Availability of RK3399 Max & Plus boards and availability of all accessories
Posted at 2/19/2018 19:31:47
When will the Firefly-RK3399 Plus 4gb + 32gb and the Firefly-RK3399 Max 4gb 128 gb boards be available in sufficient numbers internationally, especially on Amazon?
And why us there no mention of most the the Smartfly accessories, especially the PCIe M.2 to SATA adapter boards? The only place you can source this crucial bit of kit is on Aliexpress.
Come on guy's, if you want the Smartfly (Firefly) range to be a huge success, professionalism and proper marketing is crucial. That means;
Visibility on the primary Western online stores such as Amazon and Ebay.
Proper, continuously available stocks at these online stores
If you indicate you are out of stock, it is only good business practise to mention why and what the ETA for new stock is going to be.
Full complement of accessories indicated on Amazon and Ebay. On Amazon you show photographs of the Firefly RK3399 with a hard drive in the acrylic enclosure, yet your PCIe M2 to SATA adapter is not mentioned at all. The only accessory I came across is the OV13850 Camera Module.
Hope to own your Firefly RK3399 4Gb + 128Gb soon
Hendrik Lubbe |
