[Hardware] RK-3566-PC EMMC Root Partition gets corrupted frequently
67
Hardware RK-3566-PC EMMC Root Partition gets corrupted frequently
Posted at 2/5/2024 23:11:21      View4611 | Replies8        Print      Only Author   [Copy Link] 1#
  • SDK Package Name: ROC-RK3566-PC-MIPI_Rk356x_v1.3.2f_240202.img
  • Modification Content: no modification
  • Log: log.zip
At random times, ubuntu 20.04 running on emmc breaks. The /boot partition becomes completely empty and all /usr/bin applications become inaccessible.
For example
root@aquadata:~# ls
-bash: /usr/bin/ls: No such file or directory
Even the basic linux application "ls" cannot be used. After this happens, the device does not boot at all on reboot. The only way to reboot is to use SD-boot or rewrite emmc with RkDevTool. I can't understand why.
I think it is a power problem or an automatic update problem.
I am using a 5v 2.4A adapter.
I have about 30 RK-3566-PCs and this problem is happening with all of them, no matter if they are Offical Image or Custom Image.
Can you help me with this ?
log.zip
785 Bytes, Down times: 5
Posted at 2/19/2024 16:57:30        Only Author  2#
There has never been such a situation as you mentioned before
1 Because this situation would not have occurred if EMMC had not been erased, could you recall what special actions were taken before this issue occurred?
2 Provide complete boot logs
3 Provide corresponding version information based on Wikipedia
https://wiki.t-firefly.com/en/Fi ... version-information
Posted at 10/23/2024 14:58:47        Only Author  3#
Thanks for sharing. The apps really bring better improvements to use.
Posted at 11/8/2024 14:45:40        Only Author  4#
Experience the excitement of dating stunning South Delhi Escorts Service who can make your wishes come true. Discover passion and intimacy that will entice you to return for more.
Posted at 10/18/2025 00:11:21        Only Author  5#
Reading about the RK-3566-PC EMMC root partition issue reminded me of how frustrating random system failures can be everything seems fine until it suddenly collapses without warning. Its kind of like online dating before you find the right platform: things look stable, but the connection just doesnt hold. After seeing a forum mention, I decided to try Join This 50 and Older Dating Site to Meet Mature Singles, and that experience felt like switching to a reliable system. The people there are witty, confident, and easy to talk to, and the conversations flow naturally without glitches or pressure. Its proof that, just like with tech, sometimes all you need is the right environment to keep things running smoothly.
Posted at 1/10/2026 04:00:10        Only Author  6#
Your article made such an impression on me, Im deeply appreciative. Im just about to take the 3V0-32.23 hot questions exam. Wish me success!
Posted at 1/21/2026 07:45:18        Only Author  7#
The article provided me with so much to ponder. The 1Z0-1145-1 reliable exam online system helped me secure a promotion and raise. Now its free for all. Hope your promotion is right around the corner!
Posted at 3/5/2026 12:44:40        Only Author  8#
This article has given me a lot of space for reflection, and Ive gained a lot. Improve your IT skills and get free FCSS_NST_SE-7.6 valid braindumps sheet. Best of luck in your studies!
Posted at 6/3/2026 22:19:58        Only Author  9#
my honest reaction it's cool
