New Topic
[Linux] PWM control
154
Linux PWM control
Posted at 10/25/2022 21:59:48      View4380 | Replies10        Print      Only Author   [Copy Link] 1#
  • Type: Official Firmware
  • Filename: ---
  • Download Address: -
  • Log: no log.zip
Hello.I try to use PWM to control backlight for LVDS LCD display:
/kernel/arch/arm64/boot/dts/rockchip/rk3568j-firefly-itxq-lvds_m10r800.dts
backlight:backlight {
        status = "okay";
        enable-gpios = <&pca9555 PCA_IO1_3 GPIO_ACTIVE_HIGH>;
        compatible = "pwm-backlight";
        pwms = <&pwm15 0 25000 1>;
lvds_panel: lvds-panel {
        enable-gpios = <&pca9555 PCA_IO1_2 GPIO_ACTIVE_HIGH>;
        backlight = <&backlight>;
How can i control this device backlight on pwm15 ?
I tryed:
cat /sys/kernel/debug/pwm
platform/fe700030.pwm, 1 PWM device
pwm-0   (backlight           ): requested enabled period: 25000 ns duty: 19625 ns polarity: inverse
platform/fe700020.pwm, 1 PWM device
pwm-0   ((null)              ): period: 0 ns duty: 0 ns polarity: inverse
platform/fe6e0010.pwm, 1 PWM device
platform/fe6e0000.pwm, 1 PWM device
cd /sys/class/pwm/pwmchip0/
echo 0 > export
cd pwm0
echo 10000 > period
echo 5000 > duty_cycle
echo normal > polarity
echo 1 > enable
pwm-0   (sysfs               ): requested enabled period: 10000 ns duty: 5000 ns polarity: normal
Now i can control sysfs but not backlight.
How can i control backlight ?
no log.zip
22 Bytes, Down times: 1
Posted at 10/26/2022 10:06:29        Only Author  2#
Try this: echo 100 > /sys/class/backlight/backlight/brightness
Posted at 10/26/2022 10:09:42        Only Author  3#
He has been used, you can not export.
cd /sys/class/backlight/backlight/
cat brightness
200
echo 50 > brightness
Posted at 10/26/2022 14:00:15        Only Author  4#
ʱĺ Posted at 10/26/2022 10:06
Thank you a lot ! it works fine now !
Now i have another question - how can i control frequency (and polarity), not only brightness ?
Sure, i can try to change frequency in device tree file in pwms = <&pwm15 0 25000 1>:
        status = "okay";
Posted at 10/27/2022 13:31:53        Only Author  5#
Yes Sure, i changed frequency (period) to 50000 ns in device tree file in pwms = <&pwm15 0 50000 1>:
Then i built kernel and wrote firmware to SOM and everything works fine
Posted at 1/10/2026 06:37:25        Only Author  6#
ͨ^SISACSPAIԇJCʹԼڮ񸂠ҵITИIеλι̣ITИIеĵČIܸҪ܏ČI֪Rշe۵Ŭͨ^SISACSPAIԇJCҲǺεģSͨ^SISACSPAIԇJCITИIƏVԼĕr򣬵DzһҪMĕrg;WI֪Rx҂Testpdf SISACSPAIԇӖYϣTᘌITPԇJCоӖaƷͿԺMͨ^@NySISACSPAIԇJC
Posted at 1/15/2026 00:13:59        Only Author  7#
Thank you for the article, it really brought a fresh perspective. The CloudSec-Pro test pass4sure helped me secure my promotion and raise. Its free now for everyone. Best of luck with your career!
Posted at 1/20/2026 12:48:00        Only Author  8#
IT인증시험문제는 수시로 변경됩니다. 이 점을 해결하기 위해KoreaDumps의CompTIA인증 220-1201덤프도 시험변경에 따라 업데이트하도록 최선을 다하고 있습니다.시험문제 변경에 초점을 맞추어 업데이트를 진행한후 업데이트된CompTIA인증 220-1201덤프를 1년간 무료로 업데이트서비스를 드립니다.
Posted at 1/22/2026 06:00:34        Only Author  9#
Liking it right awaythis content is superb. Wishing everyone the best of luck! Free Valid C_BCBTM_2509 test guide materials questions are available!
Posted at 2/6/2026 22:16:41        Only Author  10#
This is top-quality stuff, clicking like now. The New SPLK-4001 exam questions exam questions are crucial for promotion and salary growthget them for free!
Return to List
12
