[Linux] Can't boot from SATA/NVMe/USB
152
Linux Can't boot from SATA/NVMe/USB
Posted at 8/11/2022 19:19:16      View3331 | Replies6        Print      Only Author   [Copy Link] 1#
I cant' understand - why I can't boot from SATA for example, using your SDK.
I have done everything like always - created bootable SATA device, plug it, then:
setenv bootcmd 'scsi scan; scsi dev 0; ext4load scsi 0:1 0x00400000 /boot/Image-5.10.66;ext4load scsi 0:1 0x0a100000 /boot/rk3588-firefly-itx-3588j.dtb;setenv bootargs console=ttyFIQ0 root=/dev/sda1 rw rootwait; booti 0x00400000 - 0x0a100000'
run bootcmd
And I can see that bootargs var is ignoring. Then, to prove it, I wrote "console=nothing", but it booting in my SDCARD like always. How I can see - bootargs var completely ignoring.
I tried to find kernel option CMDLINE_OVERRIDE that can cause such effect, but there is no such option you using to compile kernel. So, I can't understand what to do...
Posted at 8/11/2022 19:23:29        Only Author  2#
I can't use such an option like hardcoding my BOOTCMD in Linux Device Tree, because I need to create hot boot from each bootable device - I need to have an ability to boot from SD/SATA/NVMe/USB/EMMC - without recompiling something.
Also I need GUI for this process...
Posted at 1/17/2026 15:47:00        Only Author  3#
Die PECB NIS-2-Directive-Lead-Implementer Zertifizierungsprfung ist heutztage in der konkurrenzfähigen IT-Branche immer beliebter geworden. Immer mehr Leute haben die PECB NIS-2-Directive-Lead-Implementer Prfung abgelegt. Aber ihre Schwierigkeit nimmt doch nicht ab. Es ist schwer, die PECB NIS-2-Directive-Lead-Implementer Prfung zu bestehen, weil sie sowieso eine autoritäre Prfung ist, die Computerfachkenntnisse und die Fähigkeiten zur Informationstechnik prft. Viele Leute haben viel Zeit und Energie auf die PECB NIS-2-Directive-Lead-Implementer Zertifizierungsprfung aufgewendet.
Posted at 1/25/2026 14:53:46        Only Author  4#
Your article was a pleasant surprise, thank you for sharing it. Here are the free PEGACPBA24V1 reliable braindumps sheet materials. Best of luck to everyone!
Posted at 1/30/2026 16:00:40        Only Author  5#
The content is excellent, so Im liking it now. Taking on the FCSS_EFW_AD-7.6 valid exam simulator online exam soon. Hope I nail it!
Posted at 2/17/2026 01:45:14        Only Author  6#
Thank you for sharing this incredible article, its truly breathtaking! Wishing you the best in your exams! Here are the free C_ARSOR_2404 latest exam pattern questions.
Posted at 2/22/2026 16:05:21        Only Author  7#
This article is truly top-notch, thank you for sharing it with me. CKS vce test simulator contains comprehensive material, available at no cost to support your learning.
