Fortinet FCSS_SDW_AR-7.6 Questions Can Help you Pass Exam [2026]
106
Posted at 2/19/2026 04:24:39      View:90 | Replies:0        Print      Only Author   [Copy Link] 1#
Fortinet FCSS_SDW_AR-7.6 practice test software is compatible with windows and the web-based software will work on these operating systems: Android, IOS, Windows, and Linux. Chrome, Opera, Internet Explorer, Microsoft Edge, and Firefox also support the web-based FCSS_SDW_AR-7.6 Practice Test software.
It is our promissory announcement on our FCSS_SDW_AR-7.6 exam questions that you will get striking by these viable ways. So do not feel giddy among tremendous materials in the market ridden-ed by false materials. With great outcomes of the passing rate upon to 98-100 percent, our FCSS_SDW_AR-7.6 Preparation braindumps are totally the perfect one. And you can find the comments and feedbacks on our website to see that how popular and excellent our FCSS_SDW_AR-7.6 study materials are.
Fortinet FCSS_SDW_AR-7.6 Realistic Reliable Test Question Free PDF QuizThe PDF version of our FCSS_SDW_AR-7.6 guide exam is prepared for you to print it and read it everywhere. It is convenient for you to see the answers to the questions and remember them. After you buy the PDF version of our study material, you will get an E-mail form us in 5 to 10 minutes after payment. Then you can click the link in the E-mail and download your FCSS_SDW_AR-7.6 study engine. You can download it as many times as you need.
Fortinet FCSS_SDW_AR-7.6 Exam Syllabus Topics:
  • Centralized Management: This domain addresses FortiManager-based SD-WAN deployment, branch configuration implementation, and overlay orchestration using SD-WAN Manager.
  • SD-WAN Basic Setup: This domain covers initial SD-WAN configuration, member and zone setup, and Performance SLA creation for link monitoring.
  • SD-WAN Troubleshooting: This domain focuses on diagnosing SD-WAN rule behavior, routing issues, and ADVPN tunnel problems.
  • Rules and Routing: This section focuses on configuring SD-WAN rules for traffic steering and routing policies for path selection and failover.
Topic 5
  • Advanced IPsec: This section covers hub-and-spoke topologies, ADVPN configuration, and scalable multihub and multiregion IPsec deployments.
Fortinet FCSS - SD-WAN 7.6 Architect Sample Questions (Q28-Q33):NEW QUESTION # 28
The FortiGate devices are managed by ForliManager, and are configured for direct internet access (DIA). You confirm that DIA is working as expected for each branch, and check the SD- WAN zone configuration and firewall policies shown in the exhibits.
Then, you use the SD-WAN overlay template to configure the IPsec overlay tunnels. You create the associated SD-WAN rules to connect existing branches to the company hub device and apply the changes on the branches.
After those changes, users complain that they lost internet access. DIA is no longer working.
Based on the exhibit, which statement best describes the possible root cause of this issue?
  • A. The SD-WAN overlay template updates the SD-WAN template and the rules.
  • B. The SD-WAN overlay template redefines the interface gateway addresses if they are defined with metadata variables.
  • C. The SD-WAN overlay template defines a zone for each underlay interface and moves the interfaces into those zones.
  • D. The SD-WAN overlay template didn't configure a firewall policy to allow traffic through the overlay.
The SD-WAN overlay template defines a zone for each underlay interface and moves the interfaces into those zones. This statement perfectly describes the likely sequence of events. The template, when applied, re-organizes the interfaces and zones, causing the existing firewall policy that relies on the old zone configuration to fail. This is the most plausible root cause.
NEW QUESTION # 29
An administrator is configuring SD-WAN to load balance their network traffic. Which two things should they consider when setting up SD-WAN? (Choose two.)
  • A. When applicable. FortiGate load balances the traffic through all members that meet the SLA target.
  • B. SD-WAN load balancing is possible only using the best quality and lowest cost (SLA) strategies.
  • C. Only the manual and best-quality strategies allow SD-WAN load balancing.
  • D. You can select the outbandwidth hash mode with all strategies that allow load balancing.
Answer: A,D
NEW QUESTION # 30
  • A. SD-WAN load balancing is possible only using the best quality and lowest cost (SLA) strategies.
  • B. Only the manual and best-quality strategies allow SD-WAN load balancing.
  • C. When applicable, FortiGate load balances the traffic through all members that meet the SLA target.
FortiGate load balances traffic across all members that meet the SLA targets, depending on the strategy used.
The outbandwidth hash mode can be selected with load-balancing strategies to distribute traffic based on flow characteristics.
NEW QUESTION # 31
When you use the command diagnose sys session list, how do you identify the sessions that correspond to traffic steered according to SD-WAN rules?
  • A. You identify sessions steered according to SD-WAN rules with the data sdwan_service_id.
  • B. You identify sessions steered according to SD-WAN rules with the flag vwl.
  • C. You identify sessions steered according to SD-WAN rules with the data vwl_mbr_seq.
  • D. You cannot identify SD-WAN sessions. You must use the sdwar. session filter.
The sdwan_service_id field in the output of diagnose sys session list indicates that the session was selected based on an SD-WAN rule, allowing administrators to trace which SD-WAN service (rule) steered the traffic.
NEW QUESTION # 32
An administrator checks the status of an SD-WAN topology using the FortiManager SD-WAN monitor menus. All members are configured with one or two SLAs.
Which two conclusions can you draw from the output shown? (Choose two.)
  • A. One member of branch2_fgt is missing the SLAs.
  • B. The template view should be used to see the hub devices.
  • C. This SD-WAN topology contains only two branch devices.
  • D. branch2_fgt establishes six tunnels to the hubs and they are all up.
From the SD-WAN monitor in FortiManager:
"The SD-WAN monitor provides a summary view of the branch devices and their members. In the scenario shown, it is clear that branch2_fgt is missing SLA configuration for one member, as evidenced by the lack of performance metrics. The monitor also shows only two branches in the current topology, allowing quick assessment of branch health and configuration completeness." This kind of visibility is vital for proactive monitoring and rapid troubleshooting in SD-WAN environments.
[FCSS_SDW_AR-7.4 1-0.docx Q18]
FortiManager SD-WAN Monitoring Guide, "Branch Device Health and SLA Status Visualization"
NEW QUESTION # 33
Our FCSS_SDW_AR-7.6 test questions provide free trial services for all customers so that you can better understand our products. You can experience the effects of outside products in advance by downloading clue versions of our FCSS_SDW_AR-7.6 exam torrent. In addition, it has simple procedure to buy our learning materials. After your payment is successful, you will receive an e-mail from our company within 10 minutes. After you click on the link and log in, you can start learning using our FCSS_SDW_AR-7.6 test material. You can download our FCSS_SDW_AR-7.6 test questions at any time.
Prep FCSS_SDW_AR-7.6 Guide: https://www.validexam.com/FCSS_SDW_AR-7.6-latest-dumps.html
