[General] C_S4CPB_2508ԇYԡC_S4CPB_2508֥󥺽̲
99
General C_S4CPB_2508ԇYԡC_S4CPB_2508֥󥺽̲
Posted at 2/14/2026 18:16:12      View102 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. CertJukenGoogle DriveǹФƤoϤ¤C_S4CPB_2508ףhttps://drive.google.com/open?id=19gY2vk0Y2-gF0bGhcuS0Fe5bHhD9kUyr
Ugμ٤ʰkչ˰餤ޤޤयˡĥ`Ȥˤʤ뤳ȤƤ뤳ȤڤܤƤޤ C_S4CPB_2508¤ѧYϤϡ`륨`ȤˤʤꤿयˡνȤʤޤ C_S4CPB_2508ԇYΜʂƤ򾡤̕rgvBJȡäС˽Τ褦ʴIζयΥ``עĿ򼯤뤳Ȥפˤʤꡢdz˺gˤʤޤ C_S4CPB_2508ѧɤơयˡPЈmФ¤ä뤳ȤǤޤ
SAP C_S4CPB_2508 JԇYγ}죺
ȥԥå}
ȥԥå 1
  • ԤȽyϣΥǤϡӥͥץѩ`ȤΥyץڤӥɥХɤΒץʹäSAP S
  • 4HANA CloudΙCܤ򒈏uޤޤɥĩ`ɤΥӥͥץ򥵥ݩ`Ȥ뤿ˡSAPƥⲿץꥱ`yϤuޤ
ȥԥå 2
  • 饦ɥԥ`ƥTSAP Cloud ERPλAΥǤϡ륳󥵥륿ȤΥu饦ɥԥ`ƥ󥰤ԭtSAP S
  • 4HANA Cloud ERPλAvA֪RW_ޤYߤϡ饦ɥ`΁饦ɤˤERPҪSAPΥ`IΥǥȥ󥹥ե``ɤΤ褦˥ݩ`Ȥ뤫Ǥޤ
ȥԥå 3
  • ɤSAP Fiori LaunchpadΥǤϡ륳󥵥륿ȤΥuͤҪ򜺤褦˥ƥ򘋳ɤW_ޤޤSAP Fiori Launchpadʹäƥ``ڥꥨ󥹤ѩ`ʥ饤饦ɭhڤǥӥͥ`֪Ruޤ
ȥԥå 4
  • ԇYǤϡӥͥץѩ`ȤΥugװˤ륯饦ɥե`ȤΥץ`ΒäصäƤޤޤmФʥץȥ`ΘBȡ˜mϥ`åפλäͨҪ˜SAPץmϤ뤳ȤҪԤ⏊{Ƥޤ
ȥԥå 5
  • 饦ɤο˻Ťgװ`ΘB˜ʤmϤ`åפΌgʩ:
C_S4CPB_2508֥󥺽̲ & C_S4CPB_2508~ϸŤơŤԇY˺ϸ񤷤ƤuƷʹäᡢѧYϤϡC_S4CPB_2508ԇYǰˌgHΥƥȭhṩޤߥ`ᡢԇYhԇYץԇYҪ_Ǥޤ C_S4CPB_2508ѧ̲ϱˤʤ_ˤʤꡢʤҪȤ뤨Ƥޤ C_S4CPB_2508ԇYν̲ĤϤʤ⤷ƤꡢʤäˤʤͬФ˼äƤޤ
SAP Certified Associate - Implementation Consultant - SAP S/4HANA Cloud Public Edition J C_S4CPB_2508 ԇY} (Q18-Q23):| # 18
Which of the following analyses can you create from the Manage KPIs and Reports app? Note: There are 3 correct answers to this question.
  • A. SAC Stories
  • B. Lumira Dashboards
  • C. Review Booklets
  • D. Object Views
  • E. Multidimensional Reports
⣺ACE
h
The Manage KPIs and Reports app is a single platform for creating all analytical applications using KPIs, reports, multidimensional reports, and stories. You can create applications that can be launched directly from SAP Fiori launchpad. The app is integrated with SAP Analytics Cloud, which allows you to create and view stories. A story is a presentation-style document that uses charts, tables, and other visualizations to display data insights. A review booklet is a collection of stories that can be used to share information with stakeholders. A multidimensional report is a type of report that allows you to analyze data from multiple dimensions and measures. You can create and view multidimensional reports from the app. An object view is a type of report that displays data for a single object, such as a customer or a product. You cannot create or view object views from the app. A Lumira dashboard is a type of dashboard that uses SAP Lumira to create and display data visualizations. You cannot create or view Lumira dashboards from the app. References = Manage KPIs and Reports, Stories, Review Booklets, [Multidimensional Reports]
| # 19
Where are the manual test cases created for customer User Acceptance Testing?
  • A. SAP Signavio Process Navigator
  • B. Test Automation Tool
  • C. SAP Cloud ALM
  • D. SAP Solution Manager
⣺C
| # 20
You are using the Test Automation Tool.
When do you define a data variant??
  • A. After binding a process step field to a Test Data Container.
  • B. After customizing a test process.
  • C. After providing consent for Post-Upgrade Testing.
  • D. After creating a test plan.
⣺C
| # 21
Where do you enable a customer-specific field to be available for Uls and reports relevant for the same business context?
  • A. In the Runtime Authoring mode
  • B. In the Maintain SAP Business Technology Platform Extensions app
  • C. In the Extensibility Cockpit app
  • D. In the Custom Fields app
⣺D
h
You enable a customer-specific field to be available for UIs and reports relevant for the same business context in the Custom Fields app. The Custom Fields app allows you to create and manage custom fields for business objects in SAP S/4HANA Cloud, public edition. You can define the properties of the custom fields, such as the label, data type, length, and default value. You can also specify the UIs and reports where you want the custom fields to appear, and the business context that determines the visibility and authorization of the custom fields. The Custom Fields app also enables you to activate the custom fields and generate the corresponding CDS views and OData services for consumption by other applications. References = Using the Key-User In- App Extensibility Tools in SAP S/4HANA Cloud Public Edition, Custom Fields and Logic
| # 22
Which type of testing should be done after a release upgrade has occurred?
  • A. Regression tests
  • B. Integration tests
  • C. User Acceptance tests
  • D. String tests
⣺A
h
Regression tests are a type of testing that should be done after a release upgrade has occurred. Regression tests are performed to ensure that the existing functionality of the system is not affected by the changes introduced by the new release. Regression tests help to identify any defects or errors that may have been introduced or uncovered by the release upgrade. Regression tests are part of the quality assurance process and are essential for ensuring the stability and reliability of the system. References = SAP S/4HANA Cloud, Public Edition - All Learning Journeys | SAP Learning -> Implementing SAP S/4HANA Cloud Public Edition
-> Unit 5: Quality Assurance -> Lesson: Performing Regression Tests
| # 23
CertJukenuƷˤԇð椬ꡢuƷʤͨꡢC_S4CPB_2508ʂ䥬ɤWebȤEȡC_S4CPB_2508ɼoϥǥṩǤ뤳Ȥζޤ͘ǰ˵uƷˤĤ뤳ȤǤޤˡ`ǰMǤϤϡC_S4CPB_2508ԇYȥȤʤmƤ뤫ɤӑǤޤˡͨΤ͘ˤʤȡयλTSAP Certified Associate - Implementation Consultant - SAP S/4HANA Cloud Public Edition`ӥ򤪘Sߤޤ
C_S4CPB_2508֥󥺽̲: https://www.certjuken.com/C_S4CPB_2508-exam.html
BONUS CertJuken C_S4CPB_2508פһoϤǥ`ɣhttps://drive.google.com/open?id=19gY2vk0Y2-gF0bGhcuS0Fe5bHhD9kUyr
