[General] HPE7-J02 Reliable Exam Sims - HPE7-J02 Exam Vce
91
【General】 HPE7-J02 Reliable Exam Sims - HPE7-J02 Exam Vce
Posted at 2/6/2026 15:40:45      View:112 | Replies:0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of TorrentVCE HPE7-J02 dumps for free: https://drive.google.com/open?id=18l-7eyYzDsHXt8XHhSsBVpA2vzx34twb
In order to serve you better, we have a complete system for HPE7-J02 exam materials. We offer you free demo to have a try before buying, so that you can have a better understanding of what you are going to buy. If you want the HPE7-J02 exam dumps after trying, just add to cart and pay for it. You will receive the downloading link and password within ten minutes and you can start your learning right now. If you don’t receive, contact us, and we will check it for you. After you purchasing HPE7-J02 Exam Materials, we also have after-sales, and if you have any questions, you can consult us.
If you have a strong desire to get the HP certificate, our HPE7-J02 study materials are the best choice for you. At present, the certificate has gained wide popularity. So the official test syllabus of the HPE7-J02 exam begins to become complicated. So you must accept professional guidance. After all, lots of people are striving to compete with many candidates. Powerful competitiveness is crucial to pass the HPE7-J02 Exam. Our company has mastered the core technology of the HPE7-J02 study materials. What’s more, your main purpose is to get the certificate quickly and easily. Our goal is to aid your preparation of the HPE7-J02 exam. Our study materials are an indispensable helper for you anyway. Please pay close attention to our HPE7-J02 study materials.
HPE7-J02 Exam Vce & Certification HPE7-J02 Test AnswersAllowing for the different bents of exam candidate, we offer three versions of our HPE7-J02 learning braindumps for you. They are app, software and pdf versions of our HPE7-J02 training questions. All crucial points are included in the HPE7-J02 Exam Materials with equivocal contents for your reference with stalwart faith. And we also have the according three free demos of the HPE7-J02 practice engine for you to download before your purchase.
HP Advanced HPE Storage Integrator Solutions Written Exam Sample Questions (Q15-Q20):NEW QUESTION # 15
Exhibit shows HPE StoreOnce Catalyst Store Security Settings:
Server Controlled Data Immutability enabled (7 days).
Maximum ISV Controlled Data Immutability Retention (90 days).
Which statement is correct?
  • A. The Maximum ISV Controlled Data Immutability Retention parameter must be set to 0 for optimal Veeam v12 support.
  • B. Maximum ISV Controlled Data Immutability Retention allows the ISV backup application to manage item-level immutability.
  • C. Server-Controlled Data Immutability is required to achieve the highest immutability with Veeam v12 backups.
  • D. Server-Controlled and ISV-Controlled Data Immutability values do not need to match when both are configured.
NEW QUESTION # 16
Review the diagram showing an Active Peer Persistence deployment across two arrays.
Question: Which Host Proximity Parameter should be configured for ESX31 to ensure localized access?
  • A. Exclusive
  • B. Primary
  • C. All
  • D. Secondary
NEW QUESTION # 17
Two HPE Storage Alletra MP B10000 arrays are deployed with Active Peer Persistence. Both arrays and hosts are installed in close proximity to each other. To enable symmetric access, Peer Persistence must be configured accordingly.
Which Host Proximity Parameter should be selected for host ESX31 in this case?
  • A. Secondary
  • B. Exclusive
  • C. Primary
  • D. All
Detailed Explanation:
Rationale for Correct Answer:
Option B (All) is correct because in an Active Peer Persistence deployment where both arrays and hosts are in close proximity (metro or campus cluster scenario), the hosts should be configured with Host Proximity = All. This ensures that the host (ESX31) can access both arrays symmetrically and concurrently, enabling active-active paths. This is essential to deliver seamless failover and load balancing across the arrays in an HPE Alletra MP Peer Persistence environment.
Analysis of Incorrect Options (Distractors):
A (Secondary): This is used for hosts located closer to the secondary array, to bias access toward it in asymmetric deployments. Not applicable here since the hosts are near both arrays.
C (Exclusive): This option assigns the host to a single array exclusively, preventing dual-active access.
This would defeat the purpose of symmetric Peer Persistence.
D (Primary): Similar to Secondary, this biases access to only the primary array, which is not correct when arrays and hosts are in the same site for active-active.
Key Concept:
This question focuses on Host Proximity parameters in HPE Peer Persistence.
Primary/Secondary = asymmetric designs (hosts closer to one array).
All = symmetric design (hosts equidistant to both arrays, enabling active-active).
Exclusive = restricts access to one array only.
HPE Alletra MP Storage Peer Persistence Best Practices Guide
HPE Primera/Alletra Remote Copy and Peer Persistence Technical White Paper VMware Metro Storage Cluster with HPE Peer Persistence Implementation Notes
NEW QUESTION # 18
Select the scenario where implementing FCoE would be an appropriate solution.
  • A. A tech startup is developing an AI-based application that relies heavily on machine learning models.The team needs a solution that allows them to access and process large datasets in the cloud.
  • B. A company with data centers in different states wants to establish a unified SAN infrastructure. The goal is to centralize storage management across all sites, using a single protocol that can efficiently handle high-latency, long-distance connections between data centers.
  • C. A corporation needs to replicate data between data centers in different countries. The data must be synchronized in real-time across a WAN, and the solution must tolerate variable network conditions with minimal impact on performance.
  • D. A large enterprise data center with existing Fibre Channel SANs is looking to reduce hardware complexity and costs by consolidating their storage and production networks onto a single infrastructure, while maintaining high performance for mission-critical applications.
Option A is correct because Fibre Channel over Ethernet (FCoE) is designed for large enterprise environments that already have Fibre Channel (FC) infrastructures but want to simplify cabling and reduce hardware by converging LAN and SAN traffic over a single Ethernet fabric. FCoE retains the efficiency, low latency, and reliability of Fibre Channel while leveraging Ethernet to minimize physical infrastructure costs.
This aligns with HPE's best practices for environments using HPE Alletra 9000/Primera or HPE Nimble arrays connected to converged networks where cost reduction and high performance are equally important.
B: Real-time replication across WANs requires protocols like HPE 3PAR/Alletra Remote Copy, asynchronous/synchronous replication, or HPE Peer Persistence. FCoE is not suited for high-latency WANs because it is a LAN protocol designed for short distances within a data center.
C: For inter-data center SAN unification, FCIP (Fibre Channel over IP) or iSCSI are more suitable. FCoE does not handle long-distance high-latency links effectively.
D: A startup building AI applications with cloud workloads typically benefits from object storage (HPE Scality RING, HPE GreenLake for File and Object) or direct cloud-native APIs (S3/Blob). FCoE is irrelevant in this use case since it is on-prem and infrastructure-focused.
Key Concept:
The question is testing knowledge of FCoE and its appropriate deployment scenarios - specifically, its role in consolidating storage and network traffic inside enterprise data centers while preserving Fibre Channel protocol advantages.
HPE Storage Networking Best Practices Guide
HPE Primera/Alletra 9000 Technical White Paper
Fibre Channel over Ethernet Standards Overview (IEEE 802.1Qbb, 802.1Qaz)
NEW QUESTION # 19
An HPE Alletra 6030 with 138TB flash kit needs a storage expansion. The BOM lists only a 46TB Expansion Shelf, including price.
What should you take into account?
  • A. The expansion shelf needs to include the 24G SAS cables.
  • B. Both Controllers need 100Gb OCP adapters for the expansion shelf connection.
  • C. QSFP+ DAC cables are required if NVMe media is used.
  • D. Total supported capacity will be exceeded with the proposed configuration.
Alletra 6000 expansion shelves connect via 24G SAS back-end connectivity. The BOM must include the required SAS cables to properly attach the shelf. If only the shelf is listed, it's incomplete - SAS connectivity accessories must be added.
Distractors:
B: The supported max capacity is higher than 138TB + 46TB, so it won't exceed limits.
C: Expansion shelves don't use OCP adapters; they rely on SAS backend ports.
D: QSFP+ DACs are used for front-end networking (iSCSI/FC), not SAS shelf expansion.
Key Concept: Alletra 6000 expansions require 24G SAS cables included in the BOM.
Reference: HPE Alletra 6000 Hardware Installation Guide.
NEW QUESTION # 20
TorrentVCE releases 100% pass-rate HP HPE7-J02 study guide files which guarantee candidates 100% pass exam in the first attempt. It is time for you to choose a valid HP HPE7-J02 study guide, this will be your best method for clearing exam and obtain a certification. Good HPE7-J02 Study Guide will be a shortcut for you to well-directed prepare and practice efficiently, you will avoid do much useless efforts and do something interesting.
HPE7-J02 Exam Vce: https://www.torrentvce.com/HPE7-J02-valid-vce-collection.html
Purchase HPE7-J02 exam package at a discount and start TorrentVCE HPE7-J02 Exam preparation today, TorrentVCE HPE7-J02 Exam Vce not only provide the products which have high quality to each candidate, but also provides a comprehensive after-sales service, TorrentVCE HPE7-J02 Exam Vce exam answers are revised by the most skillful HP HPE7-J02 Exam Vce HPE7-J02 Exam Vce professionals, We have online and offline chat service stuff, and if you have any questions for HPE7-J02 exam materials, you can consult us.
Analytics allows developers to create better HPE7-J02 products as they identify what features are used most, Exporting States of a Page as Individual Images, Purchase HPE7-J02 Exam package at a discount and start TorrentVCE HPE7-J02 Exam preparation today.
Pass Guaranteed HP HPE7-J02 - Advanced HPE Storage Integrator Solutions Written Exam Fantastic Reliable Exam SimsTorrentVCE not only provide the products which have high quality to each candidate, HPE7-J02 Reliable Test Prep but also provides a comprehensive after-sales service, TorrentVCE exam answers are revised by the most skillful HP HPE Storage Solutions professionals.
We have online and offline chat service stuff, and if you have any questions for HPE7-J02 exam materials, you can consult us, If you are in desperate need to acquire the certificate, if you want to increase your efficiency, HPE7-J02 exam question is the best choice.
DOWNLOAD the newest TorrentVCE HPE7-J02 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=18l-7eyYzDsHXt8XHhSsBVpA2vzx34twb
