡ [url]www.pdfvce.com ️⬅️ 🎸Analytics-DA-201 Latest Exam Notes[/url]
- Analytics-DA-201 Sample Test Online 👐 Analytics-DA-201 Valid Test Camp 🥜 Analytics-DA-201 Valid Exam Registration 🤝 Open website ➽ [url]www.prep4sures.top 🢪 and search for { Analytics-DA-201 } for free download 🚃Analytics-DA-201 Valid Examcollection[/url]
- Authentic Analytics-DA-201 Exam Questions 🤏 Authentic Analytics-DA-201 Exam Questions 🗣 Analytics-DA-201 Certification Test Questions 🦖 Open website ☀ [url]www.pdfvce.com ️☀️ and search for ⇛ Analytics-DA-201 ⇚ for free download 🤥Latest Analytics-DA-201 Dumps Questions[/url]
- Free PDF 2026 Analytics-DA-201: Salesforce Certified Tableau Data Analyst High Hit-Rate Useful Dumps 📎 Open 【 [url]www.troytecdumps.com 】 enter ( Analytics-DA-201 ) and obtain a free download 🍬Exam Analytics-DA-201 Cram[/url]
- Analytics-DA-201 Test Testking 🌂 Analytics-DA-201 Test Questions 🥬 Analytics-DA-201 Relevant Answers ➿ Search for “ Analytics-DA-201 ” and easily obtain a free download on ⏩ [url]www.pdfvce.com ⏪ 😁Analytics-DA-201 Test Questions[/url]
- Authentic Analytics-DA-201 Exam Questions 😗 Analytics-DA-201 Valid Real Exam 😾 Analytics-DA-201 Reliable Learning Materials 🎄 Search for ▷ Analytics-DA-201 ◁ and easily obtain a free download on “ [url]www.verifieddumps.com ” 🚼Analytics-DA-201 Valid Exam Registration[/url]
- Quiz 2026 Salesforce Marvelous Analytics-DA-201: Salesforce Certified Tableau Data Analyst Useful Dumps 🕍 Immediately open ☀ [url]www.pdfvce.com ️☀️ and search for ➠ Analytics-DA-201 🠰 to obtain a free download 🎣Analytics-DA-201 Reliable Learning Materials[/url]
- Download The Analytics-DA-201 Useful Dumps Means that You Have Passed Salesforce Certified Tableau Data Analyst 🍉 Open website ➽ [url]www.prepawaypdf.com 🢪 and search for 《 Analytics-DA-201 》 for free download 😞Exam Analytics-DA-201 Cram[/url]
- New Analytics-DA-201 Useful Dumps | Latest Salesforce Latest Analytics-DA-201 Test Question: Salesforce Certified Tableau Data Analyst 🟫 Search for ( Analytics-DA-201 ) on “ [url]www.pdfvce.com ” immediately to obtain a free download 📝Analytics-DA-201 Relevant Answers[/url]
- Test Analytics-DA-201 Dumps Free ✴ Analytics-DA-201 Reliable Test Prep 💗 Analytics-DA-201 Sample Test Online 🌱 Search on ➽ [url]www.vce4dumps.com 🢪 for ⇛ Analytics-DA-201 ⇚ to obtain exam materials for free download 🧓Analytics-DA-201 Study Materials Review[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, cottontree.academy, thinkoraa.com, www.stes.tyc.edu.tw, edu.iqraastore.store, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, bbs.t-firefly.com, Disposable vapes
