[General] Exam 800-150 Dump | Valid 800-150 Mock Test
96
【General】 Exam 800-150 Dump | Valid 800-150 Mock Test
Posted at 1/12/2026 09:17:15      View:170 | Replies:1        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of BootcampPDF 800-150 dumps from Cloud Storage: https://drive.google.com/open?id=1DhkUh-i32IwBpNIy6G_oPnQbUJiIUlYu
God always helps those who help themselves. It is impossible to make great fortune overnight. Enough preparation and efforts are needed when you come across an opportunity. So we suggest that you learn our 800-150 latest training material, which can help broaden your knowledge. Nowadays, lifelong learning has got wide attention. The much knowledge you learn, the better chance you will have. Our 800-150 practice material suits you best. You can elevate your ability in a short time. Then you can apply what you have learned on our 800-150 test engine into practice. We warmly welcome you to purchase our study guide.
Cisco 800-150 Exam Syllabus Topics:
  • Cisco Hardware Replacement: This section of the exam measures the skills of a Technical Support Engineer and teaches how to safely and correctly replace Cisco hardware. It explains safety procedures such as creating safe work zones and handling electrostatic discharge. Students learn the step-by-step processes to replace a wide range of Cisco devices, from switches and routers to firewalls, UCS servers, and collaboration endpoints. It also covers configuring Cisco NX-OS software, including understanding operating modes, boot procedures, and password recovery, and introduces Cisco collaboration endpoint solutions like IP phones and video systems.
  • Cisco Software: This section of the exam measures the skills of a Network Engineer and discusses Cisco’s software systems and licensing. It explains the difference between IOS install and bundle modes and gives an overview of different licensing models. Students learn how to manage Cisco software images, including backing up, transferring, and installing images via FTP, TFTP, or USB. It also covers how to handle configuration files to keep devices running properly and ensure smooth upgrades or replacements.
  • Cisco UCS and Data Center Architecture: This section of the exam measures the skills of a Data Center Engineer and introduces Cisco’s UCS and data center solutions. It explains the devices found in a data center, including switches, UCS servers, and director switches, and describes different server deployment models. Students will also learn about virtualization components like virtual machines, hypervisors, cloud computing concepts, and deployment models. The section covers how Cisco UCS devices fit into campus networks, edge locations, and data centers, and explains the key components and connections used in UCS architecture.
  • Common Service Tasks and Tools: This section of the exam measures the skills of a Technical Support Engineer and focuses on tasks commonly needed to manage Cisco devices. It explains how devices boot up, introduces common Cisco IOS commands, and identifies tools for file management. It shows how to confirm physical connections, remotely access devices, and connect to the console port. It also covers how to capture the status of a device, recover passwords, and replace devices by using proper tools. Students are also taught how to find serial numbers on Cisco equipment to assist with support and maintenance activities.
Topic 5
  • Cisco Infrastructure and Collaboration Infrastructure: This section of the exam measures the skills of a Collaboration Engineer and focuses on Cisco infrastructure devices, endpoints, and collaboration technologies. It introduces network devices, collaboration endpoints like IP phones and video systems, and explains on-premises collaboration deployments using tools like Cisco Unified Communications Manager. It also covers how video systems integrate into collaboration environments and highlights Cisco’s cloud services for enterprise communication, including Webex Meetings, Webex Teams, and hosted collaboration solutions.
Valid Cisco 800-150 Mock Test - Valid 800-150 Exam PapersAs you may know that the windows software of the 800-150 study materials only supports windows operating system. Also, it needs to run on Java environment. If the computer doesn’t install JAVA, it will automatically download to ensure the normal running of the 800-150 Study Materials. What’s more, all computers you have installed our study materials can run normally. Our 800-150 exam guide are cost-effective.
Cisco Supporting Cisco Devices for Field Technicians Sample Questions (Q40-Q45):NEW QUESTION # 40
Which two settings are standard Cisco console connections when configuring a terminal emulator to connect to the console port of a Cisco switch? (Choose two.)
  • A. Flow control: Hardware
  • B. Stop bits: 2
  • C. Speed (baud rate): 9600
  • D. Data bits: 8
  • E. Parity: Even
When configuring a terminal emulator (such as PuTTY, Tera Term, or HyperTerminal) to connect to the console port of a Cisco switch, the standard settings are as follows:
* Speed (baud rate): 9600This is the default transmission speed for Cisco console ports, ensuring compatibility across various devices.
* Data bits: 8This setting specifies that each character transmitted consists of 8 data bits, which is standard for most serial communications.
* Parity: NoneNo parity bit is used, meaning there is no additional error-checking bit appended to each character.
* Stop bits: 1One stop bit indicates the end of a character transmission.
* Flow control: NoneNo flow control is employed, allowing continuous data transmission without hardware or software-based pausing.
Therefore, optionsC (Speed: 9600)andD (Data bits: 8)are correct. Options A (Stop bits: 2), B (Flow control:
Hardware), and E (Parity: Even) deviate from the standard settings and may result in communication issues if configured.
Reference:Supporting Cisco Devices for Field Technicians (FLDTEC) - Device Configuration and Verification
NEW QUESTION # 41
What is the primary purpose of backing up the endpoint configuration prior to replacing the device?
  • A. To generate a performance report for the old device
  • B. To update the firmware of the device
  • C. Torestore settings on the new device after replacement
  • D. To troubleshoot network connectivity issues
Backing up the configuration of a network device before replacement is a critical step to ensure business continuity and minimize downtime. The primary purpose of this backup is torestore the existing settings onto the new device, ensuring that it operates identically to the one being replaced.
This process includes preserving interface configurations, routing protocols, access control lists, and other essential parameters. By restoring the backed-up configuration to the new device, network administrators can quickly reintegrate it into the network infrastructure without the need for manual reconfiguration, thereby reducing the risk of errors and service disruptions.
Options A, B, and C do not align with the primary objective of configuration backups in the context of device replacement.
Reference:Supporting Cisco Devices for Field Technicians (FLDTEC) - Maintenance and RMA Procedures
NEW QUESTION # 42
Which two features are managed by the hardware and software of the collaboration infrastructure? (Choose two.)
  • A. Phone book administration
  • B. Supporting meeting experiences
  • C. Facilitating connections
  • D. Hosting large-scale databases
  • E. Network bandwidthallocation
The Cisco Collaboration Infrastructure is designed to support unified communications, video conferencing, and team collaboration through an integrated architecture involving both hardware (e.g., endpoints, media servers) and software (e.g., CUCM, Webex apps).
According to the FLDTEC course content under Cisco Collaboration Equipment and Infrastructure:
Facilitating Connections (C):
Cisco infrastructure components such as CUCM, Expressway, and Cisco Meeting Server enable real-time connections between users across voice, video, and messaging systems.
Supporting Meeting Experiences (E):
Devices such asWebex Boards, Room Kits, and Cisco Quad Cameras, in combination with platforms like Webex, provide immersive and seamless meeting experiences, supported by the infrastructure.
Incorrect Options:
A:Network bandwidth allocation: Typically managed by network QoS policies and WAN optimizations, not the collaboration infrastructure directly.
B:Hosting large-scale databases: Not a function of Cisco's collaboration system - this falls under data center or database server roles.
Dhone book administration: Often a function within directory services or external LDAP integration, not a core collaboration infrastructure task.
NEW QUESTION # 43
Which Cisco UCS management platform is specifically designed for managing standalone Cisco UCS C- Series rack servers and E-Series servers?
  • A. Cisco UCS Central
  • B. Cisco Integrated Management Controller
  • C. Cisco UCS Manager
  • D. Cisco Intersight
TheCisco Integrated Management Controller (CIMC)is the embedded management solution designed specifically forstandalone Cisco UCS C-Series rack servers and E-Series servers. It allows administrators to perform out-of-band management functions such as BIOS configuration, firmware updates, remote console access, and power control.
* Cisco UCS Manageris used for managing UCS blade chassis environments.
* Cisco UCS Centralis intended for centralized management across multiple UCS domains.
* Cisco Intersightis a cloud-based management platform that can extend CIMC functionality but is not the embedded, standalone option.
Reference:Supporting Cisco Devices for Field Technicians (FLDTEC) - Cisco Equipment and Related Hardware
NEW QUESTION # 44
What is the primary reason for placing heavier devices toward the bottom of the rack when installing replacement hardware?
  • A. To facilitate easier cable management
  • B. To maintain rack stability
  • C. To improve air circulation
  • D. To simplify device maintenance
Theprimary reasonfor placing heavier equipment, such as UPS units or core switches, at thebottom of a rack is tomaintain stability. A lower center of gravity reduces the risk of tipping, especially when the rack is not yet bolted or braced.
This is a standard safety precaution in network hardware installation and is particularly important when racks are being serviced or relocated.
Reference:Supporting Cisco Devices for Field Technicians (FLDTEC) - Safety and ESD Precautions Explanation:
The primary reason for placing heavier devices toward the bottom of the rack is to maintain rack stability.
This helps ensure the rack remains balanced and prevents tipping, especially when multiple devices are installed.
NEW QUESTION # 45
Supporting Cisco Devices for Field Technicians (800-150) practice test software is another great way to reduce your stress level when preparing for the Cisco Exam Questions. With our software, you can practice your excellence and improve your competence on the Supporting Cisco Devices for Field Technicians (800-150) exam dumps. Each Cisco 800-150 practice exam, composed of numerous skills, can be measured by the same model used by real examiners.
Valid 800-150 Mock Test: https://www.bootcamppdf.com/800-150_exam-dumps.html
What's more, part of that BootcampPDF 800-150 dumps now are free: https://drive.google.com/open?id=1DhkUh-i32IwBpNIy6G_oPnQbUJiIUlYu
Posted at 2/16/2026 21:25:02        Only Author  2#
This article has helped me clarify my plans for future development. The Valid test guide RIBO-Level-1 files content is amazing, and it’s available to you without charge.
