[General] GAQM CNA-001 ExamQuestions - 100% Success
84
【General】 GAQM CNA-001 ExamQuestions - 100% Success
Posted at 1/25/2026 10:23:44      View:138 | Replies:1        Print      Only Author   [Copy Link] 1#
P.S. Free & New CNA-001 dumps are available on Google Drive shared by PrepAwayPDF: https://drive.google.com/open?id=1pZifUJs2AS6t_Bbqvntl62QSEEQWQ2JJ
In today's competitive GAQM industry, only the brightest and most qualified candidates are hired for high-paying positions. Obtaining CNA-001 certification is a wonderful approach to be successful because it can draw in prospects and convince companies that you are the finest in your field. Pass the Certified Nursing Assistant (CNA) to establish your expertise in your field and receive certification. However, passing the Certified Nursing Assistant (CNA) CNA-001 Exam is challenging.
To be eligible for the GAQM CNA-001 Exam, candidates must have a high school diploma or equivalent and have completed a state-approved CNA training program. It is important to note that the requirements for CNA certification may vary by state, and candidates should check with their state's nursing board to ensure they meet the eligibility requirements.
CNA-001 Questions - Highly Recommended By ProfessionalsThe community has a lot of talent, people constantly improve their own knowledge to reach a higher level. But the country's demand for high-end IT staff is still expanding, internationally as well. So many people want to pass GAQM CNA-001 certification exam. But it is not easy to pass the exam. However, in fact, as long as you choose a good training materials to pass the exam is not impossible. We PrepAwayPDF GAQM CNA-001 Exam Training materials in full possession of the ability to help you through the certification. PrepAwayPDF website training materials are proved by many candidates, and has been far ahead in the international arena. If you want to through GAQM CNA-001 certification exam, add the PrepAwayPDF GAQM CNA-001 exam training to Shopping Cart quickly!
GAQM Certified Nursing Assistant (CNA) Sample Questions (Q30-Q35):NEW QUESTION # 30
True or False: A CNA should report if a resident has not had a bowel movement for three days.
  • A. False
  • B. True
Constipation can lead to serious complications and must be reported.
NEW QUESTION # 31
Which one of the following is a common sign of low oxygen levels?
  • A. Bluish fingertips
  • B. Slow pulse
  • C. Warm skin
  • D. Pink lips
Cyanosis (bluish discoloration) is a classic sign of hypoxia.
NEW QUESTION # 32
Which of the following is the correct procedure when using a fire extinguisher?
  • A. PASS
  • B. HELP
  • C. SAFE
  • D. PUSH
PASS = Pull, Aim, Squeeze, Sweep - the standard method for fire extinguisher use.
NEW QUESTION # 33
Which of the following requires a CNA to use a gait belt?
  • A. Feeding a resident in bed
  • B. Doing laundry
  • C. Ambulating an unsteady resident
  • D. Assisting with phone calls
A gait belt provides stability and prevents falls during ambulation.
NEW QUESTION # 34
True or False: When shaving a resident taking blood thinners, an electric razor should be used.
  • A. False
  • B. True
Electric razors reduce the risk of cuts and bleeding, which is critical for patients on anticoagulants.
NEW QUESTION # 35
You will have prior experience in answering questions with adjustable time. With these features, you will improve your Certified Nursing Assistant (CNA) CNA-001 exam confidence and time management skills. Many candidates prefer to prepare for the Certified Nursing Assistant (CNA) CNA-001 Exam Dumps using different formats. The Certified Nursing Assistant (CNA) CNA-001 exam questions were designed in different formats so that every candidate could select what suited them best.
CNA-001 Latest Test Online: https://www.prepawaypdf.com/GAQM/CNA-001-practice-exam-dumps.html
BONUS!!! Download part of PrepAwayPDF CNA-001 dumps for free: https://drive.google.com/open?id=1pZifUJs2AS6t_Bbqvntl62QSEEQWQ2JJ
Posted at 2/12/2026 01:36:59        Only Author  2#
So much wisdom in this article, thank you for sharing it! This is the Actual 72201T test answers exam that helped me get promoted and earn a pay raise. It’s available for free today—good luck with your career goals!
