[General] 300-710 Exam Prep and 300-710 Test Dumps - 300-710 Exam Question - BraindumpsPas
107
General 300-710 Exam Prep and 300-710 Test Dumps - 300-710 Exam Question - BraindumpsPas
Posted at 2/18/2026 20:23:07      View138 | Replies1        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest BraindumpsPass 300-710 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1C_-HS2Uv1ckvRW5JlXV9-kAysP7hCqYo
It's not easy for most people to get the 300-710 guide torrent, but I believe that you can easily and efficiently obtain qualification certificates as long as you choose our products. Interest is the best teacher, so it is only by letting the user have fun in the boring study that they can better put knowledge into their thinking. How perfect 300-710 Exam Questions are! Maybe you cannot wait to understand our study materials.
To pass the Cisco 300-710 Exam, candidates must demonstrate their understanding of the fundamental concepts of network security, such as access control, threat detection, and risk assessment. They must also possess in-depth knowledge of the Cisco Firepower NGFW and be able to configure and manage various security features, such as application control, URL filtering, and network analysis policies.
Cisco 300-710 certification exam is intended for professionals who have experience working with Cisco Firepower NGFW technology and want to expand their knowledge and skills. Candidates who pass this certification exam will be able to design, implement, and manage advanced security solutions using Cisco Firepower technology. Securing Networks with Cisco Firepower certification is ideal for network security engineers, network administrators, and security analysts who want to enhance their expertise in network security.
New 300-710 Exam Fee - 100% Realistic Questions PoolOur company in the field of the 300-710 exam bootcamp for years, we also enjoy high reputation in the business. You choose us, we will give you the best we have, and your right choice will also bring the benefits to you. With the high reputation in the field, we can guarantee the quality of the 300-710 Exam Dumps. It also contains the free update for one year for you. It can save your money for updating, and the update version will send to your mailbox automatically.
Cisco Securing Networks with Cisco Firepower Sample Questions (Q317-Q322):NEW QUESTION # 317
A network engineer is deploying a Cisco Firepower 4100 appliance and must configure a multi-instance environment for high availability. Drag and drop me actions from the left into sequence on the right far this configuration.
The correct sequence of actions for configuring a multi-instance environment for high availability on a Cisco Firepower 4100 appliance is as follows:
* Add a resource profile for container instances. A resource profile defines the CPU, RAM, and disk space allocation for each container instance.You can create multiple resource profiles with different resource settings and assign them to different container instances1.
* Add a MAC pool prefix and view the MAC address for the container instance interfaces. A MAC pool prefix is a 24-bit prefix that is used to generate MAC addresses for the container instance interfaces.
You can specify a custom MAC pool prefix or use the default one.You can also view the MAC addresses that are assigned to each container instance interface1.
* Configure interfaces. You need to configure the physical interfaces, EtherChannels, and VLAN subinterfaces that will be used by the container instances.You can also configure shared interfaces that can be used by multiple container instances on the same security module/engine1.
* Add a Standalone Firepower Threat Defense for Cisco Secure Firewall Management Center. You need to add a logical device that runs a standalone Firepower ThreatDefense (FTD) application instance and register it with the Cisco Secure Firewall Management Center (FMC).This logical device will act as the management interface for the container instances1.
* Add a high-availability pair. You need to add another logical device that runs a standalone FTD application instance and register it with the FMC as well. Then, you need to configure high availability (HA) between the two standalone FTD logical devices.This will enable HA for the container instances that are associated with them1.
NEW QUESTION # 318
An engineer must configure high availability on two Cisco Secure Firewall Threat Defense appliances. Drag and drop the configuration steps from the left into the sequence on the right.
Step 1(Configure the primary unit for high availability),
Step 2(Configure the secondary unit for high availability),
Step 3(Configure the two units for high availability),
Step 4(Configure failover criteria for health monitoring)
NEW QUESTION # 319
Refer to exhibit. Which two descriptions of the configurations of the Cisco FirePOWER Services module are true? (Choose two)
  • A. The module is operating in IPS mode
  • B. Traffic is blocked if the module fails
  • C. The module is operating in IDS mode
  • D. Traffic continues to flow if the module fails
  • E. The module tails to receive redirected traffic
NEW QUESTION # 320
A network administrator must create an EtherChannel Interface on a new Cisco Firepower 9300 appliance registered with an FMC tor high availability. Where must the administrator create the EtherChannel interface?
  • A. FMC CLI
  • B. FMC GUI
  • C. FTD CLI
  • D. FXOS CLI
An EtherChannel interface is a logical interface that consists of a bundle of individual Ethernet links that act as a single network link. An EtherChannel interface can increase the bandwidth and reliability of a network connection5.
On a Cisco Firepower 9300 appliance registered with an FMC for high availability, the network administrator must create the EtherChannel interface on the FXOS CLI. The FXOS is the operating system that runs on the Firepower 9300 chassis and provides hardware management functions such as interface configuration, power supply status, fan speed control, and so on6.
To create an EtherChannel interface on the FXOS CLI, the network administrator can follow these steps5:
* Connect to the FXOS CLI using SSH or console.
* Enter scope eth-uplink command to enter Ethernet uplink mode.
* Enter create port-channel command to create an EtherChannel interface.
* Enter a port-channel ID (1-48) and a mode (on or active) for the EtherChannel interface.
* Enter add interface command to add physical interfaces to the EtherChannel interface.
* Enter one or more interface IDs (for example, 1/1) for the physical interfaces.
* Enter commit-buffer command to save the changes.
* The FMC CLI does not provide any commands to create an EtherChannel interface on a Firepower
9300 appliance. The FMC CLI is mainly used for managing FMC settings such as backup, restore, upgrade, troubleshoot, and so on7.
* The FTD CLI does not provide any commands to create an EtherChannel interface on a Firepower 9300 appliance. The FTD CLI is mainly used for managing FTD settings such as routing, NAT, VPN, access control, and so on8.
* The FMC GUI does not provide any options to create an EtherChannel interface on a Firepower 9300 appliance. The FMC GUI is mainly used for managing FTD policies such as access control, intrusion, file, malware, and so on9.
NEW QUESTION # 321
An engineer must investigate a connectivity issue and decides to use the packet capture feature on Cisco FTD. The goal is to see the real packet going through the Cisco FTD device and see the Snort detection actions as a part of the output. After the capture-traffic command is issued, only the packets are displayed. Which action resolves this issue?
  • A. Use the capture command and specify the trace option to get the required information.
  • B. Specify the trace using the -T option after the capture-traffic command.
  • C. Perform the trace within the Cisco FMC GUI instead of the Cisco FTD CLI.
  • D. Use the verbose option as a part of the capture-traffic command
NEW QUESTION # 322
All kinds of exams are changing with dynamic society because the requirements are changing all the time. To keep up with the newest regulations of the Securing Networks with Cisco Firepower exam, our experts keep their eyes focusing on it. Expert team not only provides the high quality for the 300-710 Quiz guide consulting, also help users solve problems at the same time, leak fill a vacancy, and finally to deepen the user's impression, to solve the problem of Securing Networks with Cisco Firepower test material and no longer make the same mistake.
New Exam 300-710 Materials: https://www.braindumpspass.com/Cisco/300-710-practice-exam-dumps.html
2026 Latest BraindumpsPass 300-710 PDF Dumps and 300-710 Exam Engine Free Share: https://drive.google.com/open?id=1C_-HS2Uv1ckvRW5JlXV9-kAysP7hCqYo
Posted at 3/8/2026 02:39:46        Only Author  2#
우리 PassTIP에서는 최고이자 최신의RINCE2 인증PRINCE2-Agile-Foundation덤프자료를 제공 함으로 여러분을 도와RINCE2 인증RINCE2-Agile-Foundation인증자격증을 쉽게 취득할 수 있게 해드립니다.만약 아직도RINCE2 인증RINCE2-Agile-Foundation시험패스를 위하여 고군분투하고 있다면 바로 우리 PassTIP를 선택함으로 여러분의 고민을 날려버릴수 있습니다.
