Top 1Z0-1042-25 Questions - 1Z0-1042-25 Valid Exam Sims
Posted at 1/26/2026 21:26:16
BONUS!!! Download part of ExamcollectionPass 1Z0-1042-25 dumps for free: https://drive.google.com/open?id=1_JebF74C1je7kEXZL8D9G46BH63dO7FI
If you want to pass your exam just one time, then we will be your best choice. 1Z0-1042-25 questions and answers are edited by professional experts, and they have the professional knowledge in this field, therefore 1Z0-1042-25 exam materials are high-quality. In addition, 1Z0-1042-25 training materials contain most of the knowledge point for the exam, and you can have a good command of the exam dumps as well as improve your professional ability in the process of learning. You can also obtain the download link and password within ten minutes for 1Z0-1042-25 Exam Dumps, so you can start your learning immediately.
Oracle 1Z0-1042-25 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Creating Orchestrated Integrations: This section tests the knowledge of Orchestration Developers and Business Process Analysts in managing orchestrated integrations within OIC. It includes using lookups, data mappers, and custom JavaScript libraries, configuring orchestration flow actions, implementing file handling options, and leveraging the fault-handling framework to manage errors effectively.
| | Topic 2 | - Creating Scheduled Integrations: This domain measures the skills of Automation Engineers and Cloud Administrators in defining integration schedules and converting scheduled integrations to app-driven ones. It also includes using scheduled parameters to automate workflows efficiently.
| | Topic 3 | - Using OIC Connections & Adapters: This section evaluates the expertise of Integration Developers and Solution Architects in creating and configuring OIC connections. It includes setting up trigger and invoke connections, understanding the role of the Connectivity Agent, and effectively using adapters to connect cloud and on-premises applications seamlessly.
| | Topic 4 | - Testing, Monitoring, and Troubleshooting Integrations: This section assesses the abilities of Support Engineers and Integration Administrators in managing integration lifecycles. It includes activating and deactivating integrations, testing REST-triggered integrations, importing and exporting integrations, as well as monitoring and troubleshooting integration instances to ensure smooth operations.
| | Topic 5 | - Getting Started with OIC Integrations: This section of the exam measures the skills of Integration Specialists and Cloud Engineers in understanding the foundational components of Oracle Integration Cloud (OIC). It covers key integration concepts, how integrations work, and web services fundamentals such as WSDL, SOAP, REST, and JSON. The focus is on building a strong understanding of OIC’s integration capabilities.
1Z0-1042-25 Valid Exam Sims - Latest 1Z0-1042-25 Exam AnswersWhat kind of services on the 1Z0-1042-25 training engine can be considered professional, you will have your own judgment. We will give you the most professional answers on the 1Z0-1042-25 practice engine in the first time. But I would like to say that our 1Z0-1042-25 Study Materials must be the most professional of the 1Z0-1042-25 exam simulation you have used. Our experts who compiled them are working on the subject for years.
Oracle Cloud Infrastructure 2025 Application Integration Professional Sample Questions (Q56-Q61):NEW QUESTION # 56
You are developing an integration in Oracle Integration (OIC) to integrate two systems and wish to use an OIC Lookup. The goal is to transform customer status codes between the two systems. Which set of steps are essential for correctly utilizing the Lookup?
- A. Create a connection between the two systems, then use a SQL query to access the Lookup table directly, and map the customer status codes.
- B. Design a custom script to perform the transformation, and then use the Lookup function within a Map action to reference the script and transform the customer status codes.
- C. Create a Lookup table with the mappings of customer status codes, and then use the Lookup function within a Map action to reference the table and perform the transformation.
- D. Define a Lookup table containing the customer status code mappings, and then use the Invokeaction to call a web service for the transformation.
Lookup Usage:
D:True-create table, use lookupValue in mapper.
NEW QUESTION # 57
Your design of an asynchronous Oracle Integration Cloud (OIC) integration flow includes the requirement for additional processing logic that is conditionally based on the results returned to the integration instance from earlier external service invocations. You decide to leverage the Switch action to facilitate this implementation.
Which is a valid consideration concerning the configuration and capabilities of the Switch action?
- A. XPath version 2.0 functions can be used to create more complex conditional expressions for a branch.
- B. The Switch action must include an otherwise branch.
- C. Data objects returned from actions within a branch of a switch action are not visible in the main flow of the integration after the switch action.
- D. Nested switch actions are not supported, and you may need to create more complex conditional expressions, if necessary.
XPath version 2.0 functions can be used within the Switch action to create more complex conditional expressions for defining branches in Oracle Integration Cloud.
NEW QUESTION # 58
Which two statements are true about the Internet of Things (IoT)?
- A. Using IoT, hospitality-based businesses can track customer behavior to deliver rewards and tailored services.
- B. IoT is not useful in asset tracking scenarios due to the unavailability of low-cost connected devices and sensors.
- C. Different IoT approaches need to integrate technologies like mobile, cloud, big data, and analytics, connecting everyday objects to each other and the Internet.
- D. Cloud technology is well-suited to enable IoT, offering agility, low costs, and excellent resource utilization.
NEW QUESTION # 59
There are use cases in which you need to perform an advanced XSL task that you cannot perform in Oracle Integration Cloud (OIC) data mapper. To perform advanced mapping tasks, you decide to use an external XSL mapper and then import the .xml back to your integration.
Which is NOT a valid consideration when handling this use case?
- A. The exported archive must be imported into an Oracle Service Bus project in JDeveloper.
- B. You must export the entire integration that contains one or more .xml files.
- C. The exported archive file can include a map file that is largely complete in content or a map file that is empty of content.
Importing the exported archive into an Oracle Service Bus project in JDeveloper is incorrect. The external XSL mapper will be imported back into the Oracle Integration Cloud, not an OSB project in JDeveloper.
NEW QUESTION # 60
Which of the following is NOT a capability of the Oracle Integration (OIC) REST Adapter when configured to consume external REST APIs?
- A. Consumes REST APIs protected using OAuth Client Credentials
- B. Supports asynchronous REST API invocations with callback URLs
- C. Supports JSON, XML, binary, and URL-form-encoded payloads
- D. Supports WebSocket connections for real-time communication
REST Adapter:
D:False-no WebSocket support.
NEW QUESTION # 61
It is not hard to find that there are many different kinds of products in the education market now. It may be difficult for users to determine the best way to fit in the complex choices. We can tell you with confidence that the 1Z0-1042-25 practice materials are superior in all respects to similar products. First, users can have a free trial of 1Z0-1042-25 test prep, to help users better understand the 1Z0-1042-25 Study Guide. If the user discovers that the product is not appropriate for him, the user can choose another type of learning material. Respect the user's choice, will not impose the user must purchase the 1Z0-1042-25 practice materials. We can meet all the requirements of the user as much as possible, to help users better pass the qualifying exams.
1Z0-1042-25 Valid Exam Sims: https://www.examcollectionpass.com/Oracle/1Z0-1042-25-practice-exam-dumps.html
- 1Z0-1042-25 Training Materials are Worthy for You to Buy It - [url]www.exam4labs.com 👛 Search on ⮆ www.exam4labs.com ⮄ for ▶ 1Z0-1042-25 ◀ to obtain exam materials for free download 🧪Certification 1Z0-1042-25 Dumps[/url]
- 1Z0-1042-25 Exam Tests 👺 Exam 1Z0-1042-25 Revision Plan 🩲 1Z0-1042-25 Exam Dumps Demo 🐈 Search for [ 1Z0-1042-25 ] and easily obtain a free download on ⇛ [url]www.pdfvce.com ⇚ 🚔1Z0-1042-25 Exam Tests[/url]
- Vce 1Z0-1042-25 Files 🪓 Braindumps 1Z0-1042-25 Pdf 🍡 Reliable 1Z0-1042-25 Exam Sims 🔱 Enter ⇛ [url]www.prep4sures.top ⇚ and search for ( 1Z0-1042-25 ) to download for free 🐫1Z0-1042-25 Exam Tests[/url]
- 1Z0-1042-25 Guaranteed Questions Answers 🌇 Latest Test 1Z0-1042-25 Simulations 😱 Latest 1Z0-1042-25 Braindumps Pdf 🦞 The page for free download of 「 1Z0-1042-25 」 on ➥ [url]www.pdfvce.com 🡄 will open immediately 🐄1Z0-1042-25 Pdf Torrent[/url]
- Test 1Z0-1042-25 Book 🐽 1Z0-1042-25 Testking Learning Materials 🧩 Vce 1Z0-1042-25 Files 📐 Download { 1Z0-1042-25 } for free by simply entering ➡ [url]www.prep4away.com ️⬅️ website 🐗1Z0-1042-25 Exam Tests[/url]
- Pass Guaranteed Quiz 2026 Oracle 1Z0-1042-25: Unparalleled Top Oracle Cloud Infrastructure 2025 Application Integration Professional Questions 🐇 Enter [ [url]www.pdfvce.com ] and search for ☀ 1Z0-1042-25 ️☀️ to download for free 🧾Braindump 1Z0-1042-25 Free[/url]
- TOP Top 1Z0-1042-25 Questions - Valid Oracle 1Z0-1042-25 Valid Exam Sims: Oracle Cloud Infrastructure 2025 Application Integration Professional ⬇ Search for { 1Z0-1042-25 } and download it for free on ➡ [url]www.dumpsquestion.com ️⬅️ website 😴Latest 1Z0-1042-25 Braindumps Pdf[/url]
- Braindumps 1Z0-1042-25 Pdf 🚾 1Z0-1042-25 Pdf Torrent 🧀 Braindump 1Z0-1042-25 Free 🕢 Enter ➽ [url]www.pdfvce.com 🢪 and search for ☀ 1Z0-1042-25 ️☀️ to download for free 😶Latest 1Z0-1042-25 Braindumps Pdf[/url]
- Latest 1Z0-1042-25 Braindumps Pdf ⛪ 1Z0-1042-25 Exam Dumps Demo 🥫 1Z0-1042-25 Guaranteed Questions Answers 🌺 Search for ➥ 1Z0-1042-25 🡄 and download exam materials for free through 【 [url]www.examcollectionpass.com 】 🎀1Z0-1042-25 Exam Dumps Demo[/url]
- 100% Pass Quiz 2026 Efficient 1Z0-1042-25: Top Oracle Cloud Infrastructure 2025 Application Integration Professional Questions 🩺 Search on { [url]www.pdfvce.com } for ▛ 1Z0-1042-25 ▟ to obtain exam materials for free download 🕛Reliable 1Z0-1042-25 Exam Sims[/url]
- 1Z0-1042-25 Real Brain Dumps 🍚 1Z0-1042-25 Exam Dumps Demo ⭐ 1Z0-1042-25 Exam Dumps Demo 🎲 Open ➽ [url]www.exam4labs.com 🢪 and search for ⏩ 1Z0-1042-25 ⏪ to download exam materials for free 🦝1Z0-1042-25 Exam Dumps Demo[/url]
- myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
DOWNLOAD the newest ExamcollectionPass 1Z0-1042-25 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1_JebF74C1je7kEXZL8D9G46BH63dO7FI
