[Hardware] Salesforce-Data-Cloud Valid Test Forum, New Salesforce-Data-Cloud Test Prep
101
Hardware Salesforce-Data-Cloud Valid Test Forum, New Salesforce-Data-Cloud Test Prep
Posted at 2/21/2026 20:28:41      View130 | Replies0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of Pass4training Salesforce-Data-Cloud dumps from Cloud Storage: https://drive.google.com/open?id=1Eu91JFehid2p3z7SiBGSq8G6r_TPPks6
You should make progress to get what you want and move fast if you are a man with ambition. At the same time you will find that a wonderful aid will shorten your time greatly. To get the Salesforce-Data-Cloud certification is considered as the most direct-viewing way to make big change in your professional profile, and we are the exact Salesforce-Data-Cloud Exam Braindumps vendor. If you have a try on our free demos of our Salesforce-Data-Cloud study guide, you will choose us!
Pass4training is a trusted platform that is committed to helping Salesforce Salesforce-Data-Cloud exam candidates in exam preparation. The Salesforce Salesforce-Data-Cloud exam questions are real and updated and will repeat in the upcoming Salesforce Salesforce-Data-Cloud Exam. By practicing again and again you will become an expert to solve all the Salesforce-Data-Cloud exam questions completely and before the exam time.
Salesforce Salesforce-Data-Cloud Exam | Salesforce-Data-Cloud Valid Test Forum - Easily Pass Exam If Choosing our New Salesforce-Data-Cloud Test PrepVarious study forms are good for boosting learning interests. So our company has taken all customers requirements into account. Now we have PDF version, windows software and online engine of the Salesforce-Data-Cloud certification materials. Although all contents are the same, the learning experience is totally different. First of all, the PDF version Salesforce-Data-Cloud certification materials are easy to carry and have no restrictions. Then the windows software can simulate the real test environment, which makes you feel you are doing the real test. The online engine of the Salesforce-Data-Cloud test training can run on all kinds of browsers, which does not need to install on your computers or other electronic equipment. All in all, we hope that you can purchase our three versions of the Salesforce-Data-Cloud real exam dumps.
Salesforce Data Cloud Accredited Professional Exam Sample Questions (Q160-Q165):NEW QUESTION # 160
Which data stream category should be assigned to use the data for time-based operations in segmentation and calculated insights?
  • A. Transaction
  • B. Sales Order
  • C. Engagement
  • D. Individual
The transaction data stream category should be assigned to use the data for time-based operations in segmentation and calculated insights. This category indicates that the data stream contains events that occur at a specific point in time and have a duration. References:https://help.salesforce.com/s/articleView?id=sf.
c360_a_data_cloud_data_stream_category.htm&type=5
NEW QUESTION # 161
A consultant wants to ensure that every segment managed by multiple brand teams adheres to the same set of exclusion criteria, that are updated on a monthly basis.
What is the most efficient option to allow for this capability?
  • A. Create a nested segment.
  • B. Create a segment and copy it for each brand.
  • C. Create a reusable container block with common criteria.
  • D. Create, publish, and deploy a data kit.
The most efficient option to allow for this capability is to create a reusable container block with common criteria. A container block is a segment component that can be reused across multiple segments. A container block can contain any combination of filters, nested segments, and exclusion criteria. A consultant can create a container block with the exclusion criteria that apply to all the segments managed by multiple brand teams, and then add the container block to each segment. This way, the consultant can update the exclusion criteria in one place and have them reflected in all the segments that use the container block.
The other options are not the most efficient options to allow for this capability. Creating, publishing, and deploying a data kit is a way to share data and segments across different data spaces, but it does not allow for updating the exclusion criteria on a monthly basis. Creating a nested segment is a way to combine segments using logical operators, but it does not allow for excluding individuals based on specific criteria. Creating a segment and copying it for each brand is a way to create multiple segments with the same exclusion criteria, but it does not allow for updating the exclusion criteria in one place.
Create a Container Block
Create a Segment in Data Cloud
Create and Publish a Data Kit
Create a Nested Segment
NEW QUESTION # 162
What are the two distinct phases of data model management in Data Cloud?
  • A. Data Actions
  • B. Data Modeling
  • C. Data Ingestion
  • D. Data Activation
These two phases are distinct phases of data model management in Data Cloud. Data ingestion is the process of bringing data from different sources into Data Cloud using connectors or APIs. Data modeling is the process of mapping the ingested data to the Data Cloud canonical model or creating custom data model objects. Reference: https://help.salesforce.com/s/ar ... odel.htm&type=5
NEW QUESTION # 163
Which permission setting should an administrator check if the custom CRM object is not available in New Data Stream configuration?
  • A. View All object permission enabled in source CRM org
  • B. Create object permission enabled in Data Cloud org
  • C. Modify All object permission enabled in DataCloud org
  • D. Ingest Object permission is enabled in the CRM org
This permission setting should be checked if the custom CRM object is not available in New Data Stream configuration. The user who connects the Salesforce CRM connector must have View All permission for the custom object in the source CRM org. References:https://help.salesforce.com/s/articleView?id=sf.
c360_a_data_cloud_salesforce_crm.htm&type=5
NEW QUESTION # 164
Which data stream category type should be assigned in order to use the dataset for date and time-based operations in segmentation and calculated insights?
  • A. Sales Order
  • B. Engagement
  • C. Profile
  • D. Individual
To use a dataset for date and time-based operations in segmentation and calculated insights, the data stream category type should be assigned as Engagement . Here's why:
Understanding the Requirement
The goal is to perform date and time-based operations (e.g., filtering customers based on specific dates or times) in segmentation and calculated insights.
This requires a data stream category that captures customer interactions or activities over time.
Why Engagement?
Engagement Data Streams :
Engagement data streams are designed to capture customer interactions, such as website visits, email opens, purchases, or other time-based activities.
These streams inherently include timestamps, making them ideal for date and time-based operations.
Use in Segmentation and Calculated Insights :
Segmentation often involves filtering customers based on their engagement behavior (e.g., "customers who visited the website in the last 7 days").
Calculated insights leverage engagement data to derive metrics like recency, frequency, and trends over time.
Other Categories Are Less Suitable :
Individual : Focuses on demographic or static attributes (e.g., name, age) rather than time-based interactions.
Sales Order : Captures transactional data but is not optimized for general engagement-based operations.
Profile : Represents unified customer profiles and does not directly support date and time-based operations.
Steps to Implement This Solution
Step 1: Assign the Correct Category
When setting up the data stream, assign the Engagement category to ensure it is optimized for time-based operations.
Step 2: Map Date-Time Fields
Ensure that relevant fields (e.g., interaction timestamps) are mapped correctly during ingestion.
Step 3: Use in Segmentation and Insights
Leverage the ingested engagement data for segmentation (e.g., "customers who engaged in the last 24 hours") and calculated insights (e.g., "average time between interactions").
Conclusion
The Engagement category is specifically designed for capturing time-based interactions, making it the best choice for datasets used in date and time-based operations in segmentation and calculated insights.
NEW QUESTION # 165
The first goal of our company is to help all people to pass the Salesforce-Data-Cloud exam and get the related certification in the shortest time. Through years of concentrated efforts of our excellent experts and professors, our company has compiled the best helpful and useful Salesforce-Data-Cloud test training materials, and in addition, we can assure to everyone that our Salesforce-Data-Cloud Study Materials have a higher quality than other study materials in the global market. The Salesforce-Data-Cloud learn prep from our company has helped thousands of people to pass the exam and get the related certification.
New Salesforce-Data-Cloud Test Prep: https://www.pass4training.com/Salesforce-Data-Cloud-pass-exam-training.html
Salesforce Salesforce-Data-Cloud Valid Test Forum To do it, you can earn by participating in training, volunteering, and proving experience achievements, We believe in the future, our Salesforce-Data-Cloud study torrent will be more attractive and marvelous with high pass rate, According to the different demands from customers, the experts and professors designed three different versions of our Salesforce-Data-Cloud exam questions for all customers, One year free updating of our Salesforce-Data-Cloud exam dumps.
Software and system testers repeatedly fall Salesforce-Data-Cloud victim to the same pitfalls, The chart below, from Deskwanted, shows where these facilities are located, To do it, you can earn Salesforce-Data-Cloud Practice Questions by participating in training, volunteering, and proving experience achievements.
Efficient Salesforce-Data-Cloud Valid Test Forum Supply you Fast-Download New Test Prep for Salesforce-Data-Cloud: Salesforce Data Cloud Accredited Professional Exam to Study casuallyWe believe in the future, our Salesforce-Data-Cloud study torrent will be more attractive and marvelous with high pass rate, According to the different demands from customers, the experts and professors designed three different versions of our Salesforce-Data-Cloud exam questions for all customers.
One year free updating of our Salesforce-Data-Cloud exam dumps, You can choose the one you prefer for your training.
2026 Latest Pass4training Salesforce-Data-Cloud PDF Dumps and Salesforce-Data-Cloud Exam Engine Free Share: https://drive.google.com/open?id=1Eu91JFehid2p3z7SiBGSq8G6r_TPPks6
