PDI Exam Syllabus | Interactive PDI Practice Exam
Posted at 2/15/2026 08:04:23
BONUS!!! Download part of Dumps4PDF PDI dumps for free: https://drive.google.com/open?id=1hibgHc-poIinMvuPE2KmkAfLz4sQ2q8p
You will be able to apply for high-paying jobs in top companies worldwide after passing the Salesforce PDI test. The Salesforce PDI Exam provides many benefits such as higher pay, promotions, resume enhancement, and skill development.
Salesforce PDI Certification Exam is designed to test the candidate's ability to design, develop, and maintain custom applications on the Salesforce platform. Candidates will need to demonstrate their proficiency in Apex, Salesforce's proprietary programming language, as well as their knowledge of Visualforce, Salesforce's user interface framework. They will also need to be familiar with the Salesforce data model and know how to work with objects, relationships, and fields.
Salesforce PDI certification is a valuable credential for professionals who want to advance their careers in Salesforce development. Platform Developer I (PDI) certification demonstrates that a candidate has a deep understanding of the Salesforce platform and can develop custom applications that meet the needs of their organization. As the demand for Salesforce developers continues to grow, the PDI Certification is an excellent way for individuals to stand out in a competitive job market and increase their earning potential.
Salesforce PDI (Platform Developer I) Certification Exam is a valuable certification that demonstrates your skills and knowledge in developing custom applications on the Salesforce platform. PDI exam covers a range of topics, and with the right preparation, you can pass the exam and become a certified Salesforce professional. Platform Developer I (PDI) certification is highly respected in the industry and can open up new job opportunities and career growth.
PDI Pass-Sure Materials - PDI Quiz Bootcamp & PDI Test QuizDumps4PDF has a huge Salesforce industry elite team. They all have high authority in the PDI area. They use professional knowledge and experience to provide training materials for people ready to participate in different IT certification exams. The accuracy rate of exam practice questions and answers provided by Dumps4PDF is very high and they can 100% guarantee you pass the exam successfully for one time. Besides, we will provide you a free one-year update service.
Salesforce Platform Developer I (PDI) Sample Questions (Q113-Q118):NEW QUESTION # 113
A developer wants to handle the click event for a lightning:button componentthe onclick attribute for the component references a javascript function in which resource in the component bundle?
- A. Handler.js
- B. Controller.js
- C. Renderer.js
- D. Helper.js
NEW QUESTION # 114
Which two examples above use the system. debug statements to correctly display the results from the SOQL aggregate queries? Choose 2 answers
- A. Example 1
- B. Example 2
- C. Example 4
- D. Example 3
NEW QUESTION # 115
A developer created a trigger on the Account object and wants to test if the trigger is properly bulkified. The developer team decided that the trigger should be tested with 200 account records with unique names.
What two things should be done to create the test data within the unit test with the least amount of code?
Choose 2 answers
- A. Use the @isTest (isParallel=true) annotation in the test class.
- B. Create a static resource containing test data.
- C. Use Test.loadData to populate data in your test methods.
- D. Use the @isTest (seeAllData=true) annotation in the test class.
To test the trigger with 200 account records with unique names using the least amount of code:
Option A: Use Test.loadData to populate data in your test methods.
"Test.loadData lets you populate test records by loading the contents of a CSV file into sObjects for use in test methods."
- Apex Developer Guide: Using Test.loadData
Option B: Create a static resource containing test data.
"Create a static resource that contains the .csv file for the records you want to load."
- Apex Developer Guide: Loading Test Data from Static Resources
Option C: The @isTest(isParallel=true) annotation is used to run tests in parallel but does not help in creating test data.
Option D: Using @isTest(seeAllData=true) allows access to existing org data, which is not recommended and does not help create unique test data with minimal code.
NEW QUESTION # 116
A developer is asked to write helper methods that create test data for unit tests.
What should be changed in the TestUtils class so that its methods are only usable by unit test methods?
- A. Change public to private on line 01.
- B. Add @istest above line 01.
- C. Remove static from line 03.
- D. @isTest above line 03.
To ensure that the TestUtils class and its methods are only accessible by unit test methods, the class must be annotated with the @isTest annotation. This annotation limits the scope of the class and its methods to test contexts only.
Why @isTest?
Purpose of @isTest:
The @isTest annotation marks a class or method for use exclusively within test scenarios. It prevents the methods from being accidentally invoked in production code.
This ensures better test isolation and prevents misuse.
Static Test Data Methods:
Marking helper methods for test data creation as @isTest ensures they do not interfere with production code and are strictly for testing purposes.
Analysis of Options:
Option A: @isTest above line 03:
Incorrect. Applying @isTest only to the createAccount method would work, but the other methods in the class would still be accessible. This does not satisfy the requirement of restricting the entire class.
Option B: Add @isTest above line 01:
Correct. Annotating the class ensures all methods within the class are accessible only in the context of tests.
Option C: Change public to private on line 01:
Incorrect. Changing the class to private would cause a compilation error, as top-level classes in Salesforce cannot be declared private.
Option D: Remove static from line 03:
Incorrect. Removing static does not affect the test scope of the class or its methods. Static methods can still be invoked, and this does not restrict access to test contexts.
Correct Implementation:
The corrected code would look like this:
@isTest
public class TestUtils {
public static Account createAccount() {
Account acct = new Account();
// Set some fields on acct
return acct;
// Other methods...
Apex Testing: Test Classes and Methods
Trailhead Module on Apex Testing
NEW QUESTION # 117
A developer needs to prevent the creation of request records when certain conditions exist in the system. A RequestLogic class exists to checks the conditions. What is the correct implementation?
- A. Trigger RequestTrigger on Request (after insert) {
if (RequestLogic.isValid{Request})
Request.addError {'Your request cannot be created at this time.'};
} - B. Trigger RequestTrigger on Request (after insert) {
RequestLogic.validateRecords {trigger.new};
} - C. Trigger RequestTrigger on Request (before insert) {
if (RequestLogic.isvalid{Request})
} - D. Trigger RequestTrigger on Request (before insert) {
NEW QUESTION # 118
Many people don't get success because of using Platform Developer I (PDI) (PDI) invalid practice material. Usage of an expired Platform Developer I (PDI) (PDI) material leads to failure and loss of time and money. To save you from these losses, Dumps4PDF has a collection of actual and updated PDI Exam Questions. These Salesforce PDI practice questions will aid you in acing the test on the first attempt within a few days. This Platform Developer I (PDI) (PDI) exam dumps has been made under the expert guidance of thousands of professionals from various countries.
Interactive PDI Practice Exam: https://www.dumps4pdf.com/PDI-valid-braindumps.html
- Top PDI Exam Syllabus 100% Pass | Professional Interactive PDI Practice Exam: Platform Developer I (PDI) 🛷 Easily obtain 《 PDI 》 for free download through “ [url]www.vceengine.com ” 👶Dumps PDI Collection[/url]
- PDI Valid Exam Braindumps 🙌 Valid PDI Vce 🗺 New PDI Test Syllabus 🍧 Enter 「 [url]www.pdfvce.com 」 and search for ➡ PDI ️⬅️ to download for free 🎎New PDI Test Duration[/url]
- Clearer PDI Explanation 🤺 Valid PDI Real Test 🧄 Valid PDI Vce 🧣 Open [ [url]www.examcollectionpass.com ] and search for ▷ PDI ◁ to download exam materials for free ⚒
DI Free Brain Dumps[/url] - PDI Valid Exam Braindumps 🍚 PDI New Cram Materials 😍 Test PDI Simulator 🧊 Easily obtain “ PDI ” for free download through [ [url]www.pdfvce.com ] 😵
DI Valid Exam Braindumps[/url] - Valid PDI Vce 🥻 PDI Exam Materials ✴ Valid PDI Real Test ⭐ Go to website “ [url]www.examdiscuss.com ” open and search for 【 PDI 】 to download for free 👏Test PDI Simulator[/url]
- PDI Valid Exam Braindumps 🐃 PDI Valid Test Answers 🌭 Valid PDI Exam Voucher 🤘 Copy URL ▛ [url]www.pdfvce.com ▟ open and search for ⏩ PDI ⏪ to download for free 👩
DI Hot Questions[/url] - Valid PDI Exam Voucher ➡ PDI Mock Test 📲 New PDI Test Duration 🏛 Download ⮆ PDI ⮄ for free by simply searching on ➡ [url]www.practicevce.com ️⬅️ 🪕
DI Exam[/url] - 100% Pass The Best Salesforce - PDI Exam Syllabus ☸ Download 【 PDI 】 for free by simply searching on ✔ [url]www.pdfvce.com ️✔️ 🐔Test PDI Simulator[/url]
- PDI Training Materials: Platform Developer I (PDI) - PDI Exam Preparatory 🥯 Go to website [ [url]www.pass4test.com ] open and search for ➽ PDI 🢪 to download for free 🏐Study PDI Materials[/url]
- PDI Hot Questions 🔷 Clearer PDI Explanation 🖱 PDI Valid Test Answers 🙎 Copy URL ⮆ [url]www.pdfvce.com ⮄ open and search for ➡ PDI ️⬅️ to download for free 🚶Dumps PDI Collection[/url]
- Dumps PDI Collection 🏞 PDI Free Brain Dumps 😣 New PDI Test Syllabus 🥇 Open website ☀ [url]www.troytecdumps.com ️☀️ and search for ▷ PDI ◁ for free download ‼
DI Valid Test Answers[/url] - www.stes.tyc.edu.tw, courses.beinspired.co.za, dl.instructure.com, bbs.t-firefly.com, app.esevanakendram.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.fanart-central.net, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
BTW, DOWNLOAD part of Dumps4PDF PDI dumps from Cloud Storage: https://drive.google.com/open?id=1hibgHc-poIinMvuPE2KmkAfLz4sQ2q8p
