Test Oracle 1Z0-182 Topics Pdf - 1Z0-182 Exam Braindumps
Posted at 2/17/2026 19:09:49
View116
Replies1
2026 Latest TrainingDumps 1Z0-182 PDF Dumps and 1Z0-182 Exam Engine Free Share: https://drive.google.com/open?id=1C0ncC4cRC6aTDSK7ynCElmSkLd1tgYKE
TrainingDumps addresses this issue by offering real Oracle 1Z0-182 Questions. TrainingDumps's team of professionals worked tirelessly to create the 1Z0-182 questions, ensuring that applicants have access to the most recent and genuine 1Z0-182 Exam Questions. With TrainingDumps's help, you can pass the 1Z0-182 exam on your first attempt or claim a refund according to certain terms and conditions.
Oracle 1Z0-182 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Moving Data: This section evaluates the expertise of Data Migration Specialists in moving data within Oracle databases. It includes using external tables, executing Oracle Data Pump operations, and distinguishing SQL*Loader commands for importing data efficiently.
| | Topic 2 | - Configuring Oracle Net Services: This section measures the skills of Network Administrators and Database Administrators in configuring Oracle Net Services. It includes identifying administration components, describing connection methods, and ensuring seamless communication between clients and databases.
| | Topic 3 | - Managing Storage: This section tests the knowledge of Storage Engineers in managing storage features such as resumable space allocation, segment space-saving, and block space management. It also includes defining segment characteristics to optimize storage utilization.
| | Topic 4 | - Managing Users, Roles, and Privileges: This domain evaluates the expertise of Security Administrators in implementing user security measures. It focuses on creating and managing users, roles, and privileges to ensure secure access to Oracle databases.
| | Topic 5 | - Displaying Creating and Managing PDBs: This section assesses the knowledge of Cloud Database Architects in creating pluggable databases (PDBs) from seeds or other techniques. It also covers modifying PDB modes and attributes to meet specific application requirements.
| | Topic 6 | - Managing Tablespaces and Datafiles: This section assesses the abilities of Storage Administrators in creating, modifying, and describing tablespaces. It also covers recognizing data storage requirements and understanding datafile placement for efficient storage management.
| | Topic 7 | - Introduction to Performance: This section evaluates the expertise of Performance Analysts in summarizing Oracle database performance management techniques. It includes measuring database performance using SQL execution plans, directives, and advisors to ensure optimal system efficiency.
| | Topic 8 | - Managing Undo: This domain measures the skills of Database Administrators in using undo data effectively. It compares undo data with redo data and explains temporary undo usage for efficient transaction management.
| | Topic 9 | - Describe Oracle Database Architecture: This section of the exam measures the skills of Database Administrators and System Architects in understanding the Oracle database architecture. It covers the configurations of Oracle database instances, memory structures like SGA and PGA, and process structures such as background processes. It also explains the logical and physical database structures, including datafiles, control files, and redo log files.
| | Topic 10 | - Automated Maintenance: This section measures the skills of Database Administrators in describing automated maintenance tasks within Oracle databases. It focuses on applying automated features to streamline routine maintenance activities.
1Z0-182 Exam Braindumps & New 1Z0-182 Cram MaterialsAre you considering the questions that how you can pass the 1Z0-182 exam and get a certificate? The best answer is to download and learn our 1Z0-182 quiz torrent. Our 1Z0-182 exam questions will help you get what you want in a short time. You just need little time to download and install it after you purchase our 1Z0-182 training prep, then you just need spend about 20~30 hours to learn it. We are glad that you are going to spare your precious time to have a look to our 1Z0-182 exam guide.
Oracle Database 23ai Administration Associate Sample Questions (Q71-Q76):NEW QUESTION # 71
Which two statements are true about the tools used to configure Oracle Net Services?
- A. Enterprise Manager Cloud Control can be used to centrally configure net service names for any database server target.
- B. Oracle Net Manager can be used to centrally configure listeners on any database server target.
- C. Oracle Net Manager can be used to locally configure naming methods on a database server.
- D. The lsnrctl utility requires a listener.ora file to exist before it is started.
- E. The Oracle Net Configuration Assistant is only used when running the Oracle installer.
A .False. lsnrctl can start a default listener without listener.ora.
B .True. EMCC provides centralized Net Services configuration.
C .False. NetCA can run standalone, not just during installation.
D .True. Net Manager configures local naming (e.g., TNSNAMES.ORA).
E .False. Net Manager is local, not centralized like EMCC.
NEW QUESTION # 72
Which three are benefits of using temp UNDO when performing DML on global temporary tables?
- A. It reduces I/Os to the SYSAUX tablespace.
- B. It permits DML on global temporary tables even if the database is opened read-only.
- C. It reduces the amount of redo generated.
- D. It reduces I/Os to the SYSTEM tablespace.
- E. It reduces the amount of UNDO stored in the UNDO tablespace.
Answer: C,D,E
Temp UNDO, introduced in Oracle 12c and refined in 23ai, stores undo for global temporary tables (GTTs) in temporary tablespaces:
A . It permits DML on GTTs even if the database is opened read-only.False. In read-only mode, DML on GTTs is allowed regardless of temp UNDO, as GTT data is session-private, but temp UNDO doesn't specifically enable this.
B . It reduces the amount of UNDO stored in the UNDO tablespace.True. Temp UNDO stores undo in the temporary tablespace, reducing usage of the permanent UNDO tablespace.
C . It reduces I/Os to the SYSTEM tablespace.True. By avoiding permanent undo, it reduces metadata updates in the SYSTEM tablespace related to undo management.
D . It reduces the amount of redo generated.True. Temp UNDO changes are not redo-logged to the same extent as permanent undo, minimizing redo generation.
E . It reduces I/Os to the SYSAUX tablespace.False. SYSAUX is unrelated to undo management; temp UNDO affects temporary and SYSTEM tablespaces.
NEW QUESTION # 73
What is the result of the following command? ALTER PLUGGABLE DATABASE PDB1 DISCARD STATE;
- A. It should be used whenever PDB1 open mode needs to be changed.
- B. PDB1 is reverted to its default properties, which includes not to automatically open after a CDB restart.
- C. PDB1 is reverted to its default properties, which includes automatic opening after a CDB restart.
- D. It is unnecessary if the PDB is in the process of being upgraded.
A .False. DISCARD STATE isn't tied to upgrades; it resets PDB startup behavior.
B .True. Discards saved state, reverting PDB1 to manual open mode (not auto-open) after CDB restart.
C .False. Default is not auto-open; it's manual unless explicitly saved as OPEN.
D .False. Used for state management, not general mode changes (e.g., OPEN READ WRITE).
NEW QUESTION # 74
One of your database instances was shut down normally and then started in NOMOUNT state. You then executed this command: ALTER DATABASE MOUNT; Which two of these actions are performed?
- A. Online redo logs are opened.
- B. Online data files are opened.
- C. Oracle shared memory structures are allocated.
- D. The initialization parameter file is read.
- E. Control files are read.
- F. The alert log has instance startup details written to it.
Answer: E,F
A .False. Data files open in OPEN.
B .False. Redo logs open in OPEN.
C .False. PFILE/SPFILE is read at NOMOUNT.
D .False. SGA is allocated at NOMOUNT.
E .True. Alert log records mount event.
F .True. Control files are read in MOUNT.
NEW QUESTION # 75
Which two actions can you perform using DBCA for an existing database?
- A. Create a template that can be used to clone the database.
- B. Change the server mode from dedicated to shared, and vice versa.
- C. Create nonstandard block size tablespaces.
- D. Change the character set.
- E. Create an additional listener.
A .False. DBCA can't change character sets post-creation.
B .False. Listeners are managed via NetCA or lsnrctl.
C .True. DBCA can switch server modes for existing DBs.
D .False. Tablespaces are created via SQL, not DBCA for existing DBs.
E .True. DBCA can generate clone templates from existing DBs.
NEW QUESTION # 76
In order to meet the time requirement of our customers, our experts carefully designed our 1Z0-182 test torrent to help customers pass the exam in a lot less time. If you purchase our 1Z0-182 guide torrent, we can make sure that you just need to spend twenty to thirty hours on preparing for your exam before you take the exam, it will be very easy for you to save your time and energy. So do not hesitate and buy our 1Z0-182 study torrent, we believe it will give you a surprise, and it will not be a dream for you to pass your Oracle Database 23ai Administration Associate exam and get your certification in the shortest time.
1Z0-182 Exam Braindumps: https://www.trainingdumps.com/1Z0-182_exam-valid-dumps.html
- Avail Reliable Test 1Z0-182 Topics Pdf to Pass 1Z0-182 on the First Attempt 🧧 Easily obtain free download of 1Z0-182 by searching on ➡ [url]www.examcollectionpass.com ️⬅️ 🔝Cost Effective 1Z0-182 Dumps[/url]
- 2026 Test 1Z0-182 Topics Pdf: Oracle Database 23ai Administration Associate C Unparalleled 1Z0-182 100% Pass Quiz 💃 Download ▷ 1Z0-182 ◁ for free by simply entering [url]www.pdfvce.com website 🪑Testing 1Z0-182 Center[/url]
- Avail Reliable Test 1Z0-182 Topics Pdf to Pass 1Z0-182 on the First Attempt 🤜 Simply search for ➥ 1Z0-182 🡄 for free download on ⏩ [url]www.prepawaypdf.com ⏪ 🌮Test 1Z0-182 Testking[/url]
- Reliable 1Z0-182 Study Guide ⏺ 1Z0-182 Valid Exam Dumps ⬅ Valid 1Z0-182 Test Registration 🎑 Open ⏩ [url]www.pdfvce.com ⏪ enter ▷ 1Z0-182 ◁ and obtain a free download 🧥Useful 1Z0-182 Dumps[/url]
- Dumps 1Z0-182 Questions 🔌 Valid 1Z0-182 Test Registration 🔤 1Z0-182 Current Exam Content 💷 Search for ▛ 1Z0-182 ▟ and obtain a free download on ➠ [url]www.practicevce.com 🠰 🐴Testing 1Z0-182 Center[/url]
- 1Z0-182 Latest Dumps Files 🚝 1Z0-182 Pass Exam 🧒 Valid 1Z0-182 Test Registration 🕠 The page for free download of ⮆ 1Z0-182 ⮄ on [url]www.pdfvce.com will open immediately 🦑Testing 1Z0-182 Center[/url]
- 2026 1Z0-182: Oracle Database 23ai Administration Associate CHigh-quality Test Topics Pdf 😋 Open website ⇛ [url]www.testkingpass.com ⇚ and search for 1Z0-182 for free download 🏁Reliable 1Z0-182 Study Guide[/url]
- Upgrade Your Skills and Easily Obtain Oracle 1Z0-182 Certification 👻 Download ➽ 1Z0-182 🢪 for free by simply entering ➥ [url]www.pdfvce.com 🡄 website 💉Valid 1Z0-182 Test Registration[/url]
- 1Z0-182 Valid Dumps Book 🪀 1Z0-182 Valid Exam Dumps 🕯 Dumps 1Z0-182 Questions 🧧 Go to website ▷ [url]www.validtorrent.com ◁ open and search for ✔ 1Z0-182 ️✔️ to download for free 🕑Study 1Z0-182 Materials[/url]
- [url=https://harborviewvilla.com/?s=Cost%20Effective%201Z0-182%20Dumps%20%f0%9f%94%b8%201Z0-182%20Exam%20Questions%20Pdf%20%f0%9f%a4%a2%20Useful%201Z0-182%20Dumps%20%f0%9f%a7%92%20Search%20for%20%e2%9e%a1%201Z0-182%20%ef%b8%8f%e2%ac%85%ef%b8%8f%20and%20download%20exam%20materials%20for%20free%20through%20[%20www.pdfvce.com%20]%20%f0%9f%a7%b5New%201Z0-182%20Study%20Materials]Cost Effective 1Z0-182 Dumps 🔸 1Z0-182 Exam Questions Pdf 🤢 Useful 1Z0-182 Dumps 🧒 Search for ➡ 1Z0-182 ️⬅️ and download exam materials for free through [ www.pdfvce.com ] 🧵New 1Z0-182 Study Materials[/url]
- Valid 1Z0-182 Test Registration 🌟 1Z0-182 Valid Test Question 🕔 Testing 1Z0-182 Center 🎤 Download 1Z0-182 for free by simply entering ▛ [url]www.testkingpass.com ▟ website 🍕1Z0-182 Latest Dumps Files[/url]
- myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, mathematicsoutlet.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, lillymcenter.com, Disposable vapes
