[General] 100% Pass Quiz 2026 C-ACDET-2506: The Best SAP Certified Associate - Configuring
30
【General】 100% Pass Quiz 2026 C-ACDET-2506: The Best SAP Certified Associate - Configuring
Posted at 5/14/2026 18:46:26      View:71 | Replies:0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of ValidBraindumps C-ACDET-2506 dumps from Cloud Storage: https://drive.google.com/open?id=1rGvObEOHJCYHHuTuhBXOLmw2SIDUKRC7
All these three ValidBraindumps SAP Certified Associate - Configuring SAP Ariba Strategic Sourcing Suite (C-ACDET-2506) exam questions formats are easy to use and perfectly work with all devices, operating systems, and the latest web browsers. So rest assured that with the C-ACDET-2506 Exam Dumps you will get everything that you need to learn, prepare and pass the challenging C-ACDET-2506 exam with good scores.
The loss of personal information in the information society is indeed very serious, but C-ACDET-2506 guide materials can assure you that we will absolutely protect the privacy of every user. Our C-ACDET-2506 study braindumps users are all over the world, is a very international product, our C-ACDET-2506 Exam Questions are also very good in privacy protection. And we offer good sercives on our C-ACDET-2506 learning guide to make sure that every detail is perfect.
C-ACDET-2506 Practice Exam & Reliable C-ACDET-2506 Test CostValidBraindumps owns the most popular reputation in this field by providing not only the best ever C-ACDET-2506 study guide but also the most efficient customers' servers. We can lead you the best and the fastest way to reach for the C-ACDET-2506 certification and achieve your desired higher salary. Our C-ACDET-2506 Exam Preparation can improve your grade and change your states of life for our C-ACDET-2506 Learning Questions are the accumulation of professional knowledge. You will be more successful with our C-ACDET-2506 braindump.
SAP C-ACDET-2506 Exam Syllabus Topics:
  • Field Configuration: This domain evaluates the knowledge of an SAP Deployment Specialist and focuses on customizing and configuring business fields in the SAP system according to client-specific needs. This includes adjusting system settings for master data, transaction data, and other essential field-level controls to support business processes effectively. The section tests the candidate’s ability to use configuration tools, apply SAP standard templates, and ensure that the field configurations align with the desired operational workflows of the business. It also touches upon validation, testing, and documenting the configuration changes made during the implementation.
  • Project Overview, Roles and Responsibilities: This section of the exam measures the skills of an SAP Cloud Consultant and covers the fundamental understanding of SAP Activate methodology within the context of a cloud implementation project. Candidates are expected to be familiar with the project lifecycle, including phases such as Prepare, Explore, Realize, Deploy, and Run. This part also focuses on identifying key roles and responsibilities within a cloud project team, ensuring clarity in collaboration between consultants, clients, and SAP. It checks whether the consultant understands governance, stakeholder management, and the high-level structure of cloud deployment using SAP best practices.
  • Deploy and Migration: This part of the exam assesses the expertise of an SAP Deployment Specialist and focuses on the final deployment of the configured solution and the data migration process. Candidates should demonstrate a solid grasp of how to move configurations from a testing environment into production while minimizing disruption. It also includes knowledge of tools and strategies used for data extraction.
SAP Certified Associate - Configuring SAP Ariba Strategic Sourcing Suite Sample Questions (Q34-Q39):NEW QUESTION # 34
The customer wants to have a field to hold Contract Storage Locations and the address. Those locations are loaded from an external system, and the user should be able to search for storage locations. What should be used to hold the valid storage locations?
  • A. Create a new field of type Date, where each date entry is tied to a unique Storage Location and its corresponding address, allowing users to select locations based on historical data entries.
  • B. Create a new field of type Text, with a custom Validation where the available Storage Locations are listed.
  • C. You should create a new Flex Master Data (FMD) Template with appropriate attributes and call it Storage Location. Once the template is published and sample data loaded, you can create a custom field and select the type Storage Location.
  • D. You should load a new Enumeration Type and call it Storage Location and load the location addresses.
    Create a new field of type Enumeration with a custom filter to only Enumerations of type show Storage Locations.
For managingsearchable lists of storage locations with associated attributes like addresses, the best SAP Ariba practice is to use aFlex Master Data (FMD) Template. This allows you to model the storage locations and related information dynamically. After creating the FMD template and loading the data (e.g., from CSV imports), you can create a custom field referencing the FMD type.
This approach enables users tosearch, filter, and selectvalid locations efficiently, while also allowing the underlying data to be maintained separately and updated independently of the configuration.
Using text fields with validation or enumerations is insufficient for large or dynamic datasets and doesn't scale well. Date fields are unrelated to this scenario.
FMD provides a scalable and flexible solution for complex master data requirements like storage locations.
NEW QUESTION # 35
When you have created a new custom field and marked it as reportable, saved and published your changes, but the field does not show up in reports. How can you resolve the issue?
  • A. Custom fields must be created in the same module where reports are generated.
  • B. Run the "Retrieve flexible fields metadata for reporting" task under Reporting Manager.
  • C. Wait 2 hours for the schema to refresh automatically.
  • D. You did not assign the custom field to the appropriate report category.
After publishing a custom reportable field, the"Retrieve flexible fields metadata for reporting" task must be runto update the reporting schema with the new field metadata. Without this manual step, the reports do not recognize the new field despite it being published. The system does not perform automatic timed refreshes of the schema. Module location or report category assignment is not a prerequisite for report visibility in SAP Ariba's analytics.
NEW QUESTION # 36
A customer requests a dynamic list from CSV.
Which field type supports that?
  • A. Hyperlink
  • B. Flex Master Data-based field
  • C. Computed Field
  • D. Single-Select Enum
NEW QUESTION # 37
When performing migration to production for a Greenfield customer, which item needs to be made available in Production prior to creating the migration package in Intelligent Configuration Manager (ICM)?
  • A. Users
  • B. Approval Rules
  • C. Translations
  • D. Locations
Before creating and deploying migration packages with the Intelligent Configuration Manager (ICM), translation string resource files (custom field labels, help tips, validation messages, etc.) must be uploaded into Productionvia AML & Translations Upload. This ensures that migration bundles referencing these translations do not cause missing label or localization issues post-migration. Locations, users, and approval rules are either migrated as part of configuration packages or managed separately, and do not require prior upload to Production before creating migration packages.
NEW QUESTION # 38
How can you set the order of your custom Contract Workspace fields? Note: There are 2 correct answers to this question.
  • A. Select Field Configuration and under the advanced tab select property Sequence. Fields are sorted by this field in the UL. Once all changes are performed, publish all changes via Customizing Publish.
  • B. The fields are presented in alphabetical order of the field label. By carefully choosing the
  • C. Navigate to the UI where the class is presented, select Customize in the banner, select Edit, and drag and drop the fields in the order they should be presented. Once all changes are performed, publish all changes via Customizing → Publish
  • D. Select Field Configuration, find the class, and select the Layout tab. Here you can drag and drop the order of the fields. Once all changes are performed, publish all changes via Customizing Publish.
NEW QUESTION # 39
If you can own the certification means that you can do the job well in the area so you can get easy and quick promotion. The latest C-ACDET-2506 quiz torrent can directly lead you to the success of your career. Our materials can simulate real operation exam atmosphere and simulate exams. The download and install set no limits for the amount of the computers and the persons who use C-ACDET-2506 Test Prep. So we provide the best service for you as you can choose the most suitable learning methods to master the C-ACDET-2506 exam torrent. Believe us and if you purchase our product it is very worthy.
C-ACDET-2506 Practice Exam: https://www.validbraindumps.com/C-ACDET-2506-exam-prep.html
What's more, part of that ValidBraindumps C-ACDET-2506 dumps now are free: https://drive.google.com/open?id=1rGvObEOHJCYHHuTuhBXOLmw2SIDUKRC7
