[General] Salesforce Data-Con-101 Reliable Exam Camp, New Data-Con-101 Mock Test
97
【General】 Salesforce Data-Con-101 Reliable Exam Camp, New Data-Con-101 Mock Test
Posted at 2/15/2026 10:01:44      View:119 | Replies:0        Print      Only Author   [Copy Link] 1#
How you can gain the Data-Con-101 certification with ease in the least time? The answer is our Data-Con-101 study materials for we have engaged in this field for over ten years and we have become the professional standard over all the exam materials. You can free download the demos which are part of our Data-Con-101 Exam Braindumps, you will find that how good they are for our professionals devote of themselves on compiling and updating the most accurate content of our Data-Con-101 exam questions.
The Salesforce Data-Con-101 exam is necessary for you if you want to improve your professional career. Salesforce Data-Con-101 exam questions changes from time to time so, it is important to check for updates regularly otherwise you can miss an important thing in the middle of your Salesforce Data-Con-101 Questions preparation. After the purchase, you will get Data-Con-101 dumps' latest updates for up to 90 days as soon as they are available. If the ExamBoosts introduces new updates to Data-Con-101 study material within 90 days of your purchase then you will get them free of cost.
Salesforce Certified Data Cloud Consultant valid exam simulator & Salesforce Certified Data Cloud Consultant exam study torrent & Salesforce Certified Data Cloud Consultant test training guideThe software of Data-Con-101 guide torrent boosts varied self-learning and self-assessment functions to check the results of the learning. The software can help the learners find the weak links and deal with them. Our Data-Con-101 exam questions boost timing function and the function to stimulate the exam. Our product sets the timer to stimulate the exam to adjust the speed and keep alert. Our Data-Con-101 test torrents have simplified the complicated notions and add the instances, the stimulation and the diagrams to explain any hard-to-explain contents. So it is worthy for you to buy our Data-Con-101 exam questions.
Salesforce Data-Con-101 Exam Syllabus Topics:
  • Act on Data: This domain focuses on leveraging Data Cloud data for downstream actions through activations and data actions. It covers working with attributes, managing timing dependencies, troubleshooting activation issues like errors and rejected counts, and understanding requirements for triggering automated processes.
  • Data Cloud Setup and Administration: This domain focuses on configuring and managing Data Cloud environments through permissions, data streams, data bundles, and data spaces. It also covers administrative tools and techniques for diagnosing and exploring data using reports, dashboards, flows, APIs, and explorer tools.
  • Segmentation and Insights: This domain centers on creating audience segments and deriving analytical insights from Data Cloud. It includes configuring and maintaining segments, analyzing membership scenarios, and distinguishing between calculated insights and real-time streaming insights.
  • Data Ingestion and Modeling: This domain addresses bringing data into Data Cloud and structuring it properly through transformation, ingestion from various sources, and data mapping. It emphasizes best practices for modeling data to support identity resolution and validating ingested data using available tools.
Salesforce Certified Data Cloud Consultant Sample Questions (Q140-Q145):NEW QUESTION # 140
During discovery, which feature should a consultant highlight for a customer who has multiple data sources and needs to match and reconcile data about individuals into a single unified profile?
  • A. Data Consolidation
  • B. Data Cleansing
  • C. Harmonization
  • D. Identity Resolution
The feature that the consultant should highlight for a customer who has multiple data sources and needs to match and reconcile data about individuals into a single unified profile is D. Identity Resolution. Identity Resolution is the process of identifying, matching, and reconciling data about individuals across different data sources and creating a unified profile that represents a single view of the customer. Identity Resolution uses various methods and rules to determine the best match and reconciliation of data, such as deterministic matching, probabilistic matching, reconciliation rules, and identity graphs. Identity Resolution enables the customer to have a complete and accurate understanding of their customers and their interactions across different channels and touchpoints. References: Salesforce Data Cloud Consultant Exam Guide, Identity Resolution
NEW QUESTION # 141
Northern Trail Outfitters (NTO) is getting ready to start ingesting its CRM data into Data Cloud.
While setting up the connector, which type of refresh should NTO expect when the data stream is deployed for the first time?
  • A. Partial refresh
  • B. Manual refresh
  • C. Full refresh
  • D. Incremental
Data Stream Deployment: When setting up a data stream in Salesforce Data Cloud, the initial deployment requires a comprehensive data load.
Types of Refreshes:
Incremental Refresh: Only updates with new or changed data since the last refresh.
Manual Refresh: Requires a user to manually initiate the data load.
Partial Refresh: Only a subset of the data is refreshed.
Full Refresh: Loads the entire dataset into the system.
First-Time Deployment: For the initial deployment of a data stream, a full refresh is necessary to ensure all data from the source system is ingested into Salesforce Data Cloud.
Salesforce Documentation: Data Stream Setup
Salesforce Data Cloud Guide
NEW QUESTION # 142
A consultant has an activation that is set to publish every 12 hours, but has discovered that updates to the data prior to activation are delayed by up to 24 hours.
Which two areas should a consultant review to troubleshoot this issue?
Choose 2 answers
  • A. Review data transformations to ensure they're run after calculated insights.
  • B. Review segments to ensure they're refreshed after the data is ingested.
  • C. Review calculated insights to make sure they're run after the segments are refreshed.
  • D. Review calculated insights to make sure they're run before segments are refreshed.
The correct answer is B and C because calculated insights and segments are both dependent on the data ingestion process. Calculated insights are derived from the data model objects and segments are subsets of data model objects that meet certain criteria. Therefore, both of them need to be updated after the data is ingested to reflect the latest changes. Data transformations are optional steps that can be applied to the data streams before they are mapped to the data model objects, so they are not relevant to the issue. Reviewing calculated insights to make sure they're run after the segments are refreshed (option D) is also incorrect because calculated insights are independent of segments and do not need to be refreshed after them. References: Salesforce Data Cloud Consultant Exam Guide, Data Ingestion and Modeling, Calculated Insights, Segments
NEW QUESTION # 143
A consultant is planning the ingestion of a data stream that has profile information including a mobile phone number.
To ensure that the phone number can be used for future SMS campaigns, they need to confirm the phone number field is in the proper E164 Phone Number format. However, the phone numbers in the file appear to be in varying formats.
What is the most efficient way to guarantee that the various phone number formats are standardized?
  • A. Assign the PhoneNumber field type when creating the data stream.
  • B. Create a calculated insight after ingestion.
  • C. Create a formula field to standardize the format.
  • D. Edit and update the data in the source system prior to sending to Data Cloud.
The most efficient way to guarantee that the various phone number formats are standardized is to assign the PhoneNumber field type when creating the data stream. The PhoneNumber field type is a special field type that automatically converts phone numbers into the E164 format, which is the international standard for phone numbers. The E164 format consists of a plus sign (+), the country code, and the national number. For example, +1-202-555-1234 is the E164 format for a US phone number. By using the PhoneNumber field type, the consultant can ensure that the phone numbers are consistent and can be used for future SMS campaigns.
The other options are either more time-consuming, require manual intervention, or do not address the formatting issue. References: Data Stream Field Types, E164 Phone Number Format, Salesforce Data Cloud Exam Questions
NEW QUESTION # 144
The leadership team at Cumulus Financial has determined that customers who deposited more than $250,000 in the last five years and are not using advisory services will be the central focus for all new campaigns in the next year.
Which features support this use case?
  • A. Calculated insight and segment
  • B. Streaming insight and data action
  • C. Calculated insight and data action
  • D. Streaming insight and segment
Understanding the Use Case:
The leadership team wants to focus on customers who have deposited more than $250,000 in the last five years and are not using advisory services.
Reference: Salesforce Data Cloud Use Case Documentation
Features Involved:
Calculated Insight: This feature helps derive metrics and values based on existing data. In this case, it can calculate total deposits over the last five years.
Segment: Segmentation allows targeting specific groups of customers based on defined criteria, such as total deposits and usage of advisory services.
Reference: Salesforce Calculated Insights and Segmentation Guide
Steps to Implement:
Create a Calculated Insight:
Navigate to Visual Insights Builder in Salesforce Data Cloud.
Create a new calculated insight to sum deposits for each customer over the last five years.
Create a Segment:
Use the Segment Canvas to create a new segment.
Apply filters to include customers with deposits over $250,000 and exclude those using advisory services.
Reference: Salesforce Calculated Insights Tutorial and Segment Creation Guide Practical Application:
Example: Identify high-value customers who are not leveraging additional services and target them with personalized marketing campaigns to promote advisory services.
Reference: Salesforce High-Value Customer Segmentation Case Study
NEW QUESTION # 145
Our Data-Con-101 exam braindumps can lead you the best and the fastest way to reach for the certification and achieve your desired higher salary by getting a more important position in the company. Because we hold the tenet that low quality exam materials may bring discredit on the company. So we only creat the best quality of our Data-Con-101 Study Materials to help our worthy customers pass the exam by the first attempt. Tens of thousands of our customers have passed their exam. And you will be the next one if you buy our Data-Con-101 practice engine.
New Data-Con-101 Mock Test: https://www.examboosts.com/Salesforce/Data-Con-101-practice-exam-dumps.html
