[Linux] How to prevent ubuntu update from breaking graphics
173
【Linux】 How to prevent ubuntu update from breaking graphics
Posted at 2/3/2019 09:55:47      View:5088 | Replies:8        Print      Only Author   [Copy Link] 1#
I have an issue where if I make the mistake of sudo apt upgrade it breaks the graphics drivers and I get stuck with software gles. Is there some way to stop that? maybe a
  1. dpkg-divert
Copy the code
command or something like this .deb file https://github.com/avafinger/nanopi-m4-ubuntu-base-minimal/releases/tag/v1.2.1
Posted at 2/3/2019 15:11:24        Only Author  2#
I used apt-mark and it seemed to survive an apt upgrade
  1. sudo apt-mark hold libgl1 libglx0 libgles2 libegl1 libglvnd0
Copy the code
I will update if I find a way to have opencl without breaking webgl
Posted at 2/3/2019 15:34:13        Only Author  3#
Looks like it was already in there, clinfo just needs where to find it:
  1. sudo mkdir /etc/OpenCL
  2. sudo mkdir /etc/OpenCL/vendors
  3. echo "/usr/lib/aarch64-linux-gnu/libOpenCL.so" | sudo tee /etc/OpenCL/vendors/armocl.icd
Copy the code
vip
Rank: 6Rank: 6
Posted at 2/12/2019 11:02:09        Only Author  4#
Welcome to the forum, and thanks for sharing the solution!
Posted at 1/13/2026 03:56:29        Only Author  5#
What a remarkable piece of writing, thank you for sharing this with us! Here's the Valid FCSS_CDS_AR-7.6 test practice test that helped me land my promotion and raise. It's free today—good luck with your career progress!
Posted at 1/19/2026 04:37:43        Only Author  6#
Thank you for your article, it really impressed me in a meaningful way. These L6M3 valid study materials questions were the key to my success. Grab them today for free to boost your career!
Posted at 1/19/2026 20:58:16        Only Author  7#
It-PassportsのDP-600J問題集は実際のDP-600J認定試験と同じです。この問題集は実際試験の問題をすべて含めることができるだけでなく、問題集のソフト版はDP-600J試験の雰囲気を完全にシミュレートすることもできます。It-Passportsの問題集を利用してから、試験を受けるときに簡単に対処し、楽に高い点数を取ることができます。
Posted at 2/19/2026 11:11:27        Only Author  8#
Through reading this article, I feel that I have made great progress. The Dump 312-39 check content is outstanding, and it's available at no charge.
Posted at 2/19/2026 14:38:44        Only Author  9#
お客様はFCSS_ADA_AR-6.7を購入した前に、我々のウェブサイトでFCSS_ADA_AR-6.7問題集のサンプルを無料でダウンロードして自分の要求と一致するかどうか確認することができます。先行販売サービスは言うまでもなく、Topexamのアフターサービスはお客様の販売者への評価の基準だと思います。お客様の利益を保証するために、完全的なアフターサービスは必要となります。我々の提供するFCSS_ADA_AR-6.7のアフターサービスは一年の無料更新と半年以内の失敗返金ということです。
