[General] 350-501㏊rg & 350-501ģM
106
General 350-501㏊rg & 350-501ģM
Posted at 2/14/2026 14:51:24      View159 | Replies1        Print      Only Author   [Copy Link] 1#
P.S.MogiExamGoogle DriveǹФƤoϤ2026 Cisco 350-501ףhttps://drive.google.com/open?id=1tlmvgehECWi_TODGUeWMcukv71f0mqe9
θǤϡMogiExamϤYδu򲩤ΤҡϤĤYԇYեȤ_k뤫ǤСҡΤ褯kӤƤCisco350-501ԇYեȤϴԇY}ؤоˤä뤳ȤǤԇYʧȫ~Ƿ𤹤ȤZȤԤƷäۤȤɤYԇY˺ϸ񤷤ޤ
Cisco 350-501ԇYϡ`ӥץХ`ͥåȥ`󥰤θȼg⤹뤳ȤҪ󤵤ĤyԇYǤԇY90〜110Ά}阋ɤ졢120ڤˤҪޤԇYӢZձZÿܤǡФΤɤPearson VUEƥȥ󥿩`ǤYǤޤ
350-501ԇY˂䤨뤿ˤϡͥåȥ`Υ󥻥ץȤ似gˏ̤ʻA֤Υͥåȥ`CǤIUYҪǤϡvxe`˥󥰥⥸`롢ѧYϤʤɡޤޤʥȥ`˥󥰥`꥽`ṩơaߤԇY˂䤨Τޤ
һCisco 350-501㏊rg & ϸ񥹥`350-501ģM | һ350-501Ϥ͘νԘ^뤿ˡʤ˸ߤƥΥ`ӥṩǤŬƤޤޤǡMogiExam350-501}ϤΥ`ؤäƅfޤmǤ350-501}ʹä͘ϤۤȤԇY˺ϸ񤷤ޤ
Cisco 350-501Implementing and Operating Cisco Service Provider Network Core TechnologiesϡCiscoΥ`ӥץХ`ͥåȥ`gΌgװ\äˤ낀ˤ֪RȥƥȤ뤿JԇYǤԇYϡ`ӥץХ`ͥåȥ`󥰤ηҰǤΌT֪R^ηҰǤΥꥢM᤿TҤȤƤޤ
Cisco Implementing and Operating Cisco Service Provider Network Core Technologies J 350-501 ԇY} (Q272-Q277):| # 272
Which configuration must be applied to each of the four routers on the network to reduce LDP LIB size and advertise label bindings for the /32 loopback IP space only?
  • A. Option D
  • B. Option B
  • C. Option A
  • D. Option C
⣺C
| # 273
Refer to the exhibit:
R1 and R2 are directly connected with Fast Ethernet interfaces and have the above configuration applied OSPF adjacency is not formed. When the debug ip ospf hello command is issued on R1. these log messages are seen.
Which command can be configured on routers R1 and R2 on fO/O interfaces to form OSPF adjacency?
  • A. ip ospf network non-broadcast
  • B. ip ospf network point-to-point
  • C. ip ospf network broadcast
  • D. ip ospf network point-to- multipoint non-broadcast
⣺B
| # 274
How is RSVP used with MPLS traffic engineering tunnels?
  • A. It assigns a tag to a packet as it travels through the tunnel.
  • B. It removes and reassigns an MPLS label when the packet enters the tunnel.
  • C. It reserves bandwidth along the path of the tunnel.
  • D. It reduces the CPU burden when a packet travels through the tunnel.
⣺D
| # 275
Simulation 5
h
See the solution below:
R1
router ospf 10
redistribute static
int et0/0
ip ospf hello-interval 5
ip ospf dead-interval 10
ip ospf cost 15
ip ospf 10 area 0
copy run start
R2
router ospf 10
redistribute static
int et0/0
ip ospf cost 15
ip ospf 10 area 0
copy run start
| # 276
A network administrator is implementing IGMP to enable multicast feed transmission to the receiver. Which configuration must the administrator deploy on GW1 to permit IGMP Joins only to the assigned (S, G) feed?
  • A.
  • B.
  • C.
  • D.
⣺C
h
Option A corresponds to the desired configuration. It uses an access-list to permit IGMP joins for the specific multicast group 239.10.10.10 from the source 172.20.20.3.
Options B, C, and D do not match the desired configuration. They either allow all IGMP traffic or do not specify the correct source and group addresses.
| # 277
350-501ģM: https://www.mogiexam.com/350-501-exam.html
BONUS MogiExam 350-501פһoϤǥ`ɣhttps://drive.google.com/open?id=1tlmvgehECWi_TODGUeWMcukv71f0mqe9
Posted at 2/14/2026 19:26:44        Only Author  2#
Die Prfungsfragen und Antworten zur SAP C_THR82_2505 Zertifizierungsprfung von ExamFragen wird von unserem Expertenteam nach ihren umfangreichen Kenntnissen und Erfahrungen berarbeitet. Sie können die Bedrfnisse der Kandidaten abdecken. Sie finden vielleicht in anderen Bchern oder auf anderen Websites auch die SAP C_THR82_2505 Schulungsunterlagen. Aber die Schulungsunterlagen von ExamFragen sind die umfassendste unter ihnen und zugleich kann Ihnen die beste Garantie geben. Bitte wählen Sie die SAP C_THR82_2505 Prfungsfragen und Antworten von ExamFragen.
