[General] 2026 Professional Juniper JN0-336: Security, Specialist (JNCIS-SEC) Latest Real
92
General 2026 Professional Juniper JN0-336: Security, Specialist (JNCIS-SEC) Latest Real
Posted at 2/19/2026 19:43:15      View103 | Replies0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of TestKingIT JN0-336 dumps for free: https://drive.google.com/open?id=1frrv5b-iBQm6Be9FVlyeV4pC-hrXCopb
One thing has to admit, more and more certifications you own, it may bring you more opportunities to obtain better job, earn more salary. This is the reason that we need to recognize the importance of getting the test JN0-336 certifications. More qualified certification for our future employment has the effect to be reckoned with, only to have enough qualification certifications to prove their ability, can we win over rivals in the social competition. Therefore, the JN0-336 Guide Torrent can help users pass the qualifying examinations that they are required to participate in faster and more efficiently.
As for the points you may elapse or being frequently tested in the real exam, we give referent information, then involved them into our JN0-336 actual exam. Our experts expertise about JN0-336 training materials is unquestionable considering their long-time research and compile. I believe that no one can know the JN0-336 Exam Questions better than them. And they always keep a close eye on the changes of the content and displays of the JN0-336 study guide.
Pass Guaranteed Quiz 2026 JN0-336: Security, Specialist (JNCIS-SEC) Authoritative Latest Real ExamWe consider the actual situation of the test-takers and provide them with high-quality JN0-336 learning materials at a reasonable price. Choose the JN0-336 test guide absolutely excellent quality and reasonable price, because the more times the user buys the JN0-336 test guide, the more discounts he gets. In order to make the user's whole experience smoother, we also provide a thoughtful package of services. Once users have any problems related to the JN0-336 learning questions, our staff will help solve them as soon as possible.
Juniper Security, Specialist (JNCIS-SEC) Sample Questions (Q44-Q49):NEW QUESTION # 44
How does the SSL proxy detect if encryption is being used?
  • A. It queries the client device.
  • B. It verifies the length of the packet
  • C. It looks at the destination port number.
  • D. It uses application identity services.
The SSL proxy can detect if encryption is being used by looking at the destination port number of the packet. If the port number is 443, then the proxy can assume that the packet is being sent over an encrypted connection. If the port number is different, then the proxy can assume that the packet is not encrypted. For more information, please refer to the Juniper Networks JNCIS-SEC Study Guide.
NEW QUESTION # 45
You want to deploy a virtualized SRX in your environment.
In this scenario, why would you use a vSRX instead of a cSRX? (Choose two.)
  • A. Only the vSRX provides clustering.
  • B. The vSRX supports Layer 2 and Layer 3 configurations.
  • C. Only the vSRX provides NAT, IPS, and UTM services
  • D. The vSRX has faster boot times.
vSRX provides flexible networking capabilities which include support for both Layer 2 (data link) and Layer 3 (network) configurations. This allows it to handle a variety of routing and switching tasks within virtual environments.
Clustering capability, which involves grouping multiple vSRX instances to operate as a single entity for redundancy and high availability, is a feature specific to vSRX. This is critical in environments where continuous uptime and resilience are required.
NEW QUESTION # 46
Click the Exhibit button.
Which two statements about the log output shown in the exhibit are correct? (Choose two)
  • A. AppTrack is enabled on the untrust zone.
  • B. Source NAT is performed
  • C. Traffic destined to the HTTP server is placed in an IPsec tunnel
  • D. AppTrack is enabled on the trast zone.
Answer: A,D
NEW QUESTION # 47
Referring to the exhibit, what will the SRX Series device do in this configuration?
  • A. Packets from the infected hosts with a threat level of 8 will be dropped and no log message will be generated.
  • B. Packets from the infected hosts with a threat level of 8 will be dropped and a log message will be generated.
  • C. Packets from the infected hosts with a threat level of 8 or above will be dropped and a log message will be generated.
  • D. Packets from the infected hosts with a threat level of 8 or above will be dropped and no log message will be generated.
The exhibit shows a configuration snippet for security intelligence on an SRX Series device. Security intelligence is a feature that allows you to block or monitor traffic from malicious sources based on threat intelligence feeds from Juniper ATP Cloud or other providers. The configuration defines a profile for ATP Infected-Hosts, which is a feed that contains IP addresses of hosts that are infected with malware and communicate with command-and-control servers. The configuration also defines a rule for threat level 8, which is a parameter that indicates the severity of the threat.
Based on this configuration, the SRX Series device will do the following:
Packets from the infected hosts with a threat level of 8 or above will be dropped: The action block-and- drop under the rule means that the device will block any traffic from the infected hosts that have a threat level equal to or higher than 8. This will prevent the hosts from sending or receiving malicious commands or data.
No log message will be generated: The absence of any log option under the rule means that the device will not generate any log message for the blocked traffic. This may reduce the load on the device and the logging server, but it may also limit the visibility and analysis of the security events. Reference: = Security Intelligence Theory, Firewall Filter Support on Loopback Interface
NEW QUESTION # 48
Which two statements are true about Juniper ATP Cloud? (Choose two.)
  • A. If the cache lookup determines that a file contains malware, static analysis is not performed to verify the results.
  • B. Dynamic analysis is always performed to determine if a file contains malware.
  • C. If the cache lookup determines that a file contains malware, performed to verify the results.
  • D. Dynamic analysis is not always necessary to determine if a file contains malware.
Answer: A,D
Dynamic analysis is not always necessary to determine if a file contains malware, as the ATP Cloud uses a cache lookup to quickly identify known malicious files. If the cache lookup determines that a file contains malware, static analysis is not performed to verify the results. This information can be found on the Juniper website here: https://www.juniper.net/documentation/en_US/release- independent/security/jnpr-security-srx-series/inform
NEW QUESTION # 49
Our JN0-336 practice prep provides you with a brand-new learning method that lets you get rid of heavy schoolbags, lose boring textbooks, and let you master all the important knowledge in the process of making a question. Please believe that with JN0-336 Real Exam, you will fall in love with learning. Our JN0-336 exam questions are contained in three versions: the PDF, Software and APP online which can cater to different needs of our customers.
Valid JN0-336 Test Vce: https://www.testkingit.com/Juniper/latest-JN0-336-exam-dumps.html
Unfortunately, now, you are so frustrated that you forget the beginning of the heart and lost the firm belief (JN0-336 actual test questions), Our JN0-336 braindumps are simply unmatched in their utility and perfection, Juniper JN0-336 Latest Real Exam Perhaps our research data will give you some help, We are providing latest JN0-336 PDF question answers to help you prepare exam while working in the office to save your time.
Implement cookies, pop-up windows, and timers, You focused JN0-336 on staying on message and making sure that you had coordination of messages across all your channels, Unfortunately, now, you are so frustrated that you forget the beginning of the heart and lost the firm belief (JN0-336 Actual Test questions).
JN0-336 exam dumps & JN0-336 prep4sure trainingOur JN0-336 braindumps are simply unmatched in their utility and perfection, Perhaps our research data will give you some help, We are providing latest JN0-336 PDF question answers to help you prepare exam while working in the office to save your time.
Come and take JN0-336 preparation questions home.
P.S. Free & New JN0-336 dumps are available on Google Drive shared by TestKingIT: https://drive.google.com/open?id=1frrv5b-iBQm6Be9FVlyeV4pC-hrXCopb
