1z1-809 Valid Test Simulator & Reliable 1z1-809 Exam Guide
103
Posted at 2/6/2026 21:42:44      View89 | Replies0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest RealExamFree 1z1-809 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1SsPItAwcqJUlY3wUiW5pXS2qKP57_dTv
RealExamFree's experts have simplified the complex concepts and have added examples, simulations and graphs to explain whatever could be difficult for you to understand. Therefore even the average 1z1-809 exam candidates can grasp all study questions without any difficulty. Additionally, the 1z1-809 Exam takers can benefit themselves by using our testing engine and get numerous real 1z1-809 exam like practice questions and answers. They will help them revising the entire syllabus within no time.
A generally accepted view on society is only the professionals engaged in professional work, and so on, only professional in accordance with professional standards of study materials, as our 1z1-809 study materials, to bring more professional quality service for the user. Our study materials can give the user confidence and strongly rely on feeling, lets the user in the reference appendix not alone on the road, because we are to accompany the examinee on 1z1-809 Exam, candidates need to not only learning content of teaching, but also share his arduous difficult helper, so believe us, we are so professional company.
Reliable Oracle 1z1-809 Exam Guide - 1z1-809 Learning ModeThe only goal of all experts and professors in our company is to design the best and suitable 1z1-809 study materials for all people. According to the different demands of many customers, they have designed the three different versions of the 1z1-809 certification study guide materials for all customers: PDF, Soft and APP versions. They sincerely hope that all people who use 1z1-809 Exam Questions from our company can pass the 1z1-809 exam and get the related certification successfully. And our pass rate for 1z1-809 exam questions is high as more than 98%.
Oracle Java SE 8 Programmer II Sample Questions (Q82-Q87):NEW QUESTION # 82
Given:
Which two classes use the shape class correctly?
  • A. Option D
  • B. Option F
  • C. Option C
  • D. Option E
  • E. Option B
  • F. Option A
Answer: D,E
When an abstract class is subclassed, the subclass usually provides implementations for all of the abstract methods in its parent class (E). However, if it does not, then the subclass must also be declared abstract (B). Note: An abstract class is a class that is declared abstract--it may or may not include abstract methods. Abstract classes cannot be instantiated, but they can be subclassed.
NEW QUESTION # 83
Given the code fragment:
ZonedDateTime depart = ZonedDateTime.of(2015, 1, 15, 3, 0, 0, 0, ZoneID.of("UTC-7"));
ZonedDateTime arrive = ZonedDateTime.of(2015, 1, 15, 9, 0, 0, 0, ZoneID.of("UTC-5"));
long hrs = ChronoUnit.HOURS.between(depart, arrive); //line n1
System.out.println("Travel time is" + hrs + "hours");
What is the result?
  • A. Travel time is 4 hours
  • B. An exception is thrown at line n1.
  • C. Travel time is 6 hours
  • D. Travel time is 8 hours
NEW QUESTION # 84
Given the structure of the STUDENT table:
Student (id INTEGER, name VARCHAR)
Given:
public class Test {
static Connection newConnection =null;
public static Connection get DBConnection () throws SQLException {
try (Connection con = DriveManager.getConnection(URL, username,
password)) {
newConnection = con;
return newConnection;
public static void main (String [] args) throws SQLException {
get DBConnection ();
Statement st = newConnection.createStatement();
st.executeUpdate("INSERT INTO student VALUES (102, 'Kelvin')");
Assume that:
The required database driver is configured in the classpath.
The appropriate database is accessible with the URL, userName, and passWord exists.
The SQL query is valid.
What is the result?
  • A. The program executes successfully and the STUDENT table is updated with one record.
  • B. A SQLExceptionis thrown as runtime.
  • C. A NullPointerExceptionis thrown as runtime.
  • D. The program executes successfully and the STUDENT table is NOT updated with any record.
NEW QUESTION # 85
Which three lines fail to compile?
  • A. line 9
  • B. line 8
  • C. line 7
  • D. line 10
  • E. line 11
  • F. line 12
Answer: C,D,F
NEW QUESTION # 86
Given:
public interface Moveable<Integer> {
public default void walk (Integer distance) {System.out.println("Walking");) public void run(Integer distance);
Which statement is true?
  • A. Moveable can be used as below:Moveable<Integer> animal = n - > System.out.println("Running" + n); animal.run(100);animal.walk(20);
  • B. Moveable can be used as below:Moveable<Integer> animal = n - > n + 10;animal.run(100);animal.walk (20);
  • C. Moveable can be used as below:Moveable animal = (Integer n) - > System.out.println(n);animal.run (100);Moveable.walk(20);
  • D. Movable cannot be used in a lambda expression.
NEW QUESTION # 87
Choose RealExamFree 1z1-809 new dumps questions, you will never regret for your decision. Our high-quality 1z1-809 exam cram can ensure you 100% pass. You see, we have quality control system, each questions of 1z1-809 exam dumps are checked and confirmed strictly according to the quality control system. Besides, the updated frequency for 1z1-809 Exam Questions is so regular and in accordance with the real exam changes. You can enjoy one year free update after purchase.
Reliable 1z1-809 Exam Guide: https://www.realexamfree.com/1z1-809-real-exam-dumps.html
Our 1z1-809 exam training guide must be your preference with their reasonable price and superb customer services, which including one-year free update after you purchase our 1z1-809 : Java SE 8 Programmer II training guide, if you want to keep on buying other 1z1-809 test products, you can get it with your membership discounts when you purchase, Oracle 1z1-809 Valid Test Simulator After purchasing our products you will feel easy to attend exams you may feel difficult before.
The Java-powered online game RuneScape, It's good to be flexible, Our 1z1-809 exam training guide must be your preference with their reasonable price and superb customer services, which including one-year free update after you purchase our 1z1-809 : Java SE 8 Programmer II training guide, if you want to keep on buying other 1z1-809 test products, you can get it with your membership discounts when you purchase.
How RealExamFree Make its Oracle 1z1-809 Exam Questions Engaging?After purchasing our products you will feel easy to attend exams you may feel difficult before, Get the latest 1z1-809 actual exam questions for 1z1-809 Exam.
Additionally, RealExamFree offers 12 months of free Oracle 1z1-809 exam questions so that our customers prepare with the latest Oracle 1z1-809 material.
As the saying goes, time is the most precious wealth of all wealth.
BONUS!!! Download part of RealExamFree 1z1-809 dumps for free: https://drive.google.com/open?id=1SsPItAwcqJUlY3wUiW5pXS2qKP57_dTv
