[General] Test CRT-450 Questions Fee | Reliable CRT-450 Test Tips
【General】 Test CRT-450 Questions Fee | Reliable CRT-450 Test Tips
Posted at 2/20/2026 18:23:51      View:79 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Salesforce CRT-450 dumps are available on Google Drive shared by ExamCost: https://drive.google.com/open?id=1h_9XfJbkt7Vvv7Qu4iK593-HgSQBeR7Z
If you want to get a desirable opposition and then achieve your career dream, you are a right place now. Our CRT-450 study tool can help you pass the exam. So, don't be hesitate, choose the CRT-450 test torrent and believe in us. Let's strive to our dreams together. Life is short for us, so we all should cherish our life. Our CRT-450 Guide Torrent can help you to save your valuable time and let you have enough time to do other things you want to do. Just buy our CRT-450 exam questions, then you will pass the CRT-450 exam easily.
Salesforce CRT-450 exam is a valuable certification for individuals who want to start their career as a Salesforce platform developer. Salesforce Certified Platform Developer I certification is a foundation-level certification that assesses the essential knowledge and skills required to develop custom applications on the Salesforce platform. Passing the Salesforce CRT-450 exam demonstrates a candidate's proficiency in Salesforce development and validates their expertise in developing custom applications using Apex and Visualforce.
Salesforce CRT-450 Certification Exam contains 60 multiple-choice questions that need to be completed within 105 minutes. CRT-450 exam evaluates the developer's knowledge of Salesforce development best practices, Apex programming language, and the Salesforce Lightning Platform. Salesforce Certified Platform Developer I certification exam also assesses the candidate's ability to design and implement custom objects, custom fields, and custom relationships.
Reliable CRT-450 Test Tips - Valid CRT-450 Test ReviewIf you are unfamiliar with our CRT-450 practice materials, please download the free demos for your reference, and to some unlearned exam candidates, you can master necessities by our CRT-450 training prep quickly. Our passing rate of the CRT-450 Study Guide has reached up to 98 to 100 percent up to now, so you cannot miss this opportunity. And you will feel grateful if you choose our CRT-450 exam questions.
Salesforce CRT-450 certification exam is designed for professionals who are interested in building custom applications on the Salesforce platform. CRT-450 exam covers a wide range of topics, including the Salesforce development environment, data modeling and management, Apex programming language, Visualforce user interface framework, and testing and deployment. CRT-450 Exam aims to test the candidates' understanding of the Salesforce development process and their ability to design, develop, test, and deploy custom applications.
Salesforce Certified Platform Developer I Sample Questions (Q204-Q209):NEW QUESTION # 204
Refer to the component code 9fd requirements below:
Requirements
* For mobile devices. the information should display in three rows.
* For desktops and tablets, the information should display in a single row.
Requirement 2 is not displaying as desired.
Which option has the correct component code to meet the requirements for desktops end and tablets?
  • A.
  • B.
To meet the requirements:
For mobile devices, the content should display inthree rows.
For desktops and tablets, the content should display ina single row.
Explanation of Correct Option (B):The code useslightning:layoutItemwith appropriate sizing formediumDeviceSize="4", which ensures:
Mobile devices: Each layout item will occupy the full width (size="12"), resulting in three rows.
Tablets and desktops: Each layout item will occupy one-third of the row (mediumDeviceSize="4"), displaying in a single row.
Example Code from Option B:
<lightning:layoutmultipleRows="true">
<lightning:layoutItemsize="12"mediumDeviceSize="4">{!v.account.Name}</lightning:layoutItem>
<lightning:layoutItemsize="12"mediumDeviceSize="4">{!v.account.AccountNumber}</lightning:
layoutItem>
<lightning:layoutItemsize="12"mediumDeviceSize="4">{!v.account.Industry}</lightning:layoutItem>
</lightning:layout>
Option Aoes not account for mediumDeviceSize and will not adjust for tablets/desktops.
Option C:Uses incorrect sizing formediumDeviceSize, which may not display correctly for tablets/desktops.
Referenceightning Design System Grid
NEW QUESTION # 205
What is a correct pattern to follow when programming in Apex on a Multi-tenant platform?
  • A. DML is performed on one record at a time to avoid possible data concurrency issues.
  • B. Apex classes use the ''with sharing" keyword to prevent access from other server tenants.
  • C. Apex code is created in a separate environment from schema to reduce deployment errors.
  • D. Queries select the fewest fields and records possible to avoid exceeding governor limits.
NEW QUESTION # 206
A developer is tasked to perform a security review of the ContactSearch Apex class that exists in the system.
Within the class, the developer identifies the following method as a security threat:
ist<Contact> performSearch (String lastName} [
return Database.query('SELECT Id, FirstName, LastName FROM Contact WHERE LastName Like s'+lastName+'s'")?; What are two ways the developer can update the method to prevent a SOQL injection attack?
Choose 2 answers
  • A. Use variable binding and replace the dynamic query with a static SOQL.
  • B. Use the Readonly annotation and the with sharing keyword on the class.
  • C. Use the sacapeSingleQuotes method to sanitize the parameter before its use.
  • D. Use a regular expression on the parameter to remove special characters.
Option A: Using variable binding eliminates the need for concatenating dynamic values in the query, which is the safest approach.
Option B: UsingString.escapeSingleQuotesensures special characters are handled safely, reducing the risk of SOQL injection.
Not Suitable:
Option C: Whilewith sharingensures sharing rules are applied, it does not prevent SOQL injection.
Option D: Regular expressions are not a reliable method for sanitizing input.
Preventing SOQL Injection
NEW QUESTION # 207
A developer wants to import 500 Opportunity records into a sandbox.
Why should the developer choose to use Data Loader instead of Data Import Wizard?
  • A. Data Loader runs from the developer's browser.
  • B. Data Import Wizard does not support Opportunities.
  • C. Data Import Wizard can not import all 500 records.
  • D. Data Loader automatically relates Opportunities to Accounts.
NEW QUESTION # 208
When a user edits the Postal Code on an Account, a custom Account text field named ''Timezone'' must be updated based on the values another custom object object called.
What is the optimal way to Implement this feature?
  • A. Create an account approval process.
  • B. Build a flow with flow Builder.
  • C. Build an account assignment rule.
  • D. Create a formula field.
The optimal way to implement this feature is to build a flow with Flow Builder. Flow Builder is a tool that lets you automate business processes by creating flows that execute logic, interact with Salesforce, and call Apex classes. You can use Flow Builder to create a record-triggered flow that runs when an Account record is updated. In the flow, you can use a Get Records element to query the custom object based on the Postal Code field of the Account record. Then, you can use an Assignment element to assign the value of the Timezone field from the custom object record to the Timezone field of the Account record. Finally, you can use an Update Records element to save the changes to the Account record.
Option B is incorrect because an account assignment rule is used to automatically assign account owners based on criteria. It does not update other fields on the account record.
Option C is incorrect because a formula field is a read-only field that derives its value from a formula expression. It cannot be updated by the user or by a trigger.
Option D is incorrect because an account approval process is used to require approval from one or more users before an account record can be saved. It does not update other fields on the account record.
References: Flow Builder (Trailhead)), Record-Triggered Flows (Trailhead)), Account Assignment Rules (Salesforce Help)), Formula Fields (Salesforce Help)), Approval Processes (Salesforce Help))
NEW QUESTION # 209
Reliable CRT-450 Test Tips: https://www.examcost.com/CRT-450-practice-exam.html
2026 Latest ExamCost CRT-450 PDF Dumps and CRT-450 Exam Engine Free Share: https://drive.google.com/open?id=1h_9XfJbkt7Vvv7Qu4iK593-HgSQBeR7Z
