[General] SC-400 Book Pdf | Latest SC-400 Study Guide
137
【General】 SC-400 Book Pdf | Latest SC-400 Study Guide
Posted at 2/23/2026 02:48:38      View:119 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free & New SC-400 dumps are available on Google Drive shared by 2Pass4sure: https://drive.google.com/open?id=1nQIeVRCxn8op3HjdqL1PbxoK9VUjehSN
As is known to us, the SC-400 certification has been increasingly important for a lot of modern people in the rapid development world. Why is the SC-400 certification so significant for many people? Because having the certification can help people make their dreams come true, including have a better job, gain more wealth, have a higher social position and so on. Many people are difficult in getting the SC-400 Certification successfully. If you also have trouble in passing your exam and getting your certification, we think it is time for you to use our SC-400 quiz prep.
Microsoft SC-400 Certification Exam is designed to validate the skills and knowledge of professionals who want to prove their expertise in managing and implementing information protection solutions using Microsoft technologies. Microsoft Information Protection Administrator certification is intended for IT professionals who work with data protection technologies and want to demonstrate their ability to configure, manage, and monitor information protection policies and solutions.
Latest SC-400 Study Guide & New SC-400 Test SimulatorYou can trust 2Pass4sure SC-400 exam questions and start this journey with complete peace of mind and satisfaction. The 2Pass4sure SC-400 practice questions are designed and verified by experienced and qualified SC-400 exam experts. They work collectively and put their expertise to ensure the top standard of 2Pass4sure Microsoft SC-400 Exam Dumps. So we can say that with the 2Pass4sure Microsoft SC-400 exam questions, you will get everything that you need to learn, prepare and pass the difficult Microsoft Information Protection Administrator certification exam with good scores.
Microsoft Information Protection Administrator Sample Questions (Q258-Q263):NEW QUESTION # 258
You implement Microsoft 365 Endpoint data loss prevention (Endpoint DLP).
You have computers that run Windows 10 and have Microsoft 365 Apps installed. The computers are joined to Azure Active Directory (Azure AD).
You need to ensure that Endpoint DLP policies can protect content on the computers.
Solution: You deploy the unified labeling client to the computers.
Does this meet the goal?
  • A. Yes
  • B. No
These conditions include that a device must be one of these : * Azure Active Directory (Azure AD) joined
- Hybrid Azure AD joined
- AAD registered
AND enable device monitoring and onboard your endpoints before you can monitor and protect sensitive items on a device. Both of these actions are done in the Microsoft 365 Compliance portal. However, device that have previously been onboarded into Microsoft Defender for Endpoint, will already appear in the managed devices list.
https://docs.microsoft.com/en-us ... dpoint-dlp-getting- started?view=o365-worldwide
NEW QUESTION # 259
You have a Microsoft 365 subscription that contains 100 users and a Microsoft 365 group named Group1.
All users have Windows 10 devices and use Microsoft SharePoint Online and Exchange Online.
A sensitivity label named Label1 is published as the default label for Group1.
You add two sublabels named Sublabel1 and Sublabel2 to Label1.
You need to ensure that the settings in Sublabel1 are applied by default to Group1.
What should you do?
  • A. Modify the policy of Label1.
  • B. Delete the policy of Label1 and publish Sublabel1.
  • C. Duplicate all the settings from Sublabel1 to Label1.
  • D. Change the order of Sublabel1.
NEW QUESTION # 260
You plan to implement a sensitive information type based on a trainable classifier. The sensitive information type will identify employment contracts.
You need to copy the required files to Microsoft SharePoint Online folders to train the classifier.
What should you use to seed content and test the classifier? To answer, select the appropriate options in the answer area.
https://docs.microsoft.com/en-us ... view=o365-worldwide
NEW QUESTION # 261
You plan to create a custom sensitive information type that will use Exact Data Match (EDM).
You need to identify what to upload to Microsoft 365, and which tool to use for the upload.
What should you identify? To answer, select the appropriate options in the answer area.
NEW QUESTION # 262
You need to meet the technical requirements for the Site1 documents.
Graphical user interface, text, application Description automatically generated
https://docs.microsoft.com/en-us ... ically?view=o365-wo
NEW QUESTION # 263
We have left some space for you to make notes on the PDF version of the SC-400 study materials. In a word, you need not to spend time on adjusting the PDF version of the SC-400 exam questions. You can directly print it on papers. It is easy to carry. Whenever and wherever you go, you can take out and memorize some questions. There will be detailed explanation for the difficult questions of the SC-400 Preparation quiz. So you do not need to worry about that you cannot understand them.
Latest SC-400 Study Guide: https://www.2pass4sure.com/Microsoft-Certified-Information-Protection-Administrator-Associate/SC-400-actual-exam-braindumps.html
