[Hardware] Seeing CDCS Reliable Test Cram - No Worry About EXIN EPI Certified Data Centre S
107
【Hardware】 Seeing CDCS Reliable Test Cram - No Worry About EXIN EPI Certified Data Centre S
Posted at 2/22/2026 23:07:57      View:150 | Replies:0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest ExamDiscuss CDCS PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=18V112WaTHV35tlIwgzYgVMq4uJ0KzXF-
We are proud that we have engaged in this career for over ten yeas and helped tens of thousands of the candidates achieve their CDCS certifications, and our CDCS exam questions are becoming increasingly obvious degree of helping the exam candidates with passing rate up to 98 to 100 percent. All our behaviors are aiming squarely at improving your chance of success on the CDCS Exam and we have the strengh to give you success guarantee.
So you do not need to worry about the CDCS exam preparation just download ExamDiscuss CDCS latest dumps and start preparing today. The ExamDiscuss is committed to ace the CDCS exam preparation and success journey successfully in a short time period. To achieve this objective the ExamDiscuss is offering EXIN CDCS Practice Test questions with high-in-demand features.
New CDCS Test Answers, Clearer CDCS ExplanationOur CDCS exam materials are compiled by experts and approved by the professionals who are experienced. They are revised and updated according to the pass exam papers and the popular trend in the industry. The language of our CDCS exam torrent is simple to be understood and our CDCS test questions are suitable for any learners. The content of our CDCS Study Materials is easy to be mastered and has simplified the important information. Our CDCS test questions convey the latest and valid questions and answers and thus make the learning relaxing and efficient.
EXIN EPI Certified Data Centre Specialist Sample Questions (Q105-Q110):NEW QUESTION # 105
EMF shielding material needs to be installed as EMF levels from the transformer room into the computer room are measured at 100 mG. The transformer room is ~10 meters away, separated by a corridor. Where should shielding be installed?
  • A. Shielding is not required as 100 mG is within acceptable levels
  • B. As close as possible to the computer room
  • C. As close as possible to the transformer room
  • D. It does not matter; either close to the transformer room or computer room is okay
The most effective EMF mitigation is to install shielding as close as possible to the source of radiation. By blocking or redirecting magnetic flux at the origin (the transformer room walls), the overall field propagation into adjacent areas is minimized. If shielding were placed at the computer room, the field would already have spread over the intervening space, requiring more material and higher cost.
Standards such as IEEE Std 299 (EMC Shielding Effectiveness) and IEC 61000 emphasize source-based mitigation. Additionally, ANSI/TIA-942 requires EMF shielding where magnetic flux exceeds recommended ICT thresholds (generally <5 mG for sensitive tape/disk storage).
Although 100 mG is often tolerated by modern equipment, legacy magnetic storage can be affected, so shielding is still prudent. Hence, the correct location is at the transformer room wall.
References: IEEE Std 299 (EMI Shielding), ANSI/TIA-942-B §6.6.4 (EMF Requirements), IEC 61000 EMC standards.
NEW QUESTION # 106
A computer room with a raised floor has been designed with racks in a hot/cold aisle setup.
What should you recommend for the placement of down-flow air conditioners?
  • A. Air conditioners perpendicular to (at the end of the row of) the Cold-Aisle
  • B. Air conditioners perpendicular to (at the end of the row of) the Hot-Aisle
  • C. Air conditioner placement has no influence on cooling effectiveness and efficiency. Hence, they can be placed at any convenient location.
  • D. Air conditioners should always be placed at both sides of each row of racks
In a hot/cold aisle configuration, placing down-flow air conditioners perpendicular to the cold aisle ensures that cool air is directed efficiently into the cold aisles where server intakes are located. This layout allows for optimal cooling performance by aligning the airflow directly with the equipment intakes, minimizing hot spots and enhancing cooling efficiency.
Detailed Explanation:
With a raised floor design, cold air from the air conditioners is supplied into the cold aisle, where server intakes are located. Positioning the air conditioning units perpendicular to the cold aisles ensures that cool air is delivered directly into these aisles, preventing air mixing and optimizing cooling. This setup takes full advantage of the airflow management strategy inherent to the hot/cold aisle configuration.
EPI Data Center Specialist References:
EPI guidelines on cooling emphasize that down-flow air conditioners should be positioned to maximize the effectiveness of cold aisle delivery, which improves cooling efficiency and helps maintain consistent temperatures across server racks.
NEW QUESTION # 107
You are allowed to use a calculator for this question.
A computer room has a net volume of approximately 2,500 m³ / 88,287 ft³.
The temperature is 20 °C / 68 °F.
The required design concentration is 7%.
The S-Factor is 0.1359 (metric) / 1.885 (imperial).
Calculate the amount of gas required for this computer room based on FM200. What is the correct weight?
  • A. Approximately 820 kg / 1,800 lbs
  • B. Approximately 1,390 kg / 3,000 lbs
  • C. Approximately 1,640 kg / 3,600 lbs
  • D. Approximately 410 kg / 900 lbs
The amount of FM200 gas required can be calculated using the formula:
Weight of Gas=Net Volume×Design Concentration×S-Factor        ext{Weight of Gas} =         ext{Net Volume}         imes         ext{Design Concentration}         imes         ext{S-Factor}Weight of Gas=Net Volume×Design Concentration×S-Factor Using metric units:
Net Volume: 2,500 m³
Design Concentration: 7% (or 0.07)
S-Factor: 0.1359
Calculation:
2,500 m3×0.07×0.1359=821.325 kg2,500 ,         ext{m}
2026 Latest ExamDiscuss CDCS PDF Dumps and CDCS Exam Engine Free Share: https://drive.google.com/open?id=18V112WaTHV35tlIwgzYgVMq4uJ0KzXF-
