1z1-076 Exams Dumps & New Study 1z1-076 Questions
Posted at 2/12/2026 18:27:15
View129
Replies0
P.S. Free 2026 Oracle 1z1-076 dumps are available on Google Drive shared by TestPDF: https://drive.google.com/open?id=1u_QD_ROo_5JSFVY4e-DvF7-uGWsJunwd
The TestPDF 1z1-076 PDF dumps file is a collection of real, valid, and updated 1z1-076 practice questions that are also easy to install and use. The TestPDF 1z1-076 PDF dumps file can be installed on a desktop computer, laptop, and even on your smartphone devices. Just download TestPDF Oracle Database 19c: Data Guard Administration (1z1-076) PDF questions on your desired device and start 1z1-076 exam dumps preparation today.
Oracle 1z1-076 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Enhanced Client Connectivity in a Data Guard Environment: This topic focuses on enhancing client connectivity in a Data Guard setup and implementing failover procedures for seamless client redirection. It also covers application continuity to ensure uninterrupted operations during role transitions.
| | Topic 2 | - Monitoring a Data Guard Broker Configuration: The topic covers the use of Enterprise Manager and DGMGRL to monitor Data Guard configurations and explains the various data protection modes available.
| | Topic 4 | - Creating a Logical Standby Database: This topic guides users through the process of creating and managing a logical standby database, including SQL Apply filtering.
| | Topic 5 | - Creating a Data Guard Broker Configuration: This section delves into the practical aspects of creating and managing a Data Guard broker configuration, including command-line and Enterprise Manager approaches.
| | Topic 7 | - Backup and Recovery Considerations in an Oracle Data Guard Configuration: In this topic, Backup and recovery procedures in a Data Guard configuration are discussed, including RMAN backups, offloading to physical standby, and network-based recovery.
| | Topic 8 | - Patching and Upgrading Databases in a Data Guard Configuration: This section provides guidance on patching and upgrading databases in a Data Guard environment, along with performance optimization techniques and monitoring considerations.
| | Topic 9 | - Performing Role Transitions: Here, the concept of database roles is explained, along with the steps for performing switchovers, failovers, and maintaining physical standby sessions during role transitions.
| | Topic 10 | - Managing Oracle Net Services in a Data Guard Environment: The section focuses on Oracle Net Services and its role in Data Guard networking setup.
New Study 1z1-076 Questions & 1z1-076 Exam ReviewDo you long to get the 1z1-076 certification to improve your life? Are you worried about how to choose the learning product that is suitable for you? If your answer is yes, we are willing to tell you that you are a lucky dog, because you meet us, it is very easy for us to help you solve your problem. Our 1z1-076 exam torrent is compiled by professional experts that keep pace with contemporary talent development and makes every learner fit in the needs of the society. If you choose our study materials, you will pass exam successful in a short time. There is no doubt that our 1z1-076 Exam Question can be your first choice for your relevant knowledge accumulation and ability enhancement.
Oracle Database 19c: Data Guard Administration Sample Questions (Q92-Q97):NEW QUESTION # 92
Which two are prerequisites for configuring flashback database for Oracle 19c databases, in a Data Guard environment?
- A. The database must be in ARCHTVELOG mode.
- B. A fast recovery area must be configured.
- C. The Data Guard real-time apply feature must be enabled.
- D. The data guard broker must be used.
- E. A far sync instance must be configured to flash back a standby when the primary has been flashed back.
* A fast recovery area must be configured (B): Flashback Database requires a fast recovery area to be set up because flashback logs are stored there. The fast recovery area is a unified storage location for all recovery-related files and activities.
* The database must be in ARCHIVELOG mode (C): Flashback Database operation relies on the ability to archive redo logs. Therefore, the database must be running in ARCHIVELOG mode for Flashback Database to be enabled.
* Oracle Database Backup and Recovery User's Guide
* Oracle Data Guard Concepts and Administration Guide
NEW QUESTION # 93
Attempting to start the observer raises an error:
DGMGRL> start observer;
DGM-16954: Unable to open and lock the Observer configuration file
Failed.
Identify two possible ways to start the observer successfully.
- A. Create a broker configuration and enable Fast-Start Failover before starting the observer.
- B. Set the ObserverOverride property to TRUE before starting the observer.
- C. Start the observer in a different working directory.
- D. Enable Fast-Start Failover before starting the observer.
- E. Start the observer using a different observer configuration file.
Answer: C,E
NEW QUESTION # 94
On your logical standby database, you specified these rules:
After completion of the weekend batch cycle you attempt to delete the SQL Apply filters:
Which is TRUE regarding the execution of the UNSKIP procedure?
- A. It deletes both the SQL Apply filters.
- B. It succeeds only if SQL apply is stopped before deleting the SQL Apply filter.
- C. It succeeds only if all DML statements executed on the primary have been applied on the logical standby deleting the SQL Apply filter.
- D. It returns an error because the syntax to delete a SQL Apply filter must specify the same object names as specified when the filter was added.
- E. It succeeds but the SQL Apply filters are not deleted.
The execution of the UNSKIP procedure is designed to remove SQL Apply filters that have been previously set up on a logical standby database. Based on the provided statements, the UNSKIP procedure is directed to delete any SQL Apply filters for DML statements associated with objects in the 'HR' schema that start with 'EMP'. Since both SKIP procedures had the same schema name ('HR') and statement type ('DML'), and the UNSKIP procedure uses a wildcard (%) for the object name, it will successfully remove both of the SQL Apply filters for 'EMP_NEW' and 'EMP_OLD', as both object names match the pattern provided in the UNSKIP procedure.
Oracle's Data Guard documentation and SQL Language Reference provide insights into managing SQL Apply filters on a logical standby database using the DBMS_LOGSTDBY package. This includes adding and removing filters through SKIP and UNSKIP procedures.
NEW QUESTION # 95
Which two statements are true when using non-rolling release upgrades in a Data Guard environment?
- A. During the upgrade of a logical standby database, standby redo log files must reside on O/S file systems.
- B. The compatible parameter on a standby database that is applying redo, must be equal to or greater than the compatible parameter on the primary that is shipping redo to that standby.
- C. User equivalence must be established for the owner of the Oracle software on the affected hosts prior to the upgrade.
- D. Modifications to the data dictionary on the primary database caused by the upgrade, are applied on a logical standby database.
- E. Modifications to the data dictionary on the primary database caused by the upgrade, are applied on a physical standby database.
Answer: B,E
* The compatible parameter on a standby database that is applying redo, must be equal to or greater than the compatible parameter on the primary that is shipping redo to that standby (A):
This ensures that the standby database can apply redo from the primary, even after the primary has been upgraded. The COMPATIBLE parameter setting on the standby database should not preclude it from understanding the redo it receives.
* Modifications to the data dictionary on the primary database caused by the upgrade, are applied on a physical standby database (C): When the primary database undergoes a non-rolling upgrade, any resulting data dictionary changes are transmitted through redo data and applied to the physical standby database.
* Oracle Database Upgrade Guide
NEW QUESTION # 96
Your Data Guard environment has two remote physical standby databases.
Client applications use the local naming method to connect to the primary database instance.
You want applications to automatically connect to the new primary database instance in case of a switchover or a failover.
Which set of actions will fulfill this requirement?
- A. Create a database service on the primary database that is started automatically by a trigger, when the database role is PRIMARY; modify the connection descriptors used by client applications to include all the standby hosts and connect to the database instance using that service name.
- B. Set the INSTANCE NAME parameter identically on all databases; modify the connection descriptor on client applications to include all the standby hosts and connect to the database instance using that service name.
- C. Set DB_NAME and DB_UNIQUE_NAME identically on all databases; modify the connection descriptors on client applications to include all the standby hosts and connect to the database instance using that service name.
- D. Set the LOCAL_LISTENER parameter for all the database instance to register services with the default listener on the primary database host.
For seamless client redirection in a Data Guard environment, the following steps should be taken:
Create a database service on the primary database that is started automatically by a trigger when the database role is PRIMARY (B): This ensures that the service is only available on the primary database and is automatically started after a role transition due to switchover or failover.
Modify the connection descriptors used by client applications to include all the standby hosts and connect to the database instance using that service name (B): Client applications use the connection descriptors that include all potential primary hosts (i.e., the current primary and all standbys). This enables clients to connect to whichever database is currently acting as the primary using the service name.
Oracle Real Application Clusters Administration and Deployment Guide
NEW QUESTION # 97
Our company has done the research of the 1z1-076 study material for several years, and the experts and professors from our company have created the famous 1z1-076 study materials for all customers. We believe our 1z1-076 training braidump will meet all demand of all customers. If you long to pass the exam and get the certification successfully, you will not find the better choice than our 1z1-076 Preparation questions. You can free dowload the demo of our 1z1-076 exam questons to check the excellent quality on our website.
New Study 1z1-076 Questions: https://www.testpdf.com/1z1-076-exam-braindumps.html
- Newest 1z1-076 Exams Dumps - Pass 1z1-076 Exam 🥔 Open website ⮆ [url]www.prep4sures.top ⮄ and search for { 1z1-076 } for free download 💔1z1-076 Latest Dumps Book[/url]
- Reasons to Choose Web-Based Oracle 1z1-076 Practice Test 🍘 Open ➠ [url]www.pdfvce.com 🠰 and search for { 1z1-076 } to download exam materials for free 🍷Valid 1z1-076 Exam Sample[/url]
- New Soft 1z1-076 Simulations 🥳 New Soft 1z1-076 Simulations 🍠 1z1-076 Reliable Dumps 🍜 Search for { 1z1-076 } and download it for free on ➥ [url]www.examcollectionpass.com 🡄 website 🎦Valid Test 1z1-076 Testking[/url]
- Valid 1z1-076 Exams Dumps and High-Efficient New Study 1z1-076 Questions - Professional Oracle Database 19c: Data Guard Administration Exam Review 🔦 Simply search for 1z1-076 for free download on ➠ [url]www.pdfvce.com 🠰 🧲Exam 1z1-076 Demo[/url]
- 1z1-076 Practical Information 😚 1z1-076 Reliable Dumps 👓 New Soft 1z1-076 Simulations 🧫 Simply search for 1z1-076 for free download on ✔ [url]www.practicevce.com ️✔️ 🦌Valid Test 1z1-076 Bootcamp[/url]
- Detailed 1z1-076 Study Plan 🥾 Detailed 1z1-076 Study Plan 🏃 1z1-076 Latest Test Bootcamp 🏯 Easily obtain ➥ 1z1-076 🡄 for free download through ⇛ [url]www.pdfvce.com ⇚ 🦂Valid 1z1-076 Exam Sample[/url]
- 1z1-076 Practical Information 🚠 Valid 1z1-076 Exam Sample 🌟 1z1-076 Reliable Dumps 🔣 Immediately open ➥ [url]www.prepawaypdf.com 🡄 and search for ⏩ 1z1-076 ⏪ to obtain a free download 📀Detailed 1z1-076 Study Plan[/url]
- [url=https://nanki.org/?s=1z1-076%20Reliable%20Dumps%20%f0%9f%a7%b8%20Interactive%201z1-076%20Practice%20Exam%20%f0%9f%93%a6%20Real%201z1-076%20Dumps%20Free%20%f0%9f%93%8a%20Open%20website%20%e2%9c%94%20www.pdfvce.com%20%ef%b8%8f%e2%9c%94%ef%b8%8f%20and%20search%20for%20[%201z1-076%20]%20for%20free%20download%20%f0%9f%a6%a11z1-076%20High%20Passing%20Score]1z1-076 Reliable Dumps 🧸 Interactive 1z1-076 Practice Exam 📦 Real 1z1-076 Dumps Free 📊 Open website ✔ www.pdfvce.com ️✔️ and search for [ 1z1-076 ] for free download 🦡1z1-076 High Passing Score[/url]
- 1z1-076 Exams Dumps 100% Pass | High Pass-Rate 1z1-076: Oracle Database 19c: Data Guard Administration 100% Pass 🍖 Open ✔ [url]www.prep4away.com ️✔️ and search for ⇛ 1z1-076 ⇚ to download exam materials for free 🌷1z1-076 Practical Information[/url]
- Detailed 1z1-076 Study Plan 🧭 1z1-076 High Passing Score 🏪 Valid Test 1z1-076 Bootcamp ❤ Copy URL [url]www.pdfvce.com open and search for ➠ 1z1-076 🠰 to download for free 🕎1z1-076 Reliable Real Exam[/url]
- 1z1-076 Reliable Dumps 🤴 1z1-076 Practical Information 🎇 Valid Real 1z1-076 Exam 🤓 Download 1z1-076 for free by simply searching on ➡ [url]www.troytecdumps.com ️⬅️ 🌞Valid 1z1-076 Exam Syllabus[/url]
- www.stes.tyc.edu.tw, dl.instructure.com, ycs.instructure.com, www.stes.tyc.edu.tw, paidforarticles.in, www.mixcloud.com, onlyfans.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
2026 Latest TestPDF 1z1-076 PDF Dumps and 1z1-076 Exam Engine Free Share: https://drive.google.com/open?id=1u_QD_ROo_5JSFVY4e-DvF7-uGWsJunwd
