Oracle 1z0-1077-25 Free Exam Questions & Reliable 1z0-1077-25 Test Voucher
Posted at 2/12/2026 11:55:37
P.S. Free & New 1z0-1077-25 dumps are available on Google Drive shared by Pass4guide: https://drive.google.com/open?id=1cPb-n_vUm4uDDW9YFAiP8FX_BroHXLHE
There is no denying the fact that everyone in the world wants to find a better job to improve the quality of life. Generally speaking, these jobs are offered only by some well-known companies. In order to enter these famous companies, we must try our best to get some certificates as proof of our ability such as the 1z0-1077-25 Certification. Nowadays, the 1z0-1077-25 certification has been one of the criteria for many companies to recruit employees. And in order to obtain the 1z0-1077-25 certification, taking the 1z0-1077-25 exam becomes essential.
We don't just want to make profitable deals, but also to help our users pass the exams with the least amount of time to get 1z0-1077-25 certificate. Choosing our 1z0-1077-25 exam practice, you only need to spend 20-30 hours to prepare for the exam. Maybe you will ask whether such a short time can finish all the content, we want to tell you that you can rest assured ,because our 1z0-1077-25 Learning Materials are closely related to the exam outline and the questions of our 1z0-1077-25 guide questions are related to the latest and basic knowledge. You will pass the 1z0-1077-25 exam only with our 1z0-1077-25 exam questions.
Quiz 2026 1z0-1077-25: Oracle Order Management Cloud Order to Cash 2025Implementation Professional Free Exam QuestionsThe company is preparing for the test candidates to prepare the 1z0-1077-25 exam guide professional brand, designed to be the most effective and easiest way to help users through their want to get the test 1z0-1077-25 certification and obtain the relevant certification. In comparison with similar educational products, our training materials are of superior quality and reasonable price, so our company has become the top enterprise in the international market. Our 1z0-1077-25 practice materials have been well received by the users, mainly reflected in the following advantages.
Oracle Order Management Cloud Order to Cash 2025Implementation Professional Sample Questions (Q149-Q154):NEW QUESTION # 149
Which three statements are false in regard to integrating public Global Order Promising web services with external order capture and management systems? (Choose three.)
- A. Several steps are required to enable calling Global Order Promising by using public web services.
- B. You cannot collect Sales Orders that are scheduled in external order management systems into Global Order Promising.
- C. The services cannot be used to inquire about the availability of supply for a potential order before the order is created in Oracle Order Management.
- D. You can collect Sales Orders that are scheduled in external order management systems into Global Order Promising.
- E. No steps are required to enable calling Global Order Promising by using public web services.
Answer: A,C,D
NEW QUESTION # 150
Which change mode takes a snapshot of the following stages?
. When the orchestration process starts
When a change order is received at an orchestration process step
- A. Advanced
- B. Simple
- C. None
- D. Incremental
* Change mode is the way that Order Management handles changes to sales orders during the orchestration process.Change mode determines when Order Management takes a snapshot of the orchestration process and how it applies changes to the fulfillment lines1
* Simple change mode takes a snapshot only when the orchestration process starts.It applies changes to all fulfillment lines regardless of their status1
* Incremental change mode takes a snapshot only when the orchestration process starts.It applies changes only to the fulfillment lines that are not yet completed1
* Advanced change mode takes a snapshot when the orchestration process starts and when a change order is received at an orchestration process step.It applies changes to the fulfillment lines based on the snapshot and the current status of the lines1
* None change mode does not take any snapshot and does not apply any changes to the fulfillment lines1
* Therefore, the correct answer is C. Advanced, because it is the only change mode that takes a snapshot of the following stages: when the orchestration process starts and when a change order is received at an orchestration process step.
1: Change Mode
NEW QUESTION # 151
You have set up a Processing Constraint prohibiting updates to an extensible flexfield in a fulfillment line when Ship-From Warehouse = "Operations" and the fulfillment line status = "Booked". Although the constraint has been created, it has not been enforced when a user updates a fulfillment line that meets these conditions.
Which is the most probable cause?
- A. The "Publish extensible flexfield" process was not run.
- B. A "Record Set" needs to be created for the extensible flexfieldto be visible on the "Manage Processing Constraints" page.
- C. The "generate packages"program was not submitted.
- D. The extensible flexfield is not enabled.
A processing constraint is a rule that controls the changes that can be made to an order or a fulfillment line at various stages of the order-to-cash process.A processing constraint can be based on various attributes, such as the order type, the fulfillment line status, the ship-from warehouse, and the extensible flexfield1.An extensible flexfield is a custom attribute that you can use to capture additional information that is not provided by the predefined attributes2. To set up a processing constraint based on an extensible flexfield, you need to run the
"Publish extensible flexfield" process after you create or modify the extensible flexfield.This process enables the extensible flexfield to be visible and usable in the "Manage Processing Constraints" page3. If you do not run this process, the processing constraint will not be enforced when a user updates a fulfillment line that meets the conditions.
Overview of Processing Constraints
Overview of Extensible Flexfields
Create Processing Constraints Based on Extensible Flexfields
NEW QUESTION # 152
Your client sells a wide array of specialized products and services to customers across multiple industries.
As such, your client has complex requirements for defining their pricing programs in Pricing Cloud. You have been tasked to configure several, multifaceted pricing programs to which the client's various customers will be assigned. You will achieve this through the creation of pricing strategies.
Which are required fields when creating a pricing strategy header?
- A. Name, Description, Objective, and Start Date
- B. Name, Business Unit, Default Currency, and Objective
- C. Name, Business Unit, Default Currency, and Start Date
- D. Name, Business Unit, Start Date, and End Date
- E. Name, Description, Default Currency, and Start Date
A pricing strategy is a pricing entity that defines the overall pricing approach for a market segment. A pricing strategy consists of a header and one or more pricing segments.The header contains the general information and settings for the pricing strategy, such as the name, description, objective, business unit, default currency, start date, and end date1.When creating a pricing strategy header, the following fields are required2:
* Name: The name of the pricing strategy. It must be unique within the pricing business unit.
* Business Unit: The business unit that owns the pricing strategy. It determines the scope and visibility of the pricing strategy.
* Default Currency: The currency that is used for the pricing strategy. It is used to convert the prices of the items that are priced in different currencies.
* Start Date: The date when the pricing strategy becomes effective. It cannot be earlier than the current date.
Overview of Pricing Entities
Create Pricing Strategy Headers
NEW QUESTION # 153
Configurator rules are created by writing statements in Constraint Definition Language (CDL).
Which three are valid CDL classes?
- A. Numeric Comparisons
- B. Compatibilities
- C. Default
- D. Constraints
- E. Search Decisions
Answer: B,C,D
Constraint Definition Language (CDL) is a language that you use to create configurator rules in Oracle Configurator. Configurator rules are statements that define the logic and behavior of a configurable product model. CDL classes are categories of configurator rules that have different purposes and syntax. The valid CDL classes are:
* Default: A rule that assigns a default value to an item attribute or a component quantity when the configuration session starts.
* Constraints: A rule that restricts the values that can be assigned to an item attribute or a component quantity based on conditions.
* Compatibilities: A rule that specifies the compatibility or incompatibility between two or more items, attributes, or quantities.
Overview of Configurator Rules
Constraint Definition Language Reference Guide
NEW QUESTION # 154
At present, artificial intelligence is developing so fast. So machines inevitably grow smarter and more agile. In the result, many simple jobs are substituted by machines. In order to keep your job, choose our 1z0-1077-25 exam questions and let yourself become an irreplaceable figure. In fact, our 1z0-1077-25 Study Materials can give you professional guidance no matter on your daily job or on your career. And with the 1z0-1077-25 certification, you will find you can be better with our help.
Reliable 1z0-1077-25 Test Voucher: https://www.pass4guide.com/1z0-1077-25-exam-guide-torrent.html
Including the key points about the Reliable 1z0-1077-25 Test Voucher - Oracle Order Management Cloud Order to Cash 2025Implementation Professional exam training torrent, So, do not hesitate, 1z0-1077-25 exam cram will bring you light and hope, What is more, 1z0-1077-25 study materials can fuel your speed and the professional backup can relieve you of stress of the challenge, We also offer up to 1 year of free updates on Oracle 1z0-1077-25 dumps after the date of purchase, More importantly, it is evident to all that the 1z0-1077-25 training materials from our company have a high quality, and we can make sure that the quality of our products will be higher than other study materials in the market.
Beyond the Originals: Ways to Enjoy and Share, The `CPageSetupDialog` class Study Materials 1z0-1077-25 Review encapsulates the Page Setup dialog that's often used with printing functionality, Including the key points about the Oracle Order Management Cloud Order to Cash 2025Implementation Professional exam training torrent.
100% Pass 1z0-1077-25 - Professional Oracle Order Management Cloud Order to Cash 2025Implementation Professional Free Exam QuestionsSo, do not hesitate, 1z0-1077-25 Exam Cram will bring you light and hope, What is more, 1z0-1077-25 study materials can fuel your speed and the professional backup can relieve you of stress of the challenge.
We also offer up to 1 year of free updates on Oracle 1z0-1077-25 dumps after the date of purchase, More importantly, it is evident to all that the 1z0-1077-25 training materials from our company have a high quality, and 1z0-1077-25 we can make sure that the quality of our products will be higher than other study materials in the market.
- Exam 1z0-1077-25 Registration 📘 1z0-1077-25 Accurate Test 🎆 1z0-1077-25 Exam Sample 🛫 Search for ▛ 1z0-1077-25 ▟ and download it for free immediately on 《 [url]www.pass4test.com 》 🔈1z0-1077-25 Free Updates[/url]
- 1z0-1077-25 Accurate Test 🏋 1z0-1077-25 Exam Sample 🐑 1z0-1077-25 Exam Sample 👎 Easily obtain ➡ 1z0-1077-25 ️⬅️ for free download through [ [url]www.pdfvce.com ] 🏹1z0-1077-25 Free Updates[/url]
- Best-selling 1z0-1077-25 test-taking Questions Free Exam Questions 🎨 The page for free download of “ 1z0-1077-25 ” on ⮆ [url]www.vceengine.com ⮄ will open immediately 🗯1z0-1077-25 Valid Braindumps Files[/url]
- Latest 1z0-1077-25 Test Training Materials Will Update Constantly - Pdfvce 🏛 Easily obtain free download of ➽ 1z0-1077-25 🢪 by searching on ➤ [url]www.pdfvce.com ⮘ ↙Dumps 1z0-1077-25 Free[/url]
- 1z0-1077-25 Reliable Test Notes 📷 1z0-1077-25 Valid Braindumps Files 👾 1z0-1077-25 Exam 🛅 Search for ➥ 1z0-1077-25 🡄 and easily obtain a free download on 《 [url]www.pdfdumps.com 》 ❣1z0-1077-25 Practice Questions[/url]
- Updates to Oracle 1z0-1077-25 Exam Questions Are Free For 1 year 🪓 「 [url]www.pdfvce.com 」 is best website to obtain ➡ 1z0-1077-25 ️⬅️ for free download 💂1z0-1077-25 Latest Exam Answers[/url]
- 1z0-1077-25 Pass Guide 👫 1z0-1077-25 Reliable Test Notes 🤍 1z0-1077-25 Dumps Torrent 🍔 Simply search for ➽ 1z0-1077-25 🢪 for free download on ▛ [url]www.examdiscuss.com ▟ 🤓Valid Test 1z0-1077-25 Vce Free[/url]
- Free PDF 1z0-1077-25 - Reliable Oracle Order Management Cloud Order to Cash 2025Implementation Professional Free Exam Questions 🌲 Search for “ 1z0-1077-25 ” and download it for free immediately on “ [url]www.pdfvce.com ” 🍮Dumps 1z0-1077-25 Free[/url]
- Valid Test 1z0-1077-25 Vce Free 🐳 1z0-1077-25 Accurate Test 🛢 1z0-1077-25 Exam 🛄 Search for { 1z0-1077-25 } and download exam materials for free through ( [url]www.verifieddumps.com ) ‼Latest 1z0-1077-25 Exam Practice[/url]
- Provides complete coverage of every objective on exam 1z0-1077-25 Free Exam Questions 🎳 Download ⮆ 1z0-1077-25 ⮄ for free by simply searching on ▶ [url]www.pdfvce.com ◀ 🏑1z0-1077-25 Reliable Test Notes[/url]
- 1z0-1077-25 Test Discount Voucher 🐘 1z0-1077-25 Dumps Torrent 🦁 1z0-1077-25 Exam Sample 💮 Search for “ 1z0-1077-25 ” on ( [url]www.examcollectionpass.com ) immediately to obtain a free download 🤺Test 1z0-1077-25 Testking[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, hashnode.com, www.stes.tyc.edu.tw, ycs.instructure.com, www.stes.tyc.edu.tw, httydfunart.blogspot.com, www.stes.tyc.edu.tw, Disposable vapes
P.S. Free 2026 Oracle 1z0-1077-25 dumps are available on Google Drive shared by Pass4guide: https://drive.google.com/open?id=1cPb-n_vUm4uDDW9YFAiP8FX_BroHXLHE
