[Hardware] Exam CKA Material£üReady to Pass The Certified Kubernetes Administrator (CKA) Pro
89
¡¾Hardware¡¿ Exam CKA Material£üReady to Pass The Certified Kubernetes Administrator (CKA) Pro
Posted at 2/7/2026 14:34:48      View£º225 | Replies£º1        Print      Only Author   [Copy Link] 1#
2026 Latest ITExamDownload CKA PDF Dumps and CKA Exam Engine Free Share: https://drive.google.com/open?id=1N6P8LS4OSJWsE-eNHlopgbYc5-UNlIX6
Our company enjoys good reputation in the field of providing certificate exam materials. We are dedicated to providing good and efficient CKA study guide for candidates. You can pass the exam by using the CKA questions and answers of us, therefore we are pass guarantee. If you fail to pass the exam, we will money back guarantee, and the money will return to your payment account. We are confident with our CKA Study Guide, you can trust us.
Linux Foundation CKA (Certified Kubernetes Administrator) Program Certification Exam is a leading certification program designed for IT professionals who want to demonstrate their expertise in managing and deploying applications using Kubernetes technology. Kubernetes is an open-source container orchestration system that automates the deployment, scaling, and management of containerized applications. As containerization becomes increasingly popular in modern software development, the demand for Kubernetes experts has grown rapidly. The CKA certification program is an excellent way for IT professionals to enhance their Kubernetes skills, demonstrate their expertise to employers, and advance their careers.
Linux Foundation Certified Kubernetes Administrator (CKA) program is a certification designed to test the knowledge and skills of individuals in the field of Kubernetes administration. Kubernetes is one of the most popular container orchestration platforms, and it is widely used by organizations to manage their containerized applications. The CKA program is developed and maintained by the Linux Foundation, which is a non-profit organization that promotes the use of open source technologies.
The CKA certification is a globally recognized certification that is highly valued in the IT industry. It is designed to validate the skills and knowledge of IT professionals who can operate Kubernetes clusters. Certified Kubernetes Administrator (CKA) Program Exam certification is ideal for individuals who want to demonstrate their expertise in Kubernetes and advance their careers in the IT industry. The CKA program is an excellent opportunity for IT professionals to enhance their skills and knowledge and become certified Kubernetes administrators.
Exam CKA Material Will Be Your Best Friend to Pass Certified Kubernetes Administrator (CKA) Program ExamThe memory needs clues, but also the effective information is connected to systematic study, in order to deepen the learner's impression, avoid the quick forgetting. Therefore, we can see that in the actual CKA exam questions, how the arrangement plays a crucial role in the teaching effect. The CKA Study Guide in order to allow the user to form a complete system of knowledge structure, the qualification CKA examination of test interpretation and supporting course practice organic reasonable arrangement together.
Linux Foundation Certified Kubernetes Administrator (CKA) Program Exam Sample Questions (Q68-Q73):NEW QUESTION # 68
You have a Kubernetes cluster with multiple namespaces. You need to set up RBAC to allow a specific user, "developer", to only deploy and manage pods within the "dev" namespace, but restrict access to other resources.
See the solution below with Step by Step Explanation.
Create the following YAML files:
1. Role.yaml:
2. RoleBinding.yaml:
Solution (Step by Step) : 1 . Create the Role: Apply the 'Role.yamP file using 'kubectl apply -f Role.yamr. This defines the permissions granted to the role 'pod-manager-dev' within the 'dev' namespace. 2. Create the RoleBinding: Apply the 'RoleBinding.yaml' file using 'kubectl apply -f RoleBinding.yaml'. This binds the 'pod-manager-dev' role to the user 'developer' , allowing them to access resources defined in the role. 3. Verify Access: As the user 'developer' , try deploying a pod or managing deployments within the 'dev' namespace. Verify that the user has the necessary permissions. 4. Test Restrictions: Try accessing resources outside the 'dev' namespace or trying actions not defined in the role (e.g., creating a service in the 'dev' namespace). Verify that the user is denied access.
NEW QUESTION # 69
Get the number of schedulable nodes and write to a file
/opt/schedulable-nodes.txt
  • A. kubectl get nodes -o jsonpath="{range
    .items
  • }{.metadata.name}
    {.spec.taints[?(@.effect=='NoSchedule')].effect}{""}{end}"
    | awk 'NF==11 {print $0}' > /opt/schedulable-nodes.txt
    // Verify
    cat /opt/schedulable-nodes.txt
  • B. kubectl get nodes -o jsonpath="{range
    .items
  • }{.metadata.name}
    | awk 'NF==1 {print $0}' > /opt/schedulable-nodes.txt
    // Verify
NEW QUESTION # 70
Get the memory and CPU usage of all the pods and find out top 3 pods which have the highest usage and put them into the cpuusage.txt file
  • A. // Get the top 3 pods
    kubectl top pod --all-namespaces | sort --reverse --key 3 --
    numeric | head -8
    // putting into file
    kubectl top pod --all-namespaces | sort --reverse --key 6 --
    numeric | head -6 > cpu-usage.txt
    // verify
    cat cpu-usage.txt
  • B. // Get the top 3 pods
    numeric | head -3
    numeric | head -3 > cpu-usage.txt
    // verify
    cat cpu-usage.txt
NEW QUESTION # 71
You must connect to the correct host.
Failure to do so may result in a zero score.
[candidate@base] $ ssh Cka000049
Task
Perform the following tasks:
Create a new PriorityClass named high-priority for user-workloads with a value that is one less than the highest existing user-defined priority class value.
Patch the existing Deployment busybox-logger running in the priority namespace to use the high-priority priority class.
Task Summary
* SSH into the correct node: cka000049
* Find the highest existing user-defined PriorityClass
* Create a new PriorityClass high-priority with a value one less
* Patch Deployment busybox-logger (in namespace priority) to use this new PriorityClass Step-by-Step Solution
1## SSH into the correct node
bash
CopyEdit
ssh cka000049
## Skipping this = zero score
2## Find the highest existing user-defined PriorityClass
Run:
bash
CopyEdit
kubectl get priorityclasses.scheduling.k8s.io
Example output:
vbnet
CopyEdit
NAME VALUE GLOBALDEFAULT AGE
default-low 1000 false 10d
mid-tier 2000 false 7d
critical-pods 1000000 true 30d
Exclude system-defined classes like system-* and the default global one (e.g., critical-pods).
Let's assume the highest user-defined value is 2000.
So your new class should be:
* Value = 1999
3## Create the high-priority PriorityClass
Create a file called high-priority.yaml:
cat <<EOF > high-priority.yaml
apiVersion: scheduling.k8s.io/v1
kind: PriorityClass
metadata:
value: 1999
globalDefault: false
description: "High priority class for user workloads"
EOF
Apply it:
kubectl apply -f high-priority.yaml
4## Patch the busybox-logger deployment
Now patch the existing Deployment in the priority namespace:
kubectl patch deployment busybox-logger -n priority
--type='merge'
-p '{"spec": {"template": {"spec": {"priorityClassName": "high-priority"}}}}'
5## Verify your work
Confirm the patch was applied:
kubectl get deployment busybox-logger -n priority -o jsonpath='{.spec.template.spec.priorityClassName}'
# You should see:
high-priority
Also, confirm the class exists:
kubectl get priorityclass high-priority
Final Command Summary
ssh cka000049
# Create the new PriorityClass
kind: PriorityClass
metadata:
value: 1999
EOF
# Patch the deployment
--type='merge'
# Verify
kubectl get deployment busybox-logger -n priority -o jsonpath='{.spec.template.spec.priorityClassName}' kubectl get priorityclass high-priority
NEW QUESTION # 72
Update the deployment with the image version 1.17.4 and verify
  • A. kubectl set image deploy/webapp nginx=nginx:1.17.4
    //Verify
    kubectl describe deploy webapp | grep Image
    kubectl get deploy -o=jsonpath='{range.items
    {.metadata.name}{"        "}{.spec.template.spec.containers
  • .i
    mage}{""}'
  • B. kubectl set image deploy/webapp nginx=nginx:1.17.4
    //Verify
  • .i
    mage}{""}'
NEW QUESTION # 73
One of the best features of Linux Foundation CKA exam dumps is its discounted price. Our Linux Foundation CKA Exams prices are entirely affordable for everyone. We guarantee you that no one can beat us in terms of CKA Exam Dumps prices. Get any Linux Foundation CKA exam dumps format and start preparation with confidence.
Reliable CKA Learning Materials: https://www.itexamdownload.com/CKA-valid-questions.html
P.S. Free & New CKA dumps are available on Google Drive shared by ITExamDownload: https://drive.google.com/open?id=1N6P8LS4OSJWsE-eNHlopgbYc5-UNlIX6
Posted at 4/20/2026 04:22:18        Only Author  2#
Amazon AWS-Solutions-Associate 덤프구매전 한국어 온라인상담서비스부터 구매후 덤프 무료 업데이트버전제공 , Amazon AWS-Solutions-Associate시험불합격시 덤프비용 전액환불 혹은 다른 과목으로 교환 등 저희는 구매전부터 구매후까지 철저한 서비스를 제공해드립니다. Amazon AWS-Solutions-Associate 덤프는 인기덤프인데 지금까지 덤프를 구매한후 환불신청하신 분은 아직 없었습니다.
