[Linux] Changing Kernel version in Linux
14
Linux Changing Kernel version in Linux
Posted at 6/19/2018 00:26:18      View5433 | Replies7        Print      Only Author   [Copy Link] 1#
Hi everyone,
I just bought a RK-3399, I installed the Firefly-RK3399-ubuntu16.04-20180416112819.img on it.  I want to use it with a Intel Realsense camera 415. My first issue is the kernel version, because the installation script of the camera use: uname -r. Thus when I typed uname -r in the firefly ubuntu the outcome is:
4.4.77
but sadly under that kernel number there are not installed packages in /usr/src where the scripts is looking for some stuffs. However, there is all what is needed under the kernel version 4.4.0-128-generic but I dont know how to change to that kernel version because in firefly ubuntu does not work grub.
I hacked the uname program to give all the results that I want but at the end of the compilation of realsense library fails and I tired of patching this in a hacky way when the solution should be simple.
Does someone know how to change the kernel version in firefly linux?
Regards,
Felipe
Posted at 12/6/2018 01:34:57        Only Author  2#
And /boot directory is empty and gpardet is not recognizing the emmc partition disk format.
vip
Rank: 6Rank: 6
Posted at 12/7/2018 09:22:32        Only Author  3#
With the latest ubuntu 18.04 firmware for Firefly-RK3399, the partition layout will change
from the non-standard scheme of rknand= in parameter.txt to standard gpt.
Posted at 1/10/2026 23:53:21        Only Author  4#
This article is absolutely brilliant, thank you for sharing. I was promoted and received a raise with the help of the Valid exam L6M3 objectives pdf. Now its available for free to all. Best wishes for your promotions!
Posted at 1/17/2026 13:08:34        Only Author  5#
Fast2test의 제품들은 모두 우리만의 거대한IT업계엘리트들로 이루어진 그룹 즉 관련업계예서 권위가 있는 전문가들이 자기만의 지식과 지금까지의 경험으로 최고의 IT인증관련자료를 만들어냅니다. Fast2test의 문제와 답은 정확도 적중률이 아주 높습니다. 우리의 덤프로 완벽한Microsoft인증SC-100-KR시험대비를 하시면 되겠습니다. 이렇게 어려운 시험은 우리Microsoft인증SC-100-KR덤프로 여러분의 고민과 꿈을 한방에 해결해드립니다.
Posted at 1/26/2026 09:00:24        Only Author  6#
Wenn Sie sich noch anstrengend um die Oracle N16300GC10 Zertifizierungsprfung bemhen, dann haben Sie einen großen Fehler gemacht. Durch fleißiges Lernen können Sie sicher die Prfung bestehen. Aber Sie können vielleicht das erwartete Ziel vielleicht nicht erreichen. Im Zeitalter des Internets gibt es zahlreiche erfolgreiche IT-Zertifizierungen. Die Schulungsunterlagen zur Oracle N16300GC10 Zertifizierungsprfung von ZertFragen sind sehr gut. Sie sind zielgerichtet und verprechen Ihnen, die Oracle N16300GC10 Prfung 100% zu bestehen. Diese Schulungsunterlagen sind nicht nur rational, sondern können viel Zeit ersparen. Sie können mit der ersparten Zeit etwas anderes lernen. So können Sie bessere Resultate bei weniger Einsatz erzielen.
Posted at 1/30/2026 09:02:42        Only Author  7#
CDTѧκϸʤ99ǡCDTgɤϸߤҥåʤߤޤCDTƥȥȥȤόTҤˤäƾ졢Construction Specifications Instituteṩش|όgHԇY˻ŤƤޤCDTԇY}ݤϡ⤷äΤgǤԇYΜʂȫˤ뤿ˡΥեȥϡgHԇY̼CܤȡٶȤ{ĥߥ󥰙CܤṩޤCDTɼΤΥåȤ˻ŤơCDTԇY˸ߤ_ʤǺϸǤޤ
Posted at 2/1/2026 09:29:20        Only Author  8#
Such an amazing article, I appreciate your generosity in sharing it. The D-AV-DY-23 valid test camp pdf test played a pivotal role in my promotion and pay raiseget it for free today!
