[Linux] No audio, in either output
28
【Linux】 No audio, in either output
Posted at 8/13/2022 13:09:58      View:3611 | Replies:5        Print      Only Author   [Copy Link] 1#
I'm trying to get audio output functioning, but neither the headphone jack nor the HDMI output seem to be working with the Ubuntu build. Is there something I need to do special, here?
Posted at 8/15/2022 11:03:18        Only Author  2#
The output device needs to be selected in the system settings. Or use the latest v1.0.1b firmware, which already supports joint sound card output
Posted at 8/21/2022 09:10:29        Only Author  3#
Is there a way to "update the firmware" without overwriting the entire OS? I'm quite adept at apt update/apt upgrade, but I'm guessing that doesn't work...
vip
Rank: 6Rank: 6
Posted at 8/21/2022 14:38:18        Only Author  4#
Try this version of Armbian (you can choose Ubuntu or Debian) with XFCE or server, they work with HDMI and analog audio. The launch is very simple - download, unpack and burn to an SD card, connect to the device and turn on the power. If desired (after checking all the functions you need) you can easily install the system on eMMC with the standard armbian-config utility.
https://bbs.stationpc.com/forum. ... 6orderby%3Dlastpost
Posted at 1/14/2026 14:30:53        Only Author  5#
It was like a lightbulb moment for me. Plat-Arch-206 Free Dumps offers detailed content for free, designed to help with your studies.
Posted at 2/1/2026 17:31:10        Only Author  6#
Jpshikenの商品はIIC業界の専門家が自分の豊かな知識と経験を利用して認証試験に対して研究出たので品質がいいのC11試験の資料でございます。受験者がJpshikenを選択したら高度専門のC11試験に100%合格することが問題にならないと保証いたします。
