2026 1z0-076: High Pass-Rate Exam Oracle Database 19c: Data Guard Administration
Posted at 1/15/2026 10:29:36
View199
Replies4
2026 Latest Pass4sures 1z0-076 PDF Dumps and 1z0-076 Exam Engine Free Share: https://drive.google.com/open?id=1H0Cvpblo3EbHLxIeU7E8iXKKFm7NF6sG
We promise to provide a high-quality simulation system with advanced 1z0-076 study materials. With the simulation function, our 1z0-076 training guide is easier to understand and have more vivid explanations to help you learn more knowledge. You can set time to test your study efficiency, so that you can accomplish your test within the given time when you are in the Real 1z0-076 Exam. You will be confident if you have more experience on the 1z0-076 exam questions!
Oracle 1z0-076 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Using Oracle Active Data Guard: Supported Workloads in Read-Only Standby Databases: Here, the usage of physical standby databases for real-time queries is discussed.
| | Topic 2 | - Managing Oracle Net Services in a Data Guard Environment: The section focuses on Oracle Net Services and its role in Data Guard networking setup.
| | Topic 4 | - Creating a Logical Standby Database: This topic guides users through the process of creating and managing a logical standby database, including SQL Apply filtering.
| | Topic 5 | - Creating a Data Guard Broker Configuration: This section delves into the practical aspects of creating and managing a Data Guard broker configuration, including command-line and Enterprise Manager approaches.
| | Topic 6 | - Managing Physical Standby Files After Structural Changes on the Primary Database: The topic covers managing structural changes in the primary database and their impact on physical standby files.
| | Topic 7 | - Monitoring a Data Guard Broker Configuration: The topic covers the use of Enterprise Manager and DGMGRL to monitor Data Guard configurations and explains the various data protection modes available.
| | Topic 8 | - Enhanced Client Connectivity in a Data Guard Environment: This topic focuses on enhancing client connectivity in a Data Guard setup and implementing failover procedures for seamless client redirection. It also covers application continuity to ensure uninterrupted operations during role transitions.
| | Topic 9 | - Backup and Recovery Considerations in an Oracle Data Guard Configuration: In this topic, Backup and recovery procedures in a Data Guard configuration are discussed, including RMAN backups, offloading to physical standby, and network-based recovery.
| | Topic 10 | - Using Flashback Database in a Data Guard Configuration: This topic covers the configuration and advantages of using Flashback Database in a Data Guard setup, as well as the process of enabling fast-start failover for seamless role changes.
Exam 1z0-076 Lab Questions Free PDF | Valid Valid 1z0-076 Exam Duration: Oracle Database 19c: Data Guard AdministrationThe clients can consult our online customer service before and after they buy our 1z0-076 study materials. We provide considerate customer service to the clients. Before the clients buy our 1z0-076 study materials they can consult our online customer service personnel about the products version and price and then decide whether to buy them or not. After the clients buy the 1z0-076 study materials they can consult our online customer service about how to use them and the problems which occur during the process of using. If the clients fail in the test and require the refund our online customer service will reply their requests quickly and deal with the refund procedures promptly. In short, our online customer service will reply all of the clients questions about the 1z0-076 Study Materials timely and efficiently.
Oracle Database 19c: Data Guard Administration Sample Questions (Q76-Q81):NEW QUESTION # 76
Which TWO statements correctly describe the behavior of Automatic Block Media Recovery in a Data Guard environment, for a corrupt block in the example tablespace encountered by a session logged in as the SH user?
- A. A corrupt block on a standby database with Real-Time Query enabled, is automatically recovered, using flashback logs from the standby database.
- B. A corrupt block on the primary database can be automatically recovered, using a block from a standby database with Real-Time Query enabled.
- C. A corrupt block on the primary database is automatically recovered, using a block from a flashback log from the primary database.
- D. A corrupt block on the primary database is automatically recovered, using a block from a flashback log from a standby database with Real-Time Query enabled.
- E. A corrupt block on a standby database with Real-Time Query enabled, can be automatically recovered, using a block from the primary database.
Automatic Block Media Recovery can be a significant feature for maintaining data integrity within a Data Guard configuration.
* A corrupt block on the primary database can be automatically recovered, using a block from a standby database with Real-Time Query enabled (A): When a corrupted block is encountered on the primary database, Oracle can automatically replace it with a good block from the standby database where Real-Time Query is enabled, leveraging the standby as a source of good data.
* A corrupt block on the primary database is automatically recovered, using a block from a flashback log from the primary database (E): If a good block version is available in the flashback logs of the primary database, Automatic Block Media Recovery can use it to recover the corrupted block on the primary.References:
* Oracle Database Backup and Recovery User's Guide
NEW QUESTION # 77
Examine this validate command:
DGMGRL> VALIDATE DATABASE VERBOSE "<database name>";
Which THREE statements are TRUE?
- A. The command performs a comparison of SPFILE entries between the primary database and a specified standby database.
- B. The command performs a comprehensive set of database checks prior to a role change.
- C. The command performs network connectivity checks between members of a broker configuration.
- D. The command uses information available in various Oracle Data Guard views as well as the Automatic Diagnostic Repository.
- E. The command can be used for a logical standby database.
Answer: B,C,E
The command performs a comprehensive set of database checks prior to a role change (A): The VALIDATE DATABASE command in Data Guard Manager (DGMGRL) is designed to perform an exhaustive check of a specified database's readiness for a role change, such as a switchover or failover.
The command performs network connectivity checks between members of a broker configuration (C): One of the checks includes verifying that the necessary network connectivity exists between the databases in a Data Guard Broker configuration.
The command can be used for a logical standby database (D): The VALIDATE DATABASE command is versatile and can be used for both physical and logical standby databases to ensure their readiness for role changes.
Oracle Data Guard Broker documentation
Oracle Data Guard Concepts and Administration Guide
NEW QUESTION # 78
Examine the Data Guard configuration:
DGMGRL> show configuration;
Configuration - Animals
Protection Mode: MaxAvailability
Databases:
dogs - Primary database
sheep - Snapshot standby database
cats - Physical standby database
Fast-Start Failover: DISABLED
Configuration Status:
SUCCESS
You receive an error while attempting to raise the protection mode to Maximum Protection:
DGMGRL> edit configuration set protection mode as maxprotection;
Error: ORA-16627: operation disallowed since no standby databases would remain to support protection mode Failed.
Which is the minimum statement, or sequence of statements you must execute to enable successful raising of the protection mode to Maximum Protection?
- A. DGMGRL> edit database dogs set property LogXptMode=sync;
DGMGRL> edit database cats set property LogXptMode=sync; - B. DGMGRL> edit database dogs set property LogxptMode=sync;
DGMGRL> edit database sheep set property LogxptMode=sync; - C. DGMGRL> edit database sheep set property LogXptMode=sync;
- D. DGMGRL> edit database dogs set property LogXptMode=sync;
DGMGRL> edit database cats set property LogXptMode=sync; - E. DGMGRL> edit database cats set property LogXptMode=sync;
- F. DGMGRL> edit database dogs set property LogxptMode=sync;
NEW QUESTION # 79
Your Data Guard environment contains a primary database and three standby databases with these attributes:
1. prod : Primary database
2. prod_prq : Physical standby database with real-time query enabled used by reporting applications
3. prod_lsby: Logical standby database used by DSS
4. PROD_SSBY: Snapshot standby database used for Real Application Testing Which TWO can be used to prevent clients from connecting to the wrong database instance?
- A. Establish Oracle Net connectivity to the primary database instance from all the standby database instances.
- B. Create role based services with the si vet] utility when using clusterware for Oracle RAC databases or Oracle Restart for single instance Oracle databases.
- C. Create database services on each of the standby databases, start the services, and add connection descriptors on the clients to connect to those services.
- D. Create database services for each database and use event triggers to make sure that services are activated only when the database is in the correct role.
- E. Create a static service for each of the databases, register it with the local listener of each database instance, and add connection descriptors on clients to connect to those services.
Creating dedicated database services for each database instance (Option D) and utilizing event triggers to manage these services based on the role of the database (Option E) ensure that clients connect to the appropriate database instance based on its current role and state. This approach leverages the flexibility and control provided by Oracle Net services and database event management to direct client connections to the suitable primary or standby instance, enhancing the overall robustness and reliability of the Data Guard environment. Reference: Based on Oracle Database 19c best practices for managing connectivity and services in a Data Guard setup, including the use of role-based services and event-driven service management.
NEW QUESTION # 80
A customer asks for your recommendation regarding this requirement:
1. We plan to have a Data Guard Configuration with one primary database and one physical standby database.
2. We want zero data loss in case of a disaster involving the loss of one component.
3. We want to do Real Application Testing occasionally on the Standby Database.
Which solution, if any, satisfies these requirements?
- A. A far sync instance plus a snapshot standby database and real time apply that can be converted regularly into logical standby database to do real application testing
- B. A physical standby database with synchronous redo transport that can be converted regularly into a snapshot standby to do real application testing
- C. A snapshot standby database with real time query that can be converted regularly into a physical standby database open read write, to do real application testing
- D. These requirements cannot be met.
Synchronous redo transport for zero data loss (B): To guarantee zero data loss in the case of a disaster, synchronous redo transport must be configured between the primary and standby databases.
Conversion to snapshot standby for testing (B): A physical standby database can be temporarily converted into a snapshot standby database to perform real application testing. After testing is completed, the snapshot standby can be converted back to a physical standby to resume its disaster recovery role.
Oracle Database Testing Guide
NEW QUESTION # 81
Our 1z0-076 practice torrent offers you more than 99% pass guarantee, which means that if you study our 1z0-076 materials by heart and take our suggestion into consideration, you will absolutely get the 1z0-076 certificate and achieve your goal. Meanwhile, if you want to keep studying this course , you can still enjoy the well-rounded services by 1z0-076 Test Prep, our after-sale services can update your existing 1z0-076 study materials within a year and a discount more than one year.
Valid 1z0-076 Exam Duration: https://www.pass4sures.top/Oracle-Database-19c/1z0-076-testking-braindumps.html
- 100% Pass 2026 Professional Oracle Exam 1z0-076 Lab Questions 🎱 Simply search for ➡ 1z0-076 ️⬅️ for free download on ✔ [url]www.practicevce.com ️✔️ 👱
ractice 1z0-076 Tests[/url] - 1z0-076 Practice Exam Pdf 💳 1z0-076 New Exam Bootcamp 👾 1z0-076 Latest Study Notes 🎱 ☀ [url]www.pdfvce.com ️☀️ is best website to obtain 1z0-076 for free download ⛰1z0-076 Valid Test Experience[/url]
- 1z0-076 Valid Test Answers 🎩 1z0-076 Dumps Free Download 🥶 Valid 1z0-076 Test Guide 🕤 Enter ➽ [url]www.prepawayexam.com 🢪 and search for ➠ 1z0-076 🠰 to download for free 🔯1z0-076 Latest Study Notes[/url]
- Authoritative Exam 1z0-076 Lab Questions | 100% Free Valid 1z0-076 Exam Duration 🎰 Easily obtain ▷ 1z0-076 ◁ for free download through [url]www.pdfvce.com 🍡1z0-076 Real Dumps Free[/url]
- 1z0-076 Valid Test Experience 🦇 1z0-076 Reliable Exam Preparation ⛲ 1z0-076 Practice Exam Pdf 🕵 Go to website ⇛ [url]www.pdfdumps.com ⇚ open and search for 1z0-076 to download for free 🐩1z0-076 Reliable Exam Preparation[/url]
- 1z0-076 Latest Study Notes 🚾 1z0-076 Valid Test Experience 🤡 1z0-076 Valid Test Answers 🐟 Go to website [url]www.pdfvce.com open and search for ▷ 1z0-076 ◁ to download for free ✌1z0-076 Latest Study Notes[/url]
- 1z0-076 Valid Test Pass4sure 🍊 1z0-076 Latest Test Format 🍋 Reliable 1z0-076 Braindumps Free 🏉 Open ➠ [url]www.exam4labs.com 🠰 and search for ⮆ 1z0-076 ⮄ to download exam materials for free 📰1z0-076 Valid Test Answers[/url]
- Free PDF 2026 1z0-076 - Exam Oracle Database 19c: Data Guard Administration Lab Questions 🔼 Search for ➤ 1z0-076 ⮘ and download it for free on ➠ [url]www.pdfvce.com 🠰 website 😪Valid Dumps 1z0-076 Ebook[/url]
- Latest 1z0-076 Practice Materials 🥂 Valid Dumps 1z0-076 Ebook 🥘 1z0-076 Training Kit 🎬 Search for ⇛ 1z0-076 ⇚ on ▶ [url]www.practicevce.com ◀ immediately to obtain a free download 📅1z0-076 New Exam Bootcamp[/url]
- Latest 1z0-076 Practice Materials ♥ 1z0-076 Training Kit 🔰 1z0-076 Valid Test Experience 🍱 Easily obtain ➠ 1z0-076 🠰 for free download through ➡ [url]www.pdfvce.com ️⬅️ 🤤Latest 1z0-076 Exam Fee[/url]
- Practice 1z0-076 Tests 🦁 Valid 1z0-076 Test Guide 🎒 Valid 1z0-076 Test Guide 🔲 ➡ [url]www.prep4sures.top ️⬅️ is best website to obtain ➠ 1z0-076 🠰 for free download 😧1z0-076 Latest Test Format[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, c50.in, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, unilisto.com, Disposable vapes
What's more, part of that Pass4sures 1z0-076 dumps now are free: https://drive.google.com/open?id=1H0Cvpblo3EbHLxIeU7E8iXKKFm7NF6sG
