[General] Tableau TDA-C01 Test Discount - TDA-C01 Technical Training
104
General Tableau TDA-C01 Test Discount - TDA-C01 Technical Training
Posted at 2/3/2026 16:13:15      View135 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free & New TDA-C01 dumps are available on Google Drive shared by BraindumpsVCE: https://drive.google.com/open?id=1r0j4gzzey_92cnGM288Z_ieNpLalVpDC
We have dedicated staff to update all the content of TDA-C01 exam questions every day. So you dont need to worry about that you buy the materials so early that you cant learn the last updated content. And even if you failed to pass the exam for the first time, as long as you decide to continue to use TDA-C01 torrent prep, we will also provide you with the benefits of free updates within one year and a half discount more than one year. TDA-C01 Test Guide use a very easy-to-understand language. So even if you are a newcomer, you don't need to worry that you cant understand the contents. Industry experts hired by TDA-C01 exam questions also explain all of the difficult professional vocabulary through examples, forms, etc. You can completely study alone without the help of others.
The Tableau Certified Data Analyst (TDA-C01) exam questions are being offered in three different formats. The names of these formats are TDA-C01 desktop practice test software, web-based practice test software, and PDF dumps file. The TDA-C01 desktop practice test software and web-based practice test software both give you real-time Tableau TDA-C01 exam environment for quick and complete exam preparation.
Tableau TDA-C01 Technical Training, New TDA-C01 Test PrepBraindumpsVCE customizable practice exams (desktop and web-based) help students know and overcome their mistakes. The customizable Tableau TDA-C01 practice test means that the users can set the Questions and time according to their needs so that they can feel the real-based exam scenario and learn to handle the pressure. The updated pattern of Tableau TDA-C01 Practice Test ensures that customers don't face any real issues while preparing for the test.
Tableau TDA-C01 (Tableau Certified Data Analyst) Certification Exam is an industry-recognized certification program offered by Tableau, one of the leading data visualization software providers in the world. Tableau Certified Data Analyst certification is designed for professionals who want to validate their skills in data analysis using Tableau, and it is aimed at data analysts, business analysts, and other professionals who want to demonstrate their proficiency in data visualization and analysis.
Tableau TDA-C01 certification is a valuable credential for anyone who wants to demonstrate their expertise in Tableau. Tableau Certified Data Analyst certification validates that the holder has a thorough understanding of Tableau's features and functionalities, and is able to use the tool to analyze and visualize data effectively. It is especially useful for data analysts who work in organizations that rely heavily on data-driven decision making, as it demonstrates their ability to use Tableau to extract insights from complex data sets.
Tableau TDA-C01 Certification Exam consists of multiple-choice questions and is designed to test a candidate's knowledge and skills in using Tableau to analyze and visualize data. TDA-C01 exam covers different areas of Tableau, including data connection and preparation, visualization, analysis, and dashboard creation. Candidates will have two hours to complete the exam, and they must score at least 75% to pass. Successful candidates will receive a Tableau TDA-C01 certification, which is valid for two years and can be renewed by passing a recertification exam.
Tableau Certified Data Analyst Sample Questions (Q109-Q114):NEW QUESTION # 109
Open the link to Book1 found on the desktop. Open the Histogram worksheet and use the Superstone data source.
Create a histogram on the Quantity field by using bin size of 3.
check the steps below in explanation
To create a histogram on the Quantity field by using bin size of 3, you need to do the following steps:
Open the link to Book1 found on the desktop. This will open the Tableau workbook that uses the Superstore data source.
Click on the Histogram tab at the bottom of the workbook to open the Histogram worksheet. You will see a blank worksheet with no marks.
Right-click on Quantity in the Measures pane and select Create Bins from the menu. This will open a dialog box that allows you to create bins for the Quantity field. Bins are groups of values that are treated as one unit in a histogram.
Enter 3 in the Size of bins text box. This will set the bin size to 3, which means that each bin will contain values that are 3 units apart. For example, one bin will contain values from 0 to 2, another bin will contain values from 3 to 5, and so on.
Click OK to create the bins. You will see a new field named Quantity (bin) in the Measures pane with a # sign next to it.
Drag Quantity (bin) from the Measures pane to Columns on the worksheet. This will create a histogram that shows the distribution of Quantity by bins. You will see bars that represent the frequency or count of values in each bin.
Optionally, you can adjust the width, color, and labels of the bars by using the options on the Marks card. You can also add filters, tooltips, or annotations to enhance your histogram.
NEW QUESTION # 110
You have the following calculated fields in a worksheet.
[Calc1] = DATEADD ('year', -1, TODAY ())
[Calc2] = DATETRUNC ( 'month' , DATEADD ('year', -1, TODAY ())
You want to calculate the month to date value of the prior year.
How should you complete the formula? (Drag the appropriate Options to the Answer Area and drop into the correct locations.)
Finding the Month-to-Date Values for the Prior Year
[DATEADD Function]
[DATETRUNC Function]
NEW QUESTION # 111
A Data Analyst has the following dataset.
The analyst wants to create a parameter to dynamically filter the data to produce the following results based on quantity being above X value.
Which two types of parameters should the analyst use to produce the results? (Choose two)
  • A. Integer
  • B. Float
  • C. Boolean
  • D. Date
NEW QUESTION # 112
Open the Link to Book1 found on the desktop. Open Map worksheet and use Superstore data source.
Create a filed map to show the distribution of total Sales by State across the United States.
check the steps below in explanation.
To create a filled map to show the distribution of total Sales by State across the United States, you need to do the following steps:
Click on the Map tab at the bottom of the workbook to open the Map worksheet. You will see a blank worksheet with no marks.
Drag State from the Dimensions pane to Detail on the Marks card. This will create a map that shows each state as a mark. You may need to zoom in or out to see the whole map.
Drag Sales from the Measures pane to Color on the Marks card. This will create a filled map that shows the distribution of total Sales by State across the United States. The color legend will show you the range of values and colors for Sales.
Optionally, you can adjust the color scheme, transparency, size, and borders of the marks by clicking on the Color menu on the Marks card. You can also add labels, tooltips, or filters to enhance your map.
References: https://help.tableau.com/current/pro/desktop/en-us/maps.htm
https://help.tableau.com/current ... ps_howto_filled.htm
https://help.tableau.com/current ... roperties_color.htm
NEW QUESTION # 113
You have a dataset that contains daily sales by business segment from 2017 to the present You want to use monthly historical trends to predict sales by segment in the future Which three actions should you perform m order?
(Place the three correct options in order Use the arrows to move Options lo Answer Area I In Answer Area arrows to re order the options.)
The correct order of the three actions is:
* Add the date to the Columns shelf. Add the segment and the sales to the Rows shelf.
* Aggregate the date to month and year.
* From the Analytics pane, drag Forecast to the worksheet.
The first action is to add the date to the Columns shelf and the segment and the sales to the Rows shelf. This will create a line chart that shows the daily sales by segment over time. You can use the Show Me menu to choose a line chart if it is not selected by default.
The second action is to aggregate the date to month and year. This will group the daily sales into monthly sales and show the yearly trend. You can right-click on the date field on the Columns shelf and select Month (January 2017) from the menu. You can also drag Year from the Dimensions pane to the Columns shelf before or after Month.
The third action is to drag Forecast from the Analytics pane to the worksheet. This will add a forecast that predicts future sales by segment based on historical trends. You can customize the forecast by clicking on it and using the options on the Marks card.
The other options are not relevant for this scenario. Adding a trend line would show a linear or nonlinear relationship between two measures, but not a prediction of future values. Creating a calculated field that uses the model quantile function would return a value from a statistical model based on a given quantile, but not a forecast.
References: https://help.tableau.com/current/pro/desktop/en-us/analytics.htm https://help.tableau.com/current
/pro/desktop/en-us/buildmanual_shelves.htm https://help.tableau.com/current/pro/desktop/en-us/dates.htm
https://help.tableau.com/current ... lytics_forecast.htm https://help.tableau.com/current/pro
/desktop/en-us/functions_functions_statistical.htm#MODEL_QUANTILE
NEW QUESTION # 114
If you study on our test engine, your preparation time of the TDA-C01 guide braindumps will be greatly shortened. Firstly, the important knowledge has been picked out by our professional experts. You just need to spend about twenty to thirty hours before taking the Real TDA-C01 Exam. In addition, the relevant knowledge will be easy to memorize. Learning our TDA-C01 study quiz can also be a pleasant process. The saved time can be used to go sightseeing or have a rest.
TDA-C01 Technical Training: https://www.braindumpsvce.com/TDA-C01_exam-dumps-torrent.html
2026 Latest BraindumpsVCE TDA-C01 PDF Dumps and TDA-C01 Exam Engine Free Share: https://drive.google.com/open?id=1r0j4gzzey_92cnGM288Z_ieNpLalVpDC
