NCP-DB-6.10更新,NCP-DB-6.10考試備考經驗
Posted at 2/15/2026 21:52:17
從Google Drive中免費下載最新的PDFExamDumps NCP-DB-6.10 PDF版考試題庫:https://drive.google.com/open?id=1RFeDaiTFOOH87kk7Zi0XZsgLjgQVcL30
希望成為擁有NCP-DB-6.10認證的IT專業人士嗎?想減少獲得NCP-DB-6.10認證的成本嗎?想通過所有的Nutanix認證嗎?如果“是”,PDFExamDumps是考生最明智的選擇,為您提供涵蓋最新認證考試問題的最佳題庫學習資料。NCP-DB-6.10題庫可以在您考前模擬真實的考試環境,也是最有效的考古題。利用Nutanix的NCP-DB-6.10考古題,您將達到你的目的,得到最佳的效果,給您帶來無限大的利益,在您以后的IT行業道路上可以走的更遠。
通過NCP-DB-6.10考試認證,如同通過其他世界知名認證,得到國際的承認及接受,NCP-DB-6.10考試認證也有其廣泛的IT認證,世界各地的人們都喜歡選擇NCP-DB-6.10考試認證,使自己的職業生涯更加強化與成功,在PDFExamDumps,你可以選擇適合你學習能力的產品。
Nutanix NCP-DB-6.10考試備考經驗 - NCP-DB-6.10證照資訊你已經報名參加了NCP-DB-6.10認證考試嗎?是不是面對一大堆的復習資料和習題感到頭痛呢?PDFExamDumps可以幫您解決這一問題,它絕對是你可以信賴的網站!只要你選擇使用PDFExamDumps網站提供的資料,絕對可以輕鬆通過考試,與其花費時間在不知道是否有用的復習資料上,不如趕緊來體驗PDFExamDumps帶給您的服務,還在等什麼趕緊行動吧。
最新的 Nutanix Certified Professional (NCP) NCP-DB-6.10 免費考試真題 (Q87-Q92):問題 #87
What behavior is observed when applying patch profiles as a Super Admin?
- A. Unpublished patches can be applied.
- B. Hidden patches can be applied.
- C. Published patches cannot be applied if currently deprecated.
- D. Deprecated patches can be applied.
答案:C
解題說明:
In the context of Nutanix Database Automation (NCP-DB), a Super Admin has the authority to apply patch profiles. However, if a patch is marked as deprecated, even if it's published, it cannot be applied. This is because deprecation is a status that indicates the patch is outdated or has been superseded by a newer version, and thus should not be used. This behavior ensures that only the most up-to-date and secure patches are applied to the system, maintaining the integrity and security of the database environment.
問題 #88
An administrator needs to migrate a large 1/0-intensive database that doesn't support multi-disk layout.
How should the storage be provisioned with Era to support the database while optimizing performance?
- A. Volume Group
- B. vDisk based provisioning
- C. Volume Group with Load Balancing
- D. Storage Spaces
答案:A
解題說明:
In Nutanix Era, a Volume Group is the recommended storage provisioning method for a large I/O- intensive database that doesn't support a multi-disk layout. A Volume Group in Nutanix Era is a collection of disks that can be managed as a single entity, providing a way to aggregate the storage capacity of multiple disks into a larger storage unit. This allows for better performance optimization as it enables the database to leverage the combined I/O capabilities of all the disks in the group. It's important to note that while other options like Load Balancing, Storage Spaces, and vDisk based provisioning can also be used in certain scenarios, a Volume Group is specifically designed for situations where a single, high-performance storage unit is required.
問題 #89
Within the NDB GUI, an administrator needs to set the shortest schedule interval possible for a database log catch up.
Which value, in minutes, will satisfy this requirement?
答案:D
解題說明:
The NDB GUI allows an administrator to set the schedule interval for a database log catch up, which is the process of collecting transaction logs periodically from the source databases and storing them in the time machine. The shortest possible value for this interval is 15 minutes, as per the NDB documentation. This means that the NDB time machine will capture the database logs every 15 minutes and use them for backup, restore, clone, and refresh operations.
問題 #90
A DBA team needs to release PostgreSQL HA instances using a dedicated subnet. Which action is mandatory before creating the network profile?
- A. A VLAN must be added to NDB networks.
- B. The subnet in Prism Element must be iPAM configured.
- C. Configure Network Segmentation.
- D. The DB VMs must be registered first.
答案:A
解題說明:
To release PostgreSQL HA instances using a dedicated subnet in Nutanix Database Service (NDB), the administrator must create a network profile that defines the subnet and its associated VLAN. Before creating this network profile, it is mandatory to add a VLAN to the NDB Networks configuration. This VLAN ensures that the dedicated subnet is recognized and manageable within NDB, allowing the HA instances to be provisioned with isolated network connectivity. The VLAN must be configured in the NDB Networks page to be available for selection during network profile creation.
問題 #91
The NDB user interface can display which language option?
- A. French
- B. Korean
- C. German
- D. Japanese
答案:D
解題說明:
The NDB user interface supports multiple languages, including English, Chinese, and Japanese.
You can change the language pReference: in the NDB settings page. The NDB user interface does not support Korean, French, or German languages at this time.
問題 #92
PDFExamDumps是一个为考生们提供IT认证考试的考古題并能很好地帮助大家的网站。PDFExamDumps通過活用前輩們的經驗將歷年的考試資料編輯起來,製作出了最好的NCP-DB-6.10考古題。考古題裏的資料包含了實際考試中的所有的問題,可以保證你一次就成功。
NCP-DB-6.10考試備考經驗: https://www.pdfexamdumps.com/NCP-DB-6.10_valid-braindumps.html
不要再猶豫了,如果想體驗一下考古題的內容,那麼快點擊PDFExamDumps NCP-DB-6.10考試備考經驗的網站獲取吧,但是如何輕松拿到NCP-DB-6.10認證哪,Nutanix NCP-DB-6.10更新 我們的模擬測試題及答案和真實考試的題目及答案有95%的相似性,通過我們提供的測試題您可以100%通過考試,於是,NCP-DB-6.10問題集練習便成了很多人用來準備NCP-DB-6.10考試的最直接有效的方式之一,Just Do It,Nutanix NCP-DB-6.10更新 想通過IT來證明自己的實力嗎,而NCP-DB-6.10考題資料能幫考生掌握考試所需要的知識點,擁有良好的口碑,只要你選擇Nutanix NCP-DB-6.10考古題作為你的考前復習資料,你就會相信自己的選擇不會錯,所以PDFExamDumps提供的資料的品質很高,具有很高權威性,絕對可以盡全力幫你通過Nutanix NCP-DB-6.10 認證考試。
我笑爾等有眼無珠,不識真神,第322章 四方城 幾番猶豫之後,玉山道人還是決定拜訪陸放鶴,不要再猶豫了,如果想體驗一下考古題的內容,那麼快點擊PDFExamDumps的網站獲取吧,但是如何輕松拿到NCP-DB-6.10認證哪,我們的模擬測試題及答案和真實考試的題目及答案有95%的相似性,通過我們提供的測試題您可以100%通過考試。
已通過驗證NCP-DB-6.10更新和資格考試領導者及100%合格率NCP-DB-6.10考試備考經驗於是,NCP-DB-6.10問題集練習便成了很多人用來準備NCP-DB-6.10考試的最直接有效的方式之一,Just Do It!
- 最實用的NCP-DB-6.10認證考古題 👋 ⮆ [url]www.newdumpspdf.com ⮄網站搜索《 NCP-DB-6.10 》並免費下載NCP-DB-6.10熱門證照[/url]
- 完美的Nutanix NCP-DB-6.10更新&權威的Newdumpspdf - 資格考試的領先供應商 🐽 ▛ [url]www.newdumpspdf.com ▟是獲取▷ NCP-DB-6.10 ◁免費下載的最佳網站NCP-DB-6.10考證[/url]
- 新版NCP-DB-6.10題庫上線 ✨ NCP-DB-6.10熱門證照 ☘ 新版NCP-DB-6.10題庫上線 🐠 打開網站➤ [url]www.kaoguti.com ⮘搜索▛ NCP-DB-6.10 ▟免費下載NCP-DB-6.10題庫資訊[/url]
- NCP-DB-6.10認證考試解析 ↙ NCP-DB-6.10考題套裝 🧡 NCP-DB-6.10真題 🌃 在⏩ [url]www.newdumpspdf.com ⏪網站上免費搜索⇛ NCP-DB-6.10 ⇚題庫NCP-DB-6.10參考資料[/url]
- 高通過率的NCP-DB-6.10更新:Nutanix Certified Professional - Database Automation (NCP-DB) v6.10 - 有效Nutanix NCP-DB-6.10考試備考經驗 🎱 【 [url]www.newdumpspdf.com 】上搜索[ NCP-DB-6.10 ]輕鬆獲取免費下載NCP-DB-6.10題庫資訊[/url]
- 高質量的NCP-DB-6.10更新和準確的Nutanix認證培訓 - 通過無憂Nutanix Nutanix Certified Professional - Database Automation (NCP-DB) v6.10 📻 在⇛ [url]www.newdumpspdf.com ⇚網站上查找【 NCP-DB-6.10 】的最新題庫NCP-DB-6.10證照[/url]
- NCP-DB-6.10考題資訊 🧄 NCP-DB-6.10認證考試解析 🥙 最新NCP-DB-6.10考古題 🧮 立即在▷ [url]www.pdfexamdumps.com ◁上搜尋⇛ NCP-DB-6.10 ⇚並免費下載最新NCP-DB-6.10考古題[/url]
- NCP-DB-6.10熱門考古題 😳 最新NCP-DB-6.10考古題 🐁 NCP-DB-6.10資料 ⤴ ➤ [url]www.newdumpspdf.com ⮘最新“ NCP-DB-6.10 ”問題集合NCP-DB-6.10證照[/url]
- NCP-DB-6.10考證 🧹 NCP-DB-6.10題庫資訊 🐠 最新NCP-DB-6.10題庫資訊 🧢 在▶ [url]www.pdfexamdumps.com ◀搜索最新的《 NCP-DB-6.10 》題庫NCP-DB-6.10考證[/url]
- NCP-DB-6.10證照指南 🚧 NCP-DB-6.10題庫資訊 😡 NCP-DB-6.10熱門題庫 💔 打開✔ [url]www.newdumpspdf.com ️✔️搜尋☀ NCP-DB-6.10 ️☀️以免費下載考試資料最新NCP-DB-6.10題庫資源[/url]
- 高通過率的NCP-DB-6.10更新:Nutanix Certified Professional - Database Automation (NCP-DB) v6.10 - 有效Nutanix NCP-DB-6.10考試備考經驗 🎣 打開網站☀ tw.fast2test.com ️☀️搜索☀ NCP-DB-6.10 ️☀️免費下載最新NCP-DB-6.10題庫資訊
P.S. PDFExamDumps在Google Drive上分享了免費的、最新的NCP-DB-6.10考試題庫:https://drive.google.com/open?id=1RFeDaiTFOOH87kk7Zi0XZsgLjgQVcL30
