Master Microsoft DP-420 Exam Topics
Posted at 2/10/2026 10:21:19
BTW, DOWNLOAD part of BraindumpsIT DP-420 dumps from Cloud Storage: https://drive.google.com/open?id=1pGnjRWsctAD6rHLA2PbR7S4etvoeb3UC
To help you get the Microsoft exam certification, we provide you with the best valid DP-420 pdf prep material. The customizable and intelligence DP-420 test engine will bring you to a high efficiency study way. The DP-420 test engine contains self-assessment features like marks, progress charts, etc. Besides, the Easy-to-use DP-420 layout will facilitate your preparation for DP-420 real test. You can pass your DP-420 certification without too much pressure.
Our company is professional brand established for compiling DP-420 exam materials for candidates, and we aim to help you to pass the examination as well as getting the related certification in a more efficient and easier way. Owing to the superior quality and reasonable price of our DP-420 Exam Materials, our company has become a top-notch one in the international market. So you can totally depend on our DP-420 exam torrents when you are preparing for the exam. If you want to be the next beneficiary, just hurry up to purchase.
Free PDF Microsoft DP-420 - Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB Perfect Reliable Test LabsOur company always lays great emphasis on offering customers more wide range of choice. Now, we have realized our promise. Our DP-420 exam guide almost covers all kinds of official test and popular certificate. So you will be able to find what you need easily on our website. Every DP-420 exam torrent is professional and accurate, which can greatly relieve your learning pressure. In the meantime, we have three versions of product packages for you. They are PDF version, windows software and online engine of the DP-420 Exam Prep. The three versions of the study materials packages are very popular and cost-efficient now. With the assistance of our study materials, you will escape from the pains of preparing the exam. Of course, you can purchase our DP-420 exam guide according to your own conditions. All in all, you have the right to choose freely. You will not be forced to buy the packages.
Microsoft Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB Sample Questions (Q35-Q40):NEW QUESTION # 35
You have an Azure Cosmos DB for NoSQL account.
You plan 10 create a container named container1. The container1 container will store items that include two properties named nm andage The most commonly executed queries will query container1 for a specific name. The following is a sample of the query.
You need to define an opt-in Indexing policy for container1. The solution must meet the following requirements:
*Minimize the number of request units consumed by the queries.
*Ensure that the _etag property is excluded from indexing.
How should you define the indexing poky? To answer, select the appropriate options in the answer area.
NOTE: Each correct selection Is worth one point.
NEW QUESTION # 36
You have a container in an Azure Cosmos DB for NoSQL account.
You need to create an alert based on a custom Log Analytics query.
Which signal type should you use?
- A. Activity Log
- B. Metrics
- C. Resource Health
- D. Log
NEW QUESTION # 37
You have a container named container1 in an Azure Cosmos DB Core (SQL) API account.
You need to make the contents of container1 available as reference data for an Azure Stream Analytics job.
Solution: You create an Azure function that uses Azure Cosmos DB Core (SQL) API change feed as a trigger and Azure event hub as the output.
Does this meet the goal?
The Azure Cosmos DB change feed is a mechanism to get a continuous and incremental feed of records from an Azure Cosmos container as those records are being created or modified. Change feed support works by listening to container for any changes. It then outputs the sorted list of documents that were changed in the order in which they were modified.
The following diagram represents the data flow and components involved in the solution:
Reference: https://docs.microsoft.com/en-us ... -ecommerce-solution
NEW QUESTION # 38
You have an Azure Cosmos DB for NoSQL account1 that is configured for automatic failover. The account1 account has a single read-write region in West US and a and a read region in East US.
You run the following PowerShell command.
What is the effect of running the command?
- A. The account will be unavailable to writes during the change.
- B. The provisioned throughput for account1 will increase.
- C. A manual failover will occur.
- D. The account will be configured for multi-region writes.
You can use the Set-AzCosmosDBAccountRegion cmdlet to update the regions that an Azure Cosmos DB account uses. You can use this cmdlet to add a region or change the region failover order. The cmdlet requires a resource group name, an Azure Cosmos DB account name, and a list of regions in desired failover order1.
For your scenario, based on the PowerShell command, you are using the Set-AzCosmosDBAccountRegion cmdlet to update the regions for an Azure Cosmos DB account named account1 that is configured for automatic failover. The command specifies two regions: West US and East US. The effect of running the command is that the account will be configured for multi-region writes.
Multi-region writes is a feature of Azure Cosmos DB that allows you to write data to any region in your account and have it automatically replicated to all other regions. This feature provides high availability and low latency for write operations across multiple regions. To enable multi-region writes, you need to specify at least tworegions in your account and set them as write regions2. In your command, you are setting both West US and East US as write regions by using the -IsZoneRedundant parameter with a value of $true for both regions.
NEW QUESTION # 39
You have a container named container1 in an Azure Cosmos DB for NoSQL account named account1 that is set to the session default consistency level. The average size of an item in container1 is 20 KB.
You have an application named App1 that uses the Azure Cosmos DB SDK and performs a point read on the same set of items in container1 every minute.
You need to minimize the consumption of the request units (RUs) associated to the reads by App1. What should you do?
- A. In App1, change the consistency level of read requests to consistent prefix.
- B. In account1, change the default consistency level to bounded staleness.
- C. In App1, modify the connection policy settings.
- D. In account1, provision a dedicated gateway and integrated cache
The cost of a point read for a 1 KB item is 1 RU. The cost of other operations depends on factors such as item size, indexing policy, consistency level, and query complexity1. To minimize the consumption of RUs, you can optimize these factors according to your application needs.
For your scenario, one possible way to minimize the consumption of RUs associated to the reads by App1 is to change the consistency level of read requests to consistent prefix. Consistent prefix is a lower consistency level than session, which is the default consistency level for Azure Cosmos DB. Lower consistency levels consume fewer RUs than higher consistency levels2. Consistent prefix guarantees that reads never see out-of-order writes and that monotonic reads are preserved1. This may be suitable for your application if you can tolerate some eventual consistency.
NEW QUESTION # 40
Our experts are not slavish followers who just cut and paste the content into our DP-420 practice materials, all DP-420 exam questions are elaborately compiled by them. Just a small amount of money, but you can harvest colossal success with potential bright future. So we have the courage and justification to declare the number one position in this area, and choosing DP-420 Actual Exam is choosing success.
Real DP-420 Questions: https://www.braindumpsit.com/DP-420_real-exam.html
Microsoft Reliable DP-420 Test Labs As far as we are concerned, the key to quick upward mobility lies in adapting your excellent personality to the style of the organization you are working in, We provide you with free update for 365 days, so that you can know the latest information for the exam, and the update version for DP-420 exam dumps will be sent to your email automatically, Please be assured that with the help of DP-420 learning materials, you will be able to successfully pass the exam.
If you use numbers and figures in a presentation, you should DP-420 Exam Learning think in terms of tables, If you're looking for a truly comprehensive guide to virtualization, this is the one!
As far as we are concerned, the key to quick upward mobility DP-420 Exam lies in adapting your excellent personality to the style of the organization you are working in, We provide you with free update for 365 days, so that you can know the latest information for the exam, and the update version for DP-420 Exam Dumps will be sent to your email automatically.
DP-420 Certification Training & DP-420 Exam Dumps & DP-420 Study GuidePlease be assured that with the help of DP-420 learning materials, you will be able to successfully pass the exam, We offer money back guarantee if you don't pass the Microsoft Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB DP-420 exam in your first attempt.
We believe that the trial version provided by our DP-420 company will help you know about our study materials well and make the good choice for yourself.
- DP-420 Reliable Test Testking 💢 DP-420 New Dumps Ebook 🧓 DP-420 Examcollection Free Dumps 🛬 Search for 《 DP-420 》 and easily obtain a free download on ☀ [url]www.torrentvce.com ️☀️ 😞DP-420 Certification Dump[/url]
- Clear DP-420 Exam 🦌 DP-420 Mock Exams 👛 DP-420 Reliable Test Testking 🛹 Search for ➠ DP-420 🠰 and easily obtain a free download on { [url]www.pdfvce.com } 🥋DP-420 Examcollection Free Dumps[/url]
- Free PDF Quiz DP-420 - Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB Accurate Reliable Test Labs 🛢 Go to website ➡ [url]www.practicevce.com ️⬅️ open and search for ➡ DP-420 ️⬅️ to download for free 🔅Clear DP-420 Exam[/url]
- DP-420 Reliable Test Testking 🧃 DP-420 New Dumps Ebook 🤏 DP-420 Valid Exam Sims 🌻 Search for 「 DP-420 」 and download it for free on “ [url]www.pdfvce.com ” website 🛸Updated DP-420 Testkings[/url]
- Excellect DP-420 Pass Rate 📴 DP-420 Reliable Test Testking ⏸ Valid DP-420 Test Questions 👳 Download ▛ DP-420 ▟ for free by simply searching on ➡ [url]www.examcollectionpass.com ️⬅️ 🦊DP-420 Reliable Test Testking[/url]
- Reliable DP-420 Test Labs 100% Pass | Trustable Real Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB Questions Pass for sure ☣ Download 「 DP-420 」 for free by simply searching on ⮆ [url]www.pdfvce.com ⮄ 🟫DP-420 Exam Certification[/url]
- Microsoft DP-420 Exam Dumps - Smart Way To Pass Exam ⚒ Immediately open ( [url]www.pass4test.com ) and search for { DP-420 } to obtain a free download 🏹DP-420 Valid Exam Sims[/url]
- Reliable DP-420 Test Labs - Trustable Microsoft Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB - Real DP-420 Questions 🧳 ▷ [url]www.pdfvce.com ◁ is best website to obtain ➤ DP-420 ⮘ for free download 🕢DP-420 New Dumps Ebook[/url]
- Selecting Reliable DP-420 Test Labs - Get Rid Of Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB 🎯 Search for “ DP-420 ” and download exam materials for free through [ [url]www.pass4test.com ] 📘Updated DP-420 Testkings[/url]
- Microsoft DP-420 Practice Test - 100% Exam Passing Guarantee (2026) 📄 Search for ➠ DP-420 🠰 and download it for free immediately on ▛ [url]www.pdfvce.com ▟ 👆DP-420 Valid Study Materials[/url]
- DP-420 Certification Dump 😬 DP-420 Examcollection Free Dumps 🏕 DP-420 Mock Exams 💎 Open ▶ [url]www.pdfdumps.com ◀ and search for ➽ DP-420 🢪 to download exam materials for free 💚Exam DP-420 Tips[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, chillimath.com, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.holmeslist.com.au, www.stes.tyc.edu.tw, learnonline.sprintlearn.net, k12.instructure.com, www.stes.tyc.edu.tw, Disposable vapes
P.S. Free 2026 Microsoft DP-420 dumps are available on Google Drive shared by BraindumpsIT: https://drive.google.com/open?id=1pGnjRWsctAD6rHLA2PbR7S4etvoeb3UC
