[General] JN0-105 - Trustable Junos, Associate (JNCIA-Junos) Dumps PDF
139
【General】 JN0-105 - Trustable Junos, Associate (JNCIA-Junos) Dumps PDF
Posted at 2/8/2026 14:38:39      View:90 | Replies:1        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest It-Tests JN0-105 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1OTZmqipxCIhxCOL5kVq-_p0PTQWnuu7k
It-Tests is a professional website. It gives every candidate to provide quality services, including pre-sale service and after-sale service. If you need our products, you can be trying to use It-Tests Juniper JN0-105 free demo. Any place can be easy to learn with pdf real questions and answers! If it is ok, we look forward to your further contacts. If you unfortunately fail, we will refund all fees. And we will provide free updates for a year until you pass Juniper JN0-105 Certification.
The It-Tests team is updating the Juniper JN0-105 study material according to the changes in the syllabus on daily basis. The users will receive JN0-105 updates for 365 days so they can prepare according to the updated content. The 24/7 support system has been made for customers to solve their problems and serve them in the best possible ways in order to pass the Junos, Associate (JNCIA-Junos) (JN0-105) certification exam on the first try!
JN0-105 Latest Exam Simulator & JN0-105 Reliable Mock TestFree demos of It-Tests JN0-105 exam questions are available which you can download easily. Just choose the right It-Tests JN0-105 exam questions format and download the JN0-105 exam product demo free of cost. Check the top features of JN0-105 Exam Questions and if you feel that the It-Tests Junos, Associate (JNCIA-Junos) (JN0-105) certification exam practice material can work with you then take your buying decision and download it accordingly. Best of luck!!!
Juniper Junos, Associate (JNCIA-Junos) Sample Questions (Q78-Q83):NEW QUESTION # 78
Exhibit
user@router> show route 192.168.100.2
inet.O: 15 destinations, 17 routes (15 active, 0 holddown, 0 hidden) Limit/Threshold: 1048576/1048576 destinations
+ = Active Route, - = Last Active, * = Both 192.168.100.2/32*[OSPF/IO] 00:14:29, metric 1
> to 172.16.1.6 via ge-0/0/1.0 [BGP/170] 00:06:49, localpref 100
AS path: 65102 I, validation-state: unverified > to 172.16.1.6 via ge-0/0/1.0 Referring to the exhibit, which statement is correct?
  • A. The BGP route is preferred over the OSPF route.
  • B. / Traffic is load-balanced across two routes.
  • C. The OSPF path is the only active route.
  • D. The BGP path is the only active route.
Referring to the exhibit, the presence of the "+" symbol next to the OSPF route for 192.168.100.2/32 indicates that this is the active route being used to forward traffic. The BGP route, although present, does not have the
"+" symbol, indicating it is not the active route. In Junos OS, the routing table displays the active route with a
"+" symbol, and the fact that the OSPF route has this symbol means it is the preferred path based on the routing protocol'sdecision process, which takes into account factors such as route preference (administrative distance) and metrics.
NEW QUESTION # 79
Click the Exhibit button.
Referring to the exhibit, OSPF has three export policies that match different static route prefixes. The
10.10.10.0/24 static route does not match any terms in the policyl routing policy.
What happens next in this scenario?
  • A. Thestaticrouteisrejected by the default routing policy.
  • B. Thestaticrouteisevaluated by the poiicy3 routing policy.
  • C. Thestaticrouteisrejected by the policyl routing policy.
  • D. Thestaticrouteisevaluated by the poiicy2 routing policy.
In Junos, when multiple policies are applied to a routing protocol for route export, the routes are evaluated in the order in which the policies are listed. In the exhibit, the OSPF configuration has three export policies listed: policy1, policy2, and policy3. The static route 10.10.10.0/24 does not match any terms in policy1; therefore, it is not rejected by policy1 but is instead passed on to the next policy in the sequence, which is policy2.
If the static route matches a term in policy2 that permits the route, it will be exported into OSPF. If it does not match in policy2, it will then be evaluated by policy3. If there is no match in policy3 as well, and assuming there are no more policies listed, the route would then be subject to the default routing policy behavior, which typically rejects the route unless an explicit accept statement is present in the policies.
NEW QUESTION # 80
Which type of device uses the destination IP address to forward packets?
  • A. Layer 2 switch
  • B. repeater
  • C. Layer 3 router
  • D. hub
A Layer 3 router forwards packets based on the destination IP address. It operates at the network layer of the OSI model and uses routing tables to determine the best path for packet delivery. Unlike Layer 2 switches, which forward packets based on MAC addresses, routers handle logical addressing, making them crucial for inter-network communication.
NEW QUESTION # 81
A network administrator is attempting to route traffic on a Juniper switch to one of three different VLANs: Prod, Test, and Dev. Each VLAN has been assigned a numerical value.
In this scenario, what are these numerical values called?
  • A. tags
  • B. names
  • C. defaults
  • D. interfaces
In the context of VLANs (Virtual Local Area Networks) on a Juniper switch, the numerical values assigned to each VLAN, such as those for Prod, Test, and Dev, are known as VLAN tags. These tags are part of the 802.1Q VLAN standard, which allows multiple VLANs to coexist on a single physical network. Each tag uniquely identifies the VLAN to which a frame belongs, enabling the switch to segregate and manage traffic based on VLAN membership. This tagging mechanism allows for efficient traffic separation and management, ensuring that devices within one VLAN do not receive traffic intended for another, thus maintaining network security and efficiency.
NEW QUESTION # 82
Referring the exhibit, what does the highlighted number indicate?
  • A. cost is 5
  • B. route preference is 5
  • C. metric is 5
  • D. hop count is 5
In the exhibit shown, the highlighted number next to the route type (Static) within the square brackets indicates the route preference, also known as the administrative distance. In Junos, the route preference is a value that determines the priority of the route source. Lower numbers indicate a higher priority when the routing table is being calculated. The route preference is used to select the best route when multiple paths to the same destination exist from different routing sources. The number 5 is unusually low for a static route by default, suggesting it has been manually configured to override other route types.
NEW QUESTION # 83
It-Tests provides Junos, Associate (JNCIA-Junos) JN0-105 desktop-based practice software for you to test your knowledge and abilities. The Junos, Associate (JNCIA-Junos) JN0-105 desktop-based practice software has an easy-to-use interface. You will become accustomed to and familiar with the free demo for Junos, Associate (JNCIA-Junos) JN0-105 Exam Questions. Exam self-evaluation techniques in our Junos, Associate (JNCIA-Junos) JN0-105 desktop-based software include randomized questions and timed tests. These tools assist you in assessing your ability and identifying areas for improvement to pass the Junos, Associate (JNCIA-Junos) certification exam.
JN0-105 Latest Exam Simulator: https://www.it-tests.com/JN0-105.html
Our company has been providers of JN0-105 : Junos, Associate (JNCIA-Junos) dumps for many years and has been the pass-king in this this industry, With the help of our JNCIA valid dumps, you will get used to the atmosphere of JN0-105 free test in advance, which help you improve your ability with minimum time spent on the JN0-105 dumps pdf and maximum knowledge gained, The pass rate is 99% for JN0-105 exam materials, and most candidates can pass the exam by using JN0-105 questions and answers of us.
They proceeded to penetrate the security of JN0-105 the buildings and assemble bomb devices in the bathrooms, Funfair rides and programs, Our company has been providers of JN0-105 : Junos, Associate (JNCIA-Junos) dumps for many years and has been the pass-king in this this industry.
High Pass-Rate JN0-105 Dumps PDF - Pass JN0-105 Once - Fantastic JN0-105 Latest Exam SimulatorWith the help of our JNCIA valid dumps, you will get used to the atmosphere of JN0-105 free test in advance, which help you improve your ability with minimum time spent on the JN0-105 dumps pdf and maximum knowledge gained.
The pass rate is 99% for JN0-105 exam materials, and most candidates can pass the exam by using JN0-105 questions and answers of us, Our It-Tests platform is an authorized formal sales platform.
Juniper JN0-105 provides you with real-time Juniper JN0-105 exam environment for preparation.
2026 Latest It-Tests JN0-105 PDF Dumps and JN0-105 Exam Engine Free Share: https://drive.google.com/open?id=1OTZmqipxCIhxCOL5kVq-_p0PTQWnuu7k
Posted at 2/16/2026 13:17:57        Only Author  2#
This article has helped me understand related concepts better, and I’ve gained a lot. Here are the C-P2WAB-2507 reliable exam cost study materials for free—best of luck to everyone!
