100% Pass Quiz High Hit-Rate Cisco - 800-150 - Supporting Cisco Devices for Fiel
Posted at 1/11/2026 20:53:35
View203
Replies2
DOWNLOAD the newest PracticeDump 800-150 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1I8_tig5I0E81mPSpBoUG93rDbYV-dSpL
In this way, you can clear all your doubts and understand each topic well. Cisco Dumps PDF are customizable and simulate the real Supporting Cisco Devices for Field Technicians (800-150) test scenario. The desktop-based 800-150 Practice Exam software works on Windows. The web-based 800-150 practice exam is compatible with all operating systems and browsers.
Cisco 800-150 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Cisco Software: This section of the exam measures the skills of a Network Engineer and discusses Ciscos software systems and licensing. It explains the difference between IOS install and bundle modes and gives an overview of different licensing models. Students learn how to manage Cisco software images, including backing up, transferring, and installing images via FTP, TFTP, or USB. It also covers how to handle configuration files to keep devices running properly and ensure smooth upgrades or replacements.
| | Topic 2 | - Cisco Hardware Replacement: This section of the exam measures the skills of a Technical Support Engineer and teaches how to safely and correctly replace Cisco hardware. It explains safety procedures such as creating safe work zones and handling electrostatic discharge. Students learn the step-by-step processes to replace a wide range of Cisco devices, from switches and routers to firewalls, UCS servers, and collaboration endpoints. It also covers configuring Cisco NX-OS software, including understanding operating modes, boot procedures, and password recovery, and introduces Cisco collaboration endpoint solutions like IP phones and video systems.
| | Topic 3 | - Networking Foundations: This section of the exam measures the skills of a Network Engineer and covers the basic building blocks of computer networking. It explains different types of networks like local area networks and wireless networks, and introduces lightweight wireless LANs. It describes the layers of communication models like the OSI model and TCP
- IP stack, and explains how data moves across networks. It also discusses the physical cabling used in networks, such as Ethernet and fiber optics. Students will learn about network switching, IP addressing, subnetting, and routing at Layer 3. The section also introduces Ciscos campus network devices, data center switches, UCS servers, and collaboration devices, describing their roles and functions in the network.
| | Topic 4 | - Cisco Infrastructure and Collaboration Infrastructure: This section of the exam measures the skills of a Collaboration Engineer and focuses on Cisco infrastructure devices, endpoints, and collaboration technologies. It introduces network devices, collaboration endpoints like IP phones and video systems, and explains on-premises collaboration deployments using tools like Cisco Unified Communications Manager. It also covers how video systems integrate into collaboration environments and highlights Ciscos cloud services for enterprise communication, including Webex Meetings, Webex Teams, and hosted collaboration solutions.
| | Topic 5 | - Cisco UCS and Data Center Architecture: This section of the exam measures the skills of a Data Center Engineer and introduces Ciscos UCS and data center solutions. It explains the devices found in a data center, including switches, UCS servers, and director switches, and describes different server deployment models. Students will also learn about virtualization components like virtual machines, hypervisors, cloud computing concepts, and deployment models. The section covers how Cisco UCS devices fit into campus networks, edge locations, and data centers, and explains the key components and connections used in UCS architecture.
Dumps 800-150 Free Download & Online 800-150 Training MaterialsAs the professional provider of exam related materials in IT certification test, PracticeDump has been devoted to provide all candidates with the most excellent questions and answers and has helped countless people pass the exam. PracticeDump Cisco 800-150 study guide can make you gain confidence and help you take the test with ease. You can pass 800-150 Certification test on a moment's notice by PracticeDump exam dumps. Isn't it amazing? But it is true. As long as you use our products, PracticeDump will let you see a miracle.
Cisco Supporting Cisco Devices for Field Technicians Sample Questions (Q82-Q87):NEW QUESTION # 82
Which cable type should be used when installing replacement hardware and connecting two devices of the same type, like two DTEs or two DCEs?
- A. USB Type A to Type B cable
- B. Rolled RJ-45 to RJ-45 console cable
- C. RJ-45 Ethernet crossover patch cable
- D. RJ-45 Ethernet straight-through patch cable
When connectingtwo devices of the same type(e.g., two routers, two switches, or two DTEs), acrossover cableis required. This cable swaps the transmit and receive pairs to allow direct communication between devices without the need for an intermediate device like a switch.
* Straight-through cablesare used to connect different types of devices (e.g., PC to switch).
* Rolled cablesare used for console access.
* USB Type A to Bcables are typically used for peripheral device connections, not networking.
Reference:Supporting Cisco Devices for Field Technicians (FLDTEC) - Cisco Equipment and Related Hardware
NEW QUESTION # 83
How must the power to a system with dual power supplies on aCisco Nexus switch be connected?
- A. Connect the primary power supply to the main source and the secondary to a backup generator.
- B. Connect each power supply to a separate power source.
- C. Connect both power supplies to a power distribution unit with built-in redundancy.
- D. Connect both power supplies to a single power source.
In a Cisco Nexus switch withdual power supplies, the recommended method is toconnect each power supply to a separate power source(Option C). This ensures power redundancy and fault tolerance.
If one power source fails (e.g., due to a power outage or circuit failure), the switch can continue operating uninterrupted using the second power source. Connecting both to a single source (Option D) defeats the purpose of redundancy.
NEW QUESTION # 84
Drag and drop the steps from the left into order to capture the status of a Cisco device.
This procedure is taught in theFLDTEC courseunder theDevice Configuration and Verificationsection and reflects standard field technician workflows:
* Connect to the console portusing a console cable and terminal software (like PuTTY or Tera Term).
* Access the CLIof the Cisco device by logging in via the console session.
* Create a log fileor enable logging in the terminal emulator to begin capturing output.
* Check the router statususing commands such as show running-config, show ip interface brief, or show version.
* Save the output filefrom the terminal emulator for documentation, troubleshooting, or escalation.
This logical flow ensures accurate diagnostics and traceability during field support operations.
NEW QUESTION # 85
What is the first action that must be taken before removing a standby supervisor module from a Cisco MDS
9700 Series Switch?
- A. Shut down the entire switch.
- B. Disconnect all network interface cables.
- C. Perform a manual failover to the standby supervisor.
- D. Put themodule into out-of-service mode.
In theFLDTEC course, the process for removing or replacing asupervisor module- especially thestandby supervisor- in a modular switch like theCisco MDS 9700is clearly outlined. Cisco documentation states:
"Before removing a standby supervisor module, it must first be placed into out-of-service mode using the CLI command system no supervisor <slot-number> or via the appropriate management interface." This action ensures the systemacknowledges the supervisor is no longer participating in redundancy, allowing a safe and controlled removal without impacting system operations.
Why not the other options?
* A. Shut down the entire switch# Not required; MDS switches are built for high availability and allow hot-swap operations.
* C. Disconnect all network interface cables# This applies to line cards or interfaces, not to supervisor removal specifically.
* D. Perform a manual failover# Failover is requiredwhen removing the active supervisor, not the standby one.
NEW QUESTION # 86
Which pod-based deployment model provides the most flexibility and scalability in a modern data center topology?
- A. Spine-and-Leaf
- B. End of Row (EoR)
- C. Top of Rack (ToR)
- D. Fabric Extender model
TheSpine-and-Leafarchitecture is the preferredpod-based deployment modelin modern data centers because of itshigh scalability and flexibility. In this topology:
* Leaf switchesconnect to servers and act as the access layer.
* Spine switchesfunction as the core layer, interconnecting all leaf switches.
This non-blocking, highly redundant model supportspredictable latency, easy horizontal scaling, and load balancing, making it ideal for cloud-scale and virtualized environments.
* Top of Rack (ToR)andEnd of Row (EoR)are physical cabling layouts that do not inherently provide the same level of architectural scalability.
* Fabric Extender modelsextend switch ports but depend on upstream switches for intelligence, limiting flexibility.
NEW QUESTION # 87
To keep the 800-150 practice questions in Cisco PDF format up to date, we regularly update them to according to changes in the real 800-150 exam content. This dedication to keep Supporting Cisco Devices for Field Technicians (800-150) exam questions relevant to the 800-150 actual test domain ensures that customers always get the most up-to-date Cisco 800-150 questions from PracticeDump.
Dumps 800-150 Free Download: https://www.practicedump.com/800-150_actualtests.html
- 800-150 Valid Test Tutorial 🧉 800-150 Exam Paper Pdf 😯 Exam 800-150 Revision Plan 🗻 Simply search for 800-150 for free download on [url]www.prepawayete.com 👙Certification 800-150 Exam Dumps[/url]
- 800-150 Test Centres 🧼 Exam 800-150 Online 💔 Examinations 800-150 Actual Questions 🤍 Search on ➥ [url]www.pdfvce.com 🡄 for 800-150 to obtain exam materials for free download 🍉Valid 800-150 Vce[/url]
- Exam Discount 800-150 Voucher 🏞 Latest 800-150 Exam Objectives 🥫 Real 800-150 Exam 👋 Simply search for ⮆ 800-150 ⮄ for free download on ▷ [url]www.prepawayexam.com ◁ 🚒Real 800-150 Exam[/url]
- Cisco 800-150 Test Centres: Supporting Cisco Devices for Field Technicians - Pdfvce Providers you Best Dumps Free Download 🍈 Easily obtain 800-150 for free download through ➤ [url]www.pdfvce.com ⮘ 🔦Real 800-150 Exam[/url]
- Exam 800-150 Online 😕 800-150 Reliable Exam Test 🏓 Dumps 800-150 Free 🎈 Open ➠ [url]www.exam4labs.com 🠰 and search for ➡ 800-150 ️⬅️ to download exam materials for free 🏳800-150 Test Centres[/url]
- Free PDF Quiz High-quality Cisco - 800-150 Test Centres ⏲ Open website ▷ [url]www.pdfvce.com ◁ and search for ⇛ 800-150 ⇚ for free download 🏯800-150 Latest Exam Discount[/url]
- Use Cisco 800-150 PDF Questions And Get Excellent Marks 👠 Search for ➤ 800-150 ⮘ on ▶ [url]www.pdfdumps.com ◀ immediately to obtain a free download 🥰Test 800-150 Prep[/url]
- Valid 800-150 Exam Practice Material: Supporting Cisco Devices for Field Technicians and Training Study Guide - Pdfvce 🆘 Open ➡ [url]www.pdfvce.com ️⬅️ and search for ➠ 800-150 🠰 to download exam materials for free 💄800-150 Exam Paper Pdf[/url]
- Test 800-150 Prep 🍼 800-150 Valid Test Tutorial ✨ 800-150 Reliable Exam Test 👋 Search on [url]www.prepawaypdf.com for ➽ 800-150 🢪 to obtain exam materials for free download 🤕Exam Discount 800-150 Voucher[/url]
- Valid 800-150 Test Sims 🏥 Examinations 800-150 Actual Questions 💾 800-150 Exam Paper Pdf 📃 Download ▛ 800-150 ▟ for free by simply entering [url]www.pdfvce.com website 🌸Valid 800-150 Vce[/url]
- Cisco - High Hit-Rate 800-150 Test Centres ☣ Open website ▛ [url]www.prepawayete.com ▟ and search for ➽ 800-150 🢪 for free download 🟤Test 800-150 Prep[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, yu856.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, daotao.wisebusiness.edu.vn, www.stes.tyc.edu.tw, bbs.t-firefly.com, bbs.t-firefly.com, kumu.io, bbs.t-firefly.com, Disposable vapes
P.S. Free 2026 Cisco 800-150 dumps are available on Google Drive shared by PracticeDump: https://drive.google.com/open?id=1I8_tig5I0E81mPSpBoUG93rDbYV-dSpL
